Classifieds » Engines, Accessories and other Mechanicals » JZA70 c/member and J rear sump. [1j into early soarer]
manmx83
JZA70 c/member and J rear sump. [1j into early soarer] Wed, 15 June 2005 12:25 Go to next message
For the 1J\2J into GZ or MZ 20\21 soarer [apparently bolts straight up]
In brisbane.$350 pick up.Delivery\freight negotiable.
Crossmember is fairly complete with struts,brakes,rack included in the price[no engine mounts].
To seperate could do jza sump $100. c/member $250 [rack included]please email. Smile
anyone with jza70 unbroken engine mounts I may buy them.pls email
[Updated on: Sun, 26 June 2005 15:07]
manmx83
Re: JZA70 c/member and J rear sump. Sun, 26 June 2005 13:00 Go to previous messageGo to next message
do people still do this conversion?
Re: JZA70 c/member and J rear sump. [1j into early soa Mon, 27 June 2005 01:32 Go to previous messageGo to next message
PM 'MR_1JZ' and 'Hamgatan'
Between those 2 someone should want them.
MR 1JZ
Re: JZA70 c/member and J rear sump. [1j into early soa Mon, 27 June 2005 02:39 Go to previous messageGo to next message
im interested pete, let me get back too you soon regarding it if i can find a cheap subsititue for 1JZ engine mounts from repco or sprints
manmx83
Re: JZA70 c/member and J rear sump. [1j into early soa Mon, 27 June 2005 16:36 Go to previous messageGo to next message
those pesky mounts! perhaps a group buy is in order,always seems to be someone in need,if not for a new conversion its to replace a broken one.seems quite common.[1J mounts] Sad
MR 1JZ
Re: JZA70 c/member and J rear sump. [1j into early soa Mon, 27 June 2005 21:52 Go to previous messageGo to next message
well my engine now has semi solid mounts which are a combination of steel and polyurethane and they are doing the job nicely but my engine is on a very slight lean...
fixing sump and front guard is the priority atm but if you havent sold it in a couple of weeks then I will most probably take it off you
manmx83
Re: JZA70 c/member and J rear sump. [1j into early soa Tue, 28 June 2005 01:35 Go to previous messageGo to next message
Best of luck!cheers.Pete. Smile
Stenno
Re: JZA70 c/member and J rear sump. [1j into early soa Tue, 28 June 2005 02:07 Go to previous messageGo to next message
manmx83 wrote on Tue, 28 June 2005 02:36
You're referring to the rubber insulators right, not the alloy brackets that bolt onto the block?
If so, you can use the updated JZA80 insulators, they go for about $120-$140 each from memory and are of better construction - these were used from late 95 onwards. The earlier insulators are of a different design.
manmx83
Re: JZA70 c/member and J rear sump. [1j into early soa Tue, 28 June 2005 04:48 Go to previous messageGo to next message
Thanks stenno,better and stronger but the same size eh?
hamgatan
Re: JZA70 c/member and J rear sump. [1j into early soa Thu, 30 June 2005 00:36 Go to previous message
i may need all the kit and kaboodle, but lemme see if i can source the front cut first! Confused
Previous Topic:KE55 differential and brake assembly - Great Condition $50
Next Topic:SR20DET motor, computer + loom cheap
Current Time: Thu Nov 19 14:58:27 UTC 2026
Total time taken to generate the page: 0.0091969966888428 seconds
