Toymods » General Car Talk » Looking at buying a 89 celica need some info
michaelhaynes110
Townsville, QLD, Australia
June 2005
Looking at buying a 89 celica need some info Wed, 15 June 2005 11:32 Go to next message
Hi everyone
I have been looking into buying a 89 celica and have been doing a fair bit of research but i thought i should ask the owners what they think of them.
Can you give me some info on downfalls, easy mods and also some pictures of your celicas so i know what they can look like.
Also info on average number of k's for this kind of car and how much more they are good for would be great as well.
And before anyone says use the search button....i have and it gave me some info. I am just after some more.
[Updated on: Wed, 15 June 2005 11:40]
smashed_wombat
Re: Looking at buying a 89 celica need some info Wed, 15 June 2005 13:50 Go to previous messageGo to next message
Hey, howareya? Welcome!
Which model Celica were you looking at? There were two versions around in 1989 - the square 4th generation (ST162) and the rounder 5th generation (ST184)?
Also try a quick search of the forums, there's a stack of good info floating around in here.
RWDboy
Re: Looking at buying a 89 celica need some info Thu, 16 June 2005 01:07 Go to previous messageGo to next message
Hey I had huge list of stuff but then my server went 'boom'.
Basically - I've always found that the number of kays a car has done is mostly irrelevant to whether it's in good nick. Some engines are crapped after 70,000km simply because they weren't looked after properly (rings seized in, bearings/crank stuffed etc). Heck, my GT4 (ST165) blew up and it had only done 130,000km and it wasn't to do with the fact that it was turbo or the engine was unduly stressed - simply starved of oil due to me not topping the oil up (it was consuming oil at a prodigious rate though so I'm only 95% to blame).
So in effect - you should look at the condition of the engine rather than the number of k's. 3S-GEs can do around about 200,000 to 250,000km before they probably need some amount of rebuilding (valve seats, piston rings and sometimes big end bearings just for safety's sake, checking bores etc for out-of-round).
One thing you should definitely look for is whether it has the 3S-GE engine, or the 3S-FE engine. If it has the latter - then don't bother, the car is probably boring Razz
As for what they should look like? Just make sure they are straight and the paint is in good nick and you can't spot any rust (check rear boot hatch, the spare wheel well, and the front windscreen pillars).
Easy mods? You can do little things like new springs, shocks, maybe stick a decent exhaust on it. But after that it gets either mechanically tricky to do, or expensive to do (to be worth it).
Overall the only downfall of these cars is the fact that it's E-W lay-out, which means servicing things like timing belts can be annoying (if you haven't done it a few times before) and I've had mechanics do some shit work when I've had to return a car to them repeatedly (mainly because they CBFed doing the same things over and over again, so they decided that they might as well just leave the bolts out that are holding stuff on).
But on the plus side there's plenty of boot space (thanks to simple rear suspension layour), the rear seats are bit of a squeeze - the cars are nice and light-weight and good to get around in, quite fuel economical when driven reasonably and even from stock they have *excellent* turn in and response (I wouldn't particularly recommend lowering the car to improve the cornering, the drop in centre of gravity doesn't really make up for the change in roll centre of the suspension etc).
Celica_John
Re: Looking at buying a 89 celica need some info Thu, 16 June 2005 02:42 Go to previous messageGo to next message
I so much like the interior on the series 2 st162s as opposed to the series 1.
ST162GT-R
QLD, Gold Coast
Re: Looking at buying a 89 celica need some info Fri, 17 June 2005 01:46 Go to previous messageGo to next message
Celica_John wrote on Thu, 16 June 2005 12:42
what are the differences from the series 1 and 2 interiors?
matt86sx
Gold Coast, QLD
Re: Looking at buying a 89 celica need some info Fri, 17 June 2005 05:17 Go to previous messageGo to next message
The only differences I am aware of are the steering wheel, door handles and power window buttons, otherwise they are identical AFAIK.
smashed_wombat
Re: Looking at buying a 89 celica need some info Fri, 17 June 2005 12:41 Go to previous message
Dont forget the silver panel in the console! Although those are coming back into fashion. Cool Nah, I think the fact that light blue, grey and brown were taken off the colour palette makes the difference. The black interior is the nicest IMO.
Previous Topic:sport compact classes
Next Topic:ra23 front spoiler....
Current Time: Fri Nov 20 21:22:27 UTC 2026
Total time taken to generate the page: 0.076772928237915 seconds
