Toymods » Tech & Conversions » Visual identification of AE86 Diff
funkymonkey
Melbourne, Australia
Visual identification of AE86 Diff Wed, 15 June 2005 09:54 Go to next message
Its on an 1983 AE86 Toyota Sprinter, VIN plate says T50 S314. However the car has disc brakes on the rear. Which is what throws me off.
So I took some pics...
http://www.superfunhappysliders.com/fun/shan86/diff_01.jpg
http://www.superfunhappysliders.com/fun/shan86/diff_02.jpg
http://www.superfunhappysliders.com/fun/shan86/diff_03.jpg
http://www.superfunhappysliders.com/fun/shan86/diff_04.jpg
After a bit of searching on google, Club4ag and toymods I managed to find a post that said 8 bolts = S Series, 10 bolts = T Series, and many many posts saying "do a search". Very Happy Also afaik S series didn't come with disc brake hubs, only the T series diffs did.
I can't quite work out how many bolts there are on it, so if anyone would like to make an educated guess what it is (ie if its still a S314 or something else) and as to what's been done to this rear axle I'd appreciate it.
[Updated on: Wed, 15 June 2005 10:34]
ShiRi
Re: What diff is this? Wed, 15 June 2005 09:57 Go to previous messageGo to next message
funkymonkey wrote on Wed, 15 June 2005 19:54
you can't count to 10?
looks like there'd be 10 to me...
funkymonkey
Re: What diff is this? Wed, 15 June 2005 10:04 Go to previous messageGo to next message
heh, I can count to well more than 10 last time I checked, I can't however see ALL the bolts on the diff to count em without putting the car on a hoist. I'm hoping one of the guys more accustomed to toyotas (as I'm a complete n00b at anything other than Nissan drivetrains) will be able to recognise the diff easily. And if it is an 8 blot S-Series, explain how it has disc brakes.
ShiRi
Re: What diff is this? Wed, 15 June 2005 10:09 Go to previous messageGo to next message
1. stick head under car
2. put hand on top side of diff if ur so unflexible to lean up and swivle ur head a bit
3. find bolt, move hand clockwise to next bolt, repeat until ur hand is in the same position it started in
4. add up total number of bolts
funkymonkey
Re: What diff is this? Wed, 15 June 2005 10:16 Go to previous messageGo to next message
*sigh* thanks for the wisdom Shiri, informative as always...
ShiRi
Re: What diff is this? Wed, 15 June 2005 10:24 Go to previous messageGo to next message
well its a t-series disc brake diff
simply enough for u?
study the pics and think about it for two seconds i can count 6 allready and i can't see the top half of it
ae86slaver
Re: What diff is this? Wed, 15 June 2005 12:40 Go to previous messageGo to next message
ShiRi wrote on Wed, 15 June 2005 20:09
better yet, just looking at the first pic i can tell it's a T18 diff with sway bar mounts - which means its off a later model T18.
If it has discs, there is quite a possibility that this is a jap differential, but also could be a T18 diff with discs adapted.
The way i would tell is the end flanges - if you 'stick your head' Laughing behind one wheel, and look at the flanges which adapt to the backing plates of the brakes, it should either look like these:
http://img212.echo.cx/img212/3400/tseriesdiff9ve.jpg
lol @ my paint skills
hope it helps dude
funkymonkey
Re: What diff is this? Thu, 16 June 2005 05:54 Go to previous messageGo to next message
Helps a lot, thanks mate... that's the sort of response I was hoping for.
I just recieved a TRD 2Way LSD (pic) out of an early model japanese AE86. Will this fit into the aussie T-18 housings if it turns out its the aussie one? Are they the ones that come out of the celiecas?
PS those paint skills are awesome... they look like they came out of a technical manual Very Happy
[Updated on: Thu, 16 June 2005 05:55]
ae86slaver
Re: Visual identification of AE86 Diff Thu, 16 June 2005 06:00 Go to previous message
That LSD will definately fit into that diff.
The T18 diff is basically the exact same as the JDM diff apart from the end flanges/discs brakes, smaller axle bearings and obviouslt the LSD - but the housing/centre housing is somewhat identical.
have super happy sliding fun!
Previous Topic:GT4 Gearboxes
Next Topic:transparent cam gear covers ----4age
Current Time: Sun Nov 1 22:30:26 UTC 2026
Total time taken to generate the page: 0.0083720684051514 seconds
