Toymods » Tech & Conversions » 18r-geu vs. 18r-g + EFI conversion
trent_kershaw
18r-geu vs. 18r-g + EFI conversion Tue, 03 December 2002 02:20 Go to next message
Okay, I've definitely decided I want EFI on my 18r (carby's too hard to start in winter)
Is it easy to convert an 18rg to EFI?
how much of a power advantage would there be over the 18r-geu if any?
anything else I should know?
Thanks in advance,
Trent
Re: 18r-geu vs. 18r-g + EFI conversion Tue, 03 December 2002 02:25 Go to previous messageGo to next message
If you have all of the necessary parts, it's piss-easy. I did it a few years back, and back then I'd never touched an EFI car before.
You won't get any more peak power with EFI (unless your original carbies were stuffed and/or out of tune), but you will notice a much fatter torque curve from idle to redline - and that's just as important as peak power for a street-driven car. Fuel consumption is heaps better as well!
trent_kershaw
Re: 18r-geu vs. 18r-g + EFI conversion Tue, 03 December 2002 06:45 Go to previous messageGo to next message
So that means that the 18r-g with EFI conversion out-performs an 18r-g with original carby setup?
So that means there is an awesome advantage of that over the 18rgeu. Brilliant
Do you reckon you could gimme a quick list of the neccessary parts? I think I have a fair idea, but I may have overlooked something.
XTreme_Corona
adelaide
Re: 18r-geu vs. 18r-g + EFI conversion Tue, 03 December 2002 07:19 Go to previous messageGo to next message
this is a bit off topic but, i was wondering since the 18r and 22r are of the same engine family, can you put the 18r-geu head on the 22re block?
trent_kershaw
Re: 18r-geu vs. 18r-g + EFI conversion Tue, 03 December 2002 07:26 Go to previous messageGo to next message
I'm pretty sure that the answer to that is a big fat no.
Malicia
Re: 18r-geu vs. 18r-g + EFI conversion Tue, 03 December 2002 07:36 Go to previous messageGo to next message
Thats correct 22r and 18r are different
Re: 18r-geu vs. 18r-g + EFI conversion Tue, 03 December 2002 11:53 Go to previous messageGo to next message
You will need:
- inlet runners
- plenum
- throttle body
- fuel rail & injectors
- 18R-GEU thermostat housing (the 18R-G one fouls the plenum)
If you're using factory electronics, you will also need:
- ECU (duh)
- wiring harness
- airflow meter
You should also cut reliefs into the inlet ports for the injectors. Some people skip this step, but I'm sure Toyota put them there for a reason...
Re: 18r-geu vs. 18r-g + EFI conversion Tue, 03 December 2002 23:51 Go to previous messageGo to next message
don't forget the surge tanks and EFI pumps Very Happy
sounds like fun! i would like to do this... but dammit... webers are just too cool! Razz
Re: 18r-geu vs. 18r-g + EFI conversion Wed, 04 December 2002 00:42 Go to previous messageGo to next message
Actually I'm running no surge tank and a single EFI pump from a Camira. I know it's not ideal, but I've yet to experience fuel surge - and believe me, my Celica gets fanged around corners quite often! Smile
Bugman
Re: 18r-geu vs. 18r-g + EFI conversion Wed, 04 December 2002 00:53 Go to previous messageGo to next message
just dont do it with virtually no petrol in the tank and you should be fine right?
it's all I'm doing for my 28 with a 1g in it till after the engineering
inferno
Re: 18r-geu vs. 18r-g + EFI conversion Wed, 04 December 2002 01:01 Go to previous messageGo to next message
I've used the one fuel pump with my 2TGEU, never any surge, but never ran close to empty tank. The 1G would need more fuel though, I've been in a worked 2TG and a 3TG and they both surged on 1/8 tank, so you may be alright if you keep your tank above 1/2.
sbyder
Ipswich QLD
Re: 18r-geu vs. 18r-g + EFI conversion Wed, 04 December 2002 03:38 Go to previous messageGo to next message
i think you left out
Dizzy
ignitor/ignition system
Just found that i needed these parts. Smile
Kinda essential.
Re: 18r-geu vs. 18r-g + EFI conversion Wed, 04 December 2002 03:55 Go to previous message
His exisiting ignition system will work fine. It's not a bad idea to upgrade to an electronic dizzy, but it's not essential - I ran my 18R-GEU on an old 18R-C points dizzy for quite a while and that was OK.
Previous Topic:Sterio Install with pics
Next Topic:oil seals
Current Time: Mon Nov 9 20:48:22 UTC 2026
Total time taken to generate the page: 0.0061838626861572 seconds
