Classifieds » Parts Wanted » 18rg 88253 head(found)
mkal6
melbourne
18rg 88253 head(found) Thu, 16 June 2005 13:10 Go to next message
hey guys
im after the illusive 18rg 210 head motor(the powerful one Very Happy )
preferbly the whole motor but seing that there are things around the forum.....
in vic (postcode 3842)
drop a line and lets work something out
regards
mo
[Updated on: Sat, 18 June 2005 17:58]
jcmunga
adelaide
Re: 88210 18rg Fri, 17 June 2005 02:01 Go to previous messageGo to next message
Actually the most powerfull 18rg head would be the 88253. The 88210 just has better cams. The 88253 has bigger valves. What you want for more power. You put some nice cams or the 88210 cams in the 88253 head and presto. The best combo.
Jesse
mkal6
melbourne
Re: 88210 18rg Sat, 18 June 2005 05:03 Go to previous messageGo to next message
neone s got a complete motor with 253 head then. it will be nice if its somewhere in vic, would save alot of money on postage
regards
mo
o_man_ra23
Townsville North Qld
icon10.gif  Re: 18rg 88253 head(found) Sun, 19 June 2005 13:13 Go to previous message
ive got an ultimate combo 18RG. problem is im in townsville North Qld, and i want to sell it as a fully rebuilt ready to run item.
The block is from a 230 headed motor, so it has the 9.7:1 pistons, and the crank has had the rear mainseal area metalsprayed and refinished (no more oil leaks!!). The dizzy is electronic to suit 21RC ignitor and coil, the head is an 88270(unleaded, biggest valves and ports), the cams are from 88230(same as 210), your choice of short or long manifold, carbs are from 230 head (the non-problematic ones) with two 600cfm ramflo washable filters. Engine will be sold re-ringed, new bearings, balanced pistons and rods(balanced crank at extra cost), cams will be timed to your specifications (torquier or revvier) and will be supplied with new ngk plugs and 8mm top gun leads. Sump and pickup is your choice of rear pickup (celica etc) or front pickup(corolla etc). engine will also be painted to your choice of colour.
Expressions of interest should be emailed to O_man_ra23@yahoo.com.au
P.S the motor i just did up is running EFI with a cheap computer, and revvs to 8500RPM without a trouble. thats the one in my car Evil or Very Mad
Previous Topic:WTD: ae86 Jap Climate control
Next Topic:camry distributor (from 3S-F / 3S-FC ) update not the EFI dizzy
Current Time: Thu Oct 29 14:09:10 UTC 2026
Total time taken to generate the page: 0.0075199604034424 seconds
