Toymods » Tech & Conversions » 1998 Camry Antenna Won't Go Up
Razor
1998 Camry Antenna Won't Go Up Thu, 16 June 2005 02:05 Go to next message
1998 Camry Conquest
MCV20R V6
The antenna won't go up when I put the radio on, it doesnt make any noise at all. Cos if there's a noise then its the mast that needs replacing.
Do these cars have a relay or fuse for the antenna?
I had a look on the kickpanel's fuse box and there's no fuse for the antenna there.
Advice please
kingmick
Banned by his request
moved to tamworth
Re: 1998 Camry Antenna Won't Go Up Thu, 16 June 2005 21:51 Go to previous messageGo to next message
just get a multi meter and check that there is power getting to the motor. if not just replace it with factory or aftermarket one, you could snap it and get a metal coat-hanger for the, i dont care look. the only trouble is it creats more drag,so when you cruising at 280km/h it might get a bit noisey and cost you .001 of a km/h.
mick
muaythaiman
Re: 1998 Camry Antenna Won't Go Up Thu, 16 June 2005 22:09 Go to previous messageGo to next message
Do what kibgmick said with the multi. If power is there the motor may be burnt out. Go buy an Aerpro one.
Razor
Re: 1998 Camry Antenna Won't Go Up Thu, 16 June 2005 22:49 Go to previous messageGo to next message
thanks for the advice
will do
Re: 1998 Camry Antenna Won't Go Up Fri, 17 June 2005 12:08 Go to previous messageGo to next message
Bust it off, start with a shiny new coathanger, and attempt to bend it in the shape of Australia. Thing is, Tassie's a bugger to include if you don't have a soldering iron Laughing (for some reason, my mother took a dislike when I did this to her Commodore?)
ae86drift
sydney.au
Re: 1998 Camry Antenna Won't Go Up Fri, 17 June 2005 12:19 Go to previous messageGo to next message
mrshin wrote on Fri, 17 June 2005 22:08
you are a king amongst men.. ROFL
FWDCelica
sydney,nsw.oz.
Re: 1998 Camry Antenna Won't Go Up Sat, 18 June 2005 05:17 Go to previous message
Razor wrote on Thu, 16 June 2005 12:05
1998 Camry Conquest
MCV20R V6
Mr. Razor,
Do you have the Camry Owners Manual (supplied with the new car)?
Page 222 says there are 2 fuses for Audio system/power antenna.
1 (Fuse no. 14)is in the Engine Compartment Fuse Box (the long black cover between battery and guard)
and 1 (Fuse no. 36)is in the Fuse Compartment to the right of and below the steering wheel.
Check them both !
Hope this helps.
T.
Previous Topic:20v ignitors
Next Topic:STREEING box repairs
Current Time: Sat Oct 17 07:47:11 UTC 2026
Total time taken to generate the page: 0.005159854888916 seconds
