Classifieds » Engines, Accessories and other Mechanicals » 2TG parts, some new, garage clean out !!
ta22rally
Gawler S.A.
June 2005
2TG parts, some new, garage clean out !! Thu, 16 June 2005 14:00 Go to next message
after a garage clean out and house shift i've uncovered some bits i've had stored for about 10 years, all come with a good layer of dust but otherwise are in condition as listed !!
NEW 2TG cam cover gasket set (rubber, not cork) still in TRD packaging
NEW 2TG spark lead set (toyota, not TRD) still in packaging
used 2TG spark lead set, in good condition, original toyota items
NEW Mikuni complete rebuld kits (two) suit original 40mm Mikuni/Solex as per 2TG, still in blister packs
NEW 36mm outer venturi suit Solex 40mm (set of four)
NEW 2TG top chain rubbing block
NEW 2TG side (long curved type) chain rubbing block
heaps of bags of NEW Mikuni/Solex parts (screws, venturis, gaskets, o rings, etc..)still in bags, if your after anything email and check what i've got
used 2TG cam Wheels, bolts, pins (original type),timing chain, in good nic
used head bolts
2TG manual adjustable chain tensioner, in good nic
used 2TG valve buckets, i'm sure i've got some shims somewhere bit i'll have to look for them
2TG electronic dizzy, in good nic
Original toyota 2T/2TG workshop manual, in good nic except for name on front cover
Original 18R/18/RG manual in same nic as above
K-Mac rear sway bar 21mm suit TA23
Selby front sway bar (underhanging type)17mm suit TA23
NEW TA22 GT front "clear" indicator lenses (2 pair, left and right)still in packaging
NEW rear lenses only suit early (71-72) TA22, sold as pair only, still in box
NEW left rear lense and assembly suit early (71-72) TA22
also have some speedo cables, clutch reservoir caps, used petrol cap (no key), clutch slave cylinder..
All parts are in Gawler S.A., will post anywhere in OZ at buyers expense after payment received
i have photos of most bits, for prices, details etc,.. email me contact@bigpond.net.au
EldarO
Perth, WA
Re: 2TG parts, some new, garage clean out !! Thu, 16 June 2005 15:47 Go to previous messageGo to next message
going rate for the seal?
Eldar.O.
blackRA28
adelaide
Re: 2TG parts, some new, garage clean out !! Sat, 18 June 2005 03:25 Go to previous messageGo to next message
Prices on the following:
*NEW 2TG top chain rubbing block
*NEW 2TG side (long curved type) chain rubbing block
can pickup.
emailed u too.
Mr DOHC
Re: 2TG parts, some new, garage clean out !! Sun, 19 June 2005 07:41 Go to previous messageGo to next message
what jets u got for the solex's,
how much for the 36mm venturis
got mixture screws
yrhkira
June 2005
Re: 2TG parts, some new, garage clean out !! Mon, 27 June 2005 05:54 Go to previous messageGo to next message
Your "heaps of Mikuni/Solex parts" line.
What would you want for all the bits?
Regards
Rodger
cooter
perth
Re: 2TG parts, some new, garage clean out !! Mon, 27 June 2005 08:38 Go to previous messageGo to next message
pm sent
yrhkira
June 2005
Re: 2TG parts, some new, garage clean out !! Tue, 28 June 2005 02:42 Go to previous messageGo to next message
cooter,
I had PM disabled in my profile. Please send again.
Regards
Rodger
Pheonix
Wa
Re: 2TG parts, some new, garage clean out !! Tue, 28 June 2005 12:41 Go to previous messageGo to next message
Are these still available, if so how much.
timstoys
Tacoma Wa USA
Re: 2TG parts, some new, garage clean out !! Mon, 04 July 2005 07:56 Go to previous messageGo to next message
Are the tails still available?
cooter
perth
Re: 2TG parts, some new, garage clean out !! Mon, 04 July 2005 10:53 Go to previous messageGo to next message
sorry yrhkira but i dont member why i pmd you.
shelldrake
parkdale, Victoria
May 2005
Re: 2TG parts, some new, garage clean out !! Mon, 04 July 2005 12:39 Go to previous message
hey,
If the 2tg distributor is still there I know who needs one! Pm me a price delivered to melbourne. Thanks heaps!
Previous Topic:44mm Solex Carbies with manifold to suit 18R-G
Next Topic:FS - KN Panel Filter P/N:33-2030 - Celica/Corolla/MR2 + More
Current Time: Sun Oct 18 06:57:53 UTC 2026
Total time taken to generate the page: 0.059866189956665 seconds
