Toymods » Tech & Conversions » MR2 2nd gen 3S-GE dyno . whats the compression on these engine's?
soobelica
March 2005
MR2 2nd gen 3S-GE dyno . whats the compression on these engine's? Thu, 16 June 2005 09:24 Go to next message
hello,
I had my car dyno'd, its an MR2 '90 2nd gen 3S-GE. It manages 72.9kw@wheels. Just wondering if this is the correct amount for an engine that has 117kw@fly.
Ive seen another MR2 of the same year get around 90kw... but perhaps it depends on the person who does the dyno??
I also compression tested the engine and it got 177/176/173/178
[Updated on: Fri, 17 June 2005 14:43]
VRTULX
Re: MR2 '90 2nd gen 3S-GE dyno result question. Thu, 16 June 2005 11:37 Go to previous messageGo to next message
I recently got my engine rebuilt, its a 3rd gen but i got a reading of 90kws@wheels. My 3rd gen 3sge is meant to have 130kws at the fly, so it does sound about right.
Joshstix
Toymods Vice President
Re: MR2 '90 2nd gen 3S-GE dyno result question. Thu, 16 June 2005 12:43 Go to previous messageGo to next message
At our last dyno day at SAS a Gen2 3S MR2 put down 94.1KW and a really nice Gen3 put down 105.2KW. On the other hand a Gen3 swapped into an OZ delivered SW20 all stock setup made 154.1, very very nice car.
The results are Dyno Day 10 results.
soobelica
March 2005
Re: MR2 '90 2nd gen 3S-GE dyno result question. Thu, 16 June 2005 13:06 Go to previous messageGo to next message
Hmmm.... maybe it depends on the correction factor the dyno operator puts in. Mine was .88 SAE J607, not exactly sure what that means.
also 72.9kw is a 37% loss from the drive train, seems a bit high to me.
Alchemist
Re: MR2 '90 2nd gen 3S-GE dyno result question. Thu, 16 June 2005 13:07 Go to previous messageGo to next message
Yes 72KW is a little low Confused even considering variances between dyno's. My MR2 was the Gen 2 that put down 94.1RWKW, it had a HKS filter, extractors and an exhaust, but I'd expect a stock Gen 2 3S-GE to put out 90 or so.
How long have you had the car for? has it been serviced? Checked plugs, leads, fuel filter, timing? They are a pretty zippy car when they are on song.
Just a note the 154.1 was from a 3S-GTE, not a GE. I got a ride in it, damn fast car Very Happy
Alchemist
Re: MR2 '90 2nd gen 3S-GE dyno result question. Thu, 16 June 2005 13:11 Go to previous messageGo to next message
Here's my dyno chart if it's any help.
http://members.iinet.net.au/~warrenh/MR2/dyno_chart_web.jpg
soobelica
March 2005
Re: MR2 '90 2nd gen 3S-GE dyno result question. Thu, 16 June 2005 13:52 Go to previous messageGo to next message
Ive had the car for about 8 weeks (2 weeks on the road), bought it at the damaged car auctions. It was lightly damaged at the front only.
It has a full service history with toyota services upto 140k, and regular services up until 208,000km.
I changed the leads, and checked the plugs, and timing belt was changed a few thousand KM's ago according to its history.
that dyno graph is similar to mine, except my my afr is a bit flatter, and mine dyno was performed in 4th gear, which is closest to 1:1 ratio.
Only other thing i notice is mine doesnt tend to 'jump' so much in power like yours does at 113km/h. its more steady and consistent climb
Alchemist wrote on Thu, 16 June 2005 22:37
[Updated on: Thu, 16 June 2005 13:53]
Joshstix
Re: MR2 '90 2nd gen 3S-GE dyno result question. Thu, 16 June 2005 13:55 Go to previous messageGo to next message
The Toymods Dyno day is run on a Dyno Dynamics dyno in shoot out mode, this controls all of the correction factors like inertia etc.
LiL_MiC
Melb
Re: MR2 '90 2nd gen 3S-GE dyno result question. Thu, 16 June 2005 22:29 Go to previous messageGo to next message
That's interesting. most of the dyno graphs i've seen including mine show a torque drop at about 3k+rpm? and then a big increase at about 4.5krpm? (approximately around there). I thought it was a 3sge gen 2/3 thing on just how the engine works.
soobelica
March 2005
Re: MR2 2nd gen 3S-GE dyno . whats the compression on these engine's? Fri, 17 June 2005 14:47 Go to previous messageGo to next message
anyone know what the compression on these engine is meant to be? mine got
177/176/173/178
Alchemist
Re: MR2 2nd gen 3S-GE dyno . whats the compression on these engine's? Sat, 18 June 2005 05:28 Go to previous messageGo to next message
I know the compression for the 3SGE is 10:1, but I don't know what it is supposed to be per cylinder, I'm sure someone on here will know.
TRD-ST162
Re: MR2 2nd gen 3S-GE dyno . whats the compression on these engine's? Sat, 18 June 2005 06:43 Go to previous messageGo to next message
Interestin result, i've got 86.8kw from a gen 1 3sge in a st162 celica... All it had was a 2.25" exhaust and a k&n Panel Filter. The timing was also quite severly limited, for some reason the timing was set to 6 degrees, standard is 10 degrees.
smashed_wombat
Re: MR2 2nd gen 3S-GE dyno . whats the compression on these engine's? Sun, 19 June 2005 12:52 Go to previous messageGo to next message
72kw is low, standard gen 1 3SG's put out about 75kw at the treads.
RobST162
Re: MR2 2nd gen 3S-GE dyno . whats the compression on these engine's? Mon, 20 June 2005 03:39 Go to previous message
seems a bit low to me dude
Previous Topic:Hachi Roku Speed Alarm/Chime
Next Topic:4AGE Hunting at idle and really high idle.
Current Time: Sat Oct 24 04:37:30 UTC 2026
Total time taken to generate the page: 0.0060999393463135 seconds
