Toymods » Tech & Conversions » RT-142 IRS LSD Options
d-master
Adelaide - Drift Capital
RT-142 IRS LSD Options Wed, 15 June 2005 11:22 Go to next message
What could I chuck into the stock housing so I have two wheels spinning while I'm sliding?
Intensevil
Re: RT-142 IRS LSD Options Wed, 15 June 2005 13:03 Go to previous messageGo to next message
im assuming an rt142 has an F series lsd in which case you could go tru track or shim up an ma61 lsd
ra23celica
Re: RT-142 IRS LSD Options Thu, 16 June 2005 02:29 Go to previous messageGo to next message
If this Corona is the Australian made model its likely to have a Borg-Warner diff and LSD's for these are just no longer available.
Corona RT142
Campbelltown
Re: RT-142 IRS LSD Options Thu, 16 June 2005 02:42 Go to previous messageGo to next message
actually even if it is the aus spec ones the irs models run different diff i'm pretty sure only the live rear axle ones like mine run a borg warner diff. And even that can be solved. A guy with a 1ggte conversion runs a R31 skyline lsd
Re: RT-142 IRS LSD Options Thu, 16 June 2005 04:30 Go to previous messageGo to next message
If it has IRS it's definitely an F series diff, and yes an MA61 LSD will bolt right in. A TrueTrac centre is another option if you want to spend the $$$.
d-master
Re: RT-142 IRS LSD Options Wed, 22 June 2005 12:51 Go to previous messageGo to next message
Excellent. I'll pull it out soon as can but now I'm whipping up an exhaust and preparing for a respray.
PHOBIA
Cental Coast NSW
May 2005
Re: RT-142 IRS LSD Options Wed, 10 August 2005 23:45 Go to previous messageGo to next message
Norbie wrote on Thu, 16 June 2005 14:30
Do you know if the Detroit TrueTrac center is actualy available for the RT-142 IRS diff or was that just an example. I have checked there site and can't see that model listed. Thanks Norbie, im just in the market for one now. Thanks.
Re: RT-142 IRS LSD Options Thu, 11 August 2005 00:03 Go to previous messageGo to next message
They have it listed for the "Toyota 4-cylinder Pickup/Land Cruiser II/4 Runner" (aka Hilux). The front diff for the 86-95 models is listed with a 7.5" diameter ring gear, in other words it's an F series diff. This means it will fit in any F series housing, including MA61, RA65 and RT142.
If you buy it through RabidChimp they'll also supply the correct bearings, which are different to the ones you have now.
Re: RT-142 IRS LSD Options Thu, 11 August 2005 00:08 Go to previous messageGo to next message
Norbie wrote on Thu, 16 June 2005 12:30
Spend the difference, the Truetrac is awesome, so damn tight it chirps slightly pulling out of my driveway at the workshop, and so consistent.
PHOBIA
Cental Coast NSW
May 2005
Yeah, im on that site at the moment. I just couldn't make the connection between the diffs. Thanks for your help Norbie. Wink
PHOBIA
Cental Coast NSW
May 2005
Re: RT-142 IRS LSD Options Tue, 16 August 2005 05:30 Go to previous messageGo to next message
I've looked into this a little more and have been speaking to Claus from Locked Drive Systems, he has been advised that the AU delivered RT-142 with IRS has a 23 spline axle and as such they do not have a True Trac LSD to fit. The LSD that should fit (Toyota 4-cylinder Pickup/Land Cruiser II/4 Runner) have a 27 spline axle.
If anyone can confirm or deny this find that would be much appreciated. If not, I'll have to pull mine down to have a look. Thanks again. Wink
[Updated on: Tue, 16 August 2005 05:31]
Re: RT-142 IRS LSD Options Tue, 16 August 2005 05:47 Go to previous messageGo to next message
Hmm odd. I would've thought that if it could take an MA61 LSD, then it could take a Truetrac. I'd keep researching, it's well worth it Razz
Re: RT-142 IRS LSD Options Tue, 16 August 2005 05:54 Go to previous messageGo to next message
PHOBIA wrote on Tue, 16 August 2005 15:30
Are you sure he's not talking about the REAR diff there? The Hilux has a G series 8" diff in the rear, and an F series 7.5" diff in the front. It's the front diff you want, and I can 100% confirm it fits in an MA61 so there's no reason it won't fit in an RT142.
PHOBIA
Cental Coast NSW
May 2005
Re: RT-142 IRS LSD Options Tue, 16 August 2005 06:07 Go to previous messageGo to next message
It was defiantly the Hilux front diff as you said that fits, but the "diff specialist" they use to fit up the centres is addiment that the RT-142 has the 23 spline axels and the Hilux run a 27 spline axel. I think I am just going to have to have a look for myself.
Re: RT-142 IRS LSD Options Tue, 16 August 2005 06:43 Go to previous messageGo to next message
I think your "diff specialist" is smoking crack. The IFS Hilux TrueTrac centre has been successfully fitted to the MA61 Supra, RA65 Celica and even Stitt's old Crown wagon. I find it hard to believe the RT142 has a special type of F series diff that's totally different to all the other F series diffs, for no apparent reason.
Stefan
Hobart, Tas
Re: RT-142 IRS LSD Options Tue, 16 August 2005 06:57 Go to previous messageGo to next message
Norbie wrote on Tue, 16 August 2005 16:43
I think your "diff specialist" is smoking crack...
ROTFLMAO!
PHOBIA
Cental Coast NSW
May 2005
Re: RT-142 IRS LSD Options Tue, 16 August 2005 07:17 Go to previous message
He is there "specialist", but I have my doubts though. Rolling Eyes
Previous Topic:Some more Celica Questions
Next Topic:Grinding noise..spigot bearing?
Current Time: Sun Nov 1 00:19:31 UTC 2026
Total time taken to generate the page: 0.069214820861816 seconds
