Toymods » Tech & Conversions » 89661-12250
sideshow
89661-12250 Thu, 16 June 2005 06:02 Go to next message
hey can anyone with toyota epc check whjat this ecu is off
part num is 89661-12250
its either an 86kw or a 100 kw
someone has mixed looms and ecus and thing is runnin like shit
i recon they have 86kw ecu with 100kw loom or the other way round which makes injectors pulse twice as much
EvilJack
Sutho/Hills NSW
Re: 89661-12250 Thu, 16 June 2005 07:50 Go to previous messageGo to next message
mine says NOT APPLICABLE
i have access to both a 86kw ecu and 100kw ecu i will try and get the part numbers off them.
EvilJack
Sutho/Hills NSW
Re: 89661-12250 Thu, 16 June 2005 07:58 Go to previous messageGo to next message
http://www.rollamods.com/holding/ecu100kw.jpg
i duno if this helps you in knowing its a 100kw one you have
EvilJack
Sutho/Hills NSW
Re: 89661-12250 Thu, 16 June 2005 09:53 Go to previous messageGo to next message
ok i can confirm that the 86kw ecu = 89661-12080
Toobs
Re: 89661-12250 Thu, 16 June 2005 11:39 Go to previous messageGo to next message
If you feel like finding a working Russian proxy this thing will work for you:
http://www.japancats.ru/toyota
Its an online EPC... unfortunately it gives forbidden errors for anything but a russian IP address.
It took me about half an hour to find a working RU proxy to get into it last time Sad
Might be quicker and easier to just phone Toyota.
ra23celica
Re: 89661-12250 Thu, 16 June 2005 13:47 Go to previous messageGo to next message
Sideshow,
My EPC also says 'not applicable ' but it only lists JDM, so looking at their numbers, the AE82 ECU's range from -12010 to -12110.
The AE92 units run from -12180 to -12450.
It probably unlikely, but you may have an Aust spec ECU from an SX AE92 which is why I have no listing for the thing.
Like what's been said above, try calling a Toyota dealer parts dept. and quote them the number you have and see what they say..
Mitch.
sideshow
Re: 89661-12250 Thu, 16 June 2005 22:33 Go to previous messageGo to next message
ok cool
well i just found out the car was runnin sort fo ok then got bad
i was under the impression it had not run good
i guess the ecu is right one for the engine and wiring and there must be another prob
i have to go on tues to fix it and fix the dodgey wiring
i got told it used to have a ze now they fitted an 86kw back into it
1200det
Re: 89661-12250 Fri, 17 June 2005 02:14 Go to previous message
Ecu is to suit 86kw AE82 for following months/years
10/1987 - 12/1988
Previous Topic:ST165 to ST205 engine/gearbox conversion
Next Topic:20v engine covers on 16v head
Current Time: Fri Oct 23 22:40:35 UTC 2026
Total time taken to generate the page: 0.0060608386993408 seconds
