Toymods » Tech & Conversions » 4age camshaft seal leak - how serious?
boudan
4age camshaft seal leak - how serious? Thu, 16 June 2005 04:06 Go to next message
Anyone had troubles with their camshaft seals (oil leak)?
How serious is the problem likely to be after repair?
Is there a chance major damage could be done while camshaft seals have been leaking?
b1gb3n
south Melbourne/KL
Re: 4age camshaft seal leak - how serious? Thu, 16 June 2005 04:25 Go to previous messageGo to next message
is that the seal at the cam gears?? or cam cover seals??
boudan
Re: 4age camshaft seal leak - how serious? Thu, 16 June 2005 09:24 Go to previous messageGo to next message
possibly cam gears ( there was 2 seals replaced)
I think the cam cover seal would be a one piece item.
Re: 4age camshaft seal leak - how serious? Thu, 16 June 2005 12:58 Go to previous messageGo to next message
There's two camshafts, there's two camshaft seals, and there's two cam cover seals. Both are relatively easy to replace, and leaks aren't likely to cause TOO much damage, except for making a mess. However, if the cam belt is all oily etc. then slip a new one one as it goes together, in case the oil has effected it. Well worth the few lousy extra $.
boudan
Re: 4age camshaft seal leak - how serious? Thu, 16 June 2005 14:55 Go to previous message
Much appreciated...
Previous Topic:4age sumps, 3rib and 7rib the same?
Next Topic:4age 20 valve blacktop fault codes
Current Time: Sun Oct 25 07:10:53 UTC 2026
Total time taken to generate the page: 0.026183843612671 seconds
