Toymods » Tech & Conversions » Carbon clean???
Rainey
Hobart, Tasmania
January 2005
Carbon clean??? Fri, 17 June 2005 04:06 Go to next message
What exactly is involved with a carbon clean as such? My mechanic has recommended it for next service.
Sorry I probably get the prize for the most n00b question in here, but at least I used the right section! Laughing
Re: Carbon clean??? Fri, 17 June 2005 05:06 Go to previous messageGo to next message
spary WD40/RP7 liberally thru spark plug holes. leave overnight or more. start engine, check for carbon on pistons.. repeat Wink
Rainey
Hobart, Tasmania
January 2005
icon14.gif  Re: Carbon clean??? Fri, 17 June 2005 05:36 Go to previous messageGo to next message
Ahhh! That makes it clearer for me! Thanks mate.
Merudo
Central Coast, NSW
February 2005
Re: Carbon clean??? Fri, 17 June 2005 05:55 Go to previous messageGo to next message
oldcorollas wrote on Fri, 17 June 2005 15:06
That's literally all you have to do?
I'm assuming you do this to a cold engine? Wink
Corona RT142
Campbelltown
Re: Carbon clean??? Fri, 17 June 2005 06:01 Go to previous messageGo to next message
nah works much better on a hot running engine you should try it one day.
Merudo
Central Coast, NSW
February 2005
Re: Carbon clean??? Fri, 17 June 2005 06:06 Go to previous messageGo to next message
Corona RT142 wrote on Fri, 17 June 2005 16:01
oh damn mango you're so funny Rolling Eyes Razz
Re: Carbon clean??? Fri, 17 June 2005 07:10 Go to previous messageGo to next message
well, whenever i pull a motor down, WD40 or similar is applied to carbon coated pistons.. after a day or so, the carbon basically just falls off, whereas previously it is rock hard..
hopefully he is also talking about cleaning valves and manifolds etc...
maybe just ask the mechanic exactly what is involved in the process.. if he's not happy to tell you, tell him you are not happy to pay for the work if he doesn't know what is involved Wink
allencr
tallahassee FL usOFa
Re: Carbon clean??? Fri, 17 June 2005 13:12 Go to previous messageGo to next message
it's BS!
find someone else.
FKN16V
NSW, East Coast
Re: Carbon clean??? Sat, 18 June 2005 05:00 Go to previous messageGo to next message
allencr wrote on Fri, 17 June 2005 23:12
it's BS!
find someone else.
Rubbish allencr.
A close friend of mine owned a corolla gti had 140,xxxkms on it, run fine, always properly serviced, good enough to eat camry's anyway.
Had a carbon clean done at one of his service intervals($160), and holy shit what a difference, better fuel economy, better low torque, better overall, so i say do it if its been recomended do it.
As far as i know they disconnect your fuel line, plumb in a machine and let the motor idle for a peroid of time, 30mins for my friends corolla.
The motor farts of pops all over the place blowing whitish smoke. Then plumb it back together again, fresh oil and spark plugs and away you go.
Simple as that really, from what i could tell at least.
I guess the only downside to a carbon clean is that if any carbon was filling on holes/gaps anywhere it wouldnt be good afterwards.
Steve
[Updated on: Sat, 18 June 2005 05:06]
4agte
Toronto, Downtown
Re: Carbon clean??? Sat, 18 June 2005 05:18 Go to previous messageGo to next message
sounds very similar to using throttle body cleaner while the engine is running
M.W.P.
Rocky Mountains, Canada
Re: Carbon clean??? Sat, 18 June 2005 05:46 Go to previous messageGo to next message
Ive heard rotary guys pour Redline injector cleaner (or similar) into the spark plug holes, turn it over a few times (no ign, to spread the stuff around) and leave it for a few days before starting up.
Cleans off the carbon from thr rotor seals, etc.
Should also work well on a piston engine.
Just make sure you start it back up at night.... it creates a HUGE amount of smoke.
People will think there is a forrest fire in yoiur backyard if you do it during the day.
Re: Carbon clean??? Sat, 18 June 2005 08:00 Go to previous messageGo to next message
On engines I don't really care about too much (e.g. my old 2T) I've done it by feeding water down the air intake while I'm doing some Greek Rev Tuning in the driveway. Seems to stem the run on etc. for a week or two.
BradW
Bottom of the hill, Sydney
Re: Carbon clean??? Sat, 18 June 2005 08:48 Go to previous messageGo to next message
mrshin wrote on Sat, 18 June 2005 18:00
We did a similar thing to my old XF Falcon. It was pinging heaps. Checked timing, etc, all ok. So we started it up, pulled one of the BIG vacuum lines from the manifold off and put it into a bucket of water while reving the engine. Blew a shitload of smoke while we did it, but ran better after and didn't ping as much.
I wouldn't recommend this though if you like your engine as it can cause a bit of damage.
b1gb3n
south Melbourne/KL
Re: Carbon clean??? Sun, 19 June 2005 12:34 Go to previous messageGo to next message
so i just spray shitloads of carbie cleaner/wd40 into spark plug hole and start engine the next day??
do i have the spark plugs back on after spraying??
brendanteck
January 2005
Re: Carbon clean??? Mon, 20 June 2005 01:31 Go to previous messageGo to next message
Subaru sell cans spray cans of decarbonizer. They run it through the cars every second service ( because they carbon up so bad ) works great. You spray a bit in while it is running then leave it and it blows lots of smoke and cleans the engine out.
HyDrA
Adelaide, SA
Re: Carbon clean??? Mon, 20 June 2005 01:57 Go to previous messageGo to next message
Would any RP7/WD40 seep past the rings and get into the oil? That might be a concern... Confused
Rainey
Hobart, Tasmania
January 2005
icon14.gif  Re: Carbon clean??? Mon, 20 June 2005 03:00 Go to previous messageGo to next message
Well my mechanic is a friend as well as an owner of a workshop. He treats my car with a lot of respect and he said it would probably need a good carbon clean for the km's it's done. He said we can assess it when I bring it in on Wednesday and I trust his word I just didn't know what it involved. When I go in I'll see if I can find out what the process is.
Re: Carbon clean??? Mon, 20 June 2005 03:29 Go to previous messageGo to next message
HyDrA wrote on Mon, 20 June 2005 11:57
compared to how much fuel already gets into the oil? probably not a problem, and would largely evaporate when the motor warms up...
Merudo
Central Coast, NSW
February 2005
Re: Carbon clean??? Mon, 20 June 2005 03:41 Go to previous messageGo to next message
God knows if my car's ever been carbon cleaned.... considering the state of the old spark plugs, i'd say not Rolling Eyes
cannonball
Sydney NSW
Re: Carbon clean??? Mon, 20 June 2005 04:39 Go to previous messageGo to next message
As a Subie owner, i can say that subie workshops do this all the time, (with an actual decoking/decarboning stuff) and it is always reccomended to do this just before you do an oil change.
Just think of where all that nice abrasive carbon muck goes if it isnt blown out the exhaust??
M.W.P.
Re: Carbon clean??? Mon, 20 June 2005 05:50 Go to previous messageGo to next message
cannonball wrote on Mon, 20 June 2005 14:09
So there is a product made to do this job?
Any idea what it is?
Yian
Lwr Templestowe, Melbourne
Re: Carbon clean??? Mon, 20 June 2005 05:58 Go to previous messageGo to next message
Subaru Cylinder head cleaner? I think that's what its called. My mate used to be a mechanic at Subaru and he 'borrowed' a few cans.. used it on my car when we did the conversion. Good shit.
Aust162
Melb, Victoria
Re: Carbon clean??? Mon, 20 June 2005 08:27 Go to previous messageGo to next message
Is this "subaru cyl head cleaner" safe to spray into a flapper type afm?can it foul-up the sensor at all or do damage to a turbo itself?
Noob question:I assume you take off your air filter and just spray it in Confused
M.W.P.
Re: Carbon clean??? Mon, 20 June 2005 09:10 Go to previous messageGo to next message
Aust162 wrote on Mon, 20 June 2005 17:57
Very much a noob question.
Did you read any of the above?
To remove any kind of hard carbon, it must be soaked/softened first.
This cant be done by sprying somthing into the engine while its running... itll just get burnt.
jzx83
Gympie
June 2005
Re: Carbon clean??? Mon, 20 June 2005 13:03 Go to previous messageGo to next message
M.W.P. wrote on Mon, 20 June 2005 19:10
Actually, if you've ever taken off a cylinder head which has had water leaking into the combustion chamber, you'd probably realise that engine coolant can make a pretty good job of de-carbonising. The cylinder in question is generally as clean as a whistle, while the others are still as grotty as you'd expect. Don't know how long the water needs to be going into the motor though. Also care needs to be exercised that you don't get too much in there at once and 'hydraulic' the motor. ie try to force water to compress and end up bending a rod or sundry other possible nasty outcomes. I have limited myself to a spray bottle and misting the water into the carby for about a quarter of an hour, lots of billowing smoke/steam and (probably) much cleaner inside afterward. We have also put second hand motors into junker Falcons and freed up the rings by dropping oil or Moreys down the carby. Smokes like a bogan for quite a while, but does seem to bring the compression up. I wouldn't recommend oil to reduce carbon though, I'd reckon if anything it may increase the carbon. My mate who is a retired diesel fitter reckons they used to put a cleaner called Bon Ami down the carby, not sure if that was for carbon or glazed bores or both. I think it was something similar to Jif or possibly Ammonia. Anyway, carby cleaner is probably a pretty good bet, although I still reckon the water would work, after all, one of the effects of water injection is to keep the carbon off the combustion chamber surfaces, hence reducing pre ignition. The other effect being that the water vaporising absorbs some of the heat in the intake charge thus cooling it and giving a small intercooling effect. Which also helps prevent pre ignition.
Richard
4agte
Toronto, Downtown
Re: Carbon clean??? Mon, 20 June 2005 13:29 Go to previous messageGo to next message
i know people that say alltho they wouldnt do it to thier engine they have seen people do it to paddock bashers they didnt care about and as much as he didnt want to believe it worked he said the car ran a whole lot better after it.
The guy whos car it was took the filter off the carby and poured washing powder down it while running.
Aparantly made huge amounts of smoke and the smell was unbearable but once it cleared the car ran alot better go figure huh..
M.W.P.
Re: Carbon clean??? Mon, 20 June 2005 14:55 Go to previous messageGo to next message
jzx83 wrote on Mon, 20 June 2005 22:33
A long time i think.
Guys running water injection end up with almost zero carbon build up.
Ive done the water into the carb trick a few times before.
After pulling the head off my engine last week, it looks like it has almost no effect.
The piston domes had a thick very hard carbon layer on them... i had to remove it with a blade, soaking it with WD40 did squat to help remove it Sad
4agte
Toronto, Downtown
Re: Carbon clean??? Mon, 20 June 2005 14:57 Go to previous messageGo to next message
have you tried throttle body cleaner???
EldarO
Perth, WA
Re: Carbon clean??? Mon, 20 June 2005 15:14 Go to previous messageGo to next message
4agte wrote on Mon, 20 June 2005 22:57
throttle body cleaner, and carby cleaner, are pretty much one in the same, meaning, they do the same shit.
Eldar.O.
4agte
Toronto, Downtown
Re: Carbon clean??? Mon, 20 June 2005 15:17 Go to previous messageGo to next message
EldarO wrote on Tue, 21 June 2005 01:14
Eldar.O.
M.W.P said he had tried water and wd40 i dont see where carby cleaner was mentioned
[Updated on: Mon, 20 June 2005 15:17]
TA-022
Glenmore Park, NSW
Re: Carbon clean??? Mon, 20 June 2005 22:37 Go to previous messageGo to next message
b1gb3n wrote on Sun, 19 June 2005 22:34
b1gb3n
south Melbourne/KL
Re: Carbon clean??? Mon, 20 June 2005 23:31 Go to previous messageGo to next message
TA-022 wrote on Tue, 21 June 2005 08:37
are u re-asking the question or answering it with ur signature??
4agte
Toronto, Downtown
Re: Carbon clean??? Tue, 21 June 2005 04:13 Go to previous messageGo to next message
b1gb3n wrote on Tue, 21 June 2005 09:31
he is pointing out where carby cleaner is mentioned but i wasnt referring to that person
TA-022
Glenmore Park, NSW
Re: Carbon clean??? Tue, 21 June 2005 11:20 Go to previous messageGo to next message
what he said.
Very Happy
greenta22
Dandenong Ranges, VIC
Re: Carbon clean??? Tue, 21 June 2005 15:16 Go to previous messageGo to next message
Fuck water. Do what I did Very Happy
http://forums.toymods.org.au/index.php?t=msg&t h=68326&start=0&rid=6463&S=07aea6b1a5f ca88fb7791bd04870c433
urban_myth
Re: Carbon clean??? Wed, 22 June 2005 06:19 Go to previous messageGo to next message
Doesnt any premium unleaded or better petrol have cleaning agents in them to clean carbon buildup? Cos i have been puttin this stuff in my car for the past 5000 kms
Ribfeast
Newcastle, Australia
March 2005
Re: Carbon clean??? Wed, 22 June 2005 06:20 Go to previous messageGo to next message
Just do the carbon clean yourself and save some money.
I'd never heard of it until reading this thread, so I bought some carby cleaner yesterday and sprayed it down the spark plug holes while I was changing them, the car coughed and spluttered a bit when I kicked it over later but then ran nice and smooth. Didn't notice a huge difference to before really, but maybe my engine is fairly clean inside. I didn't do it overnight though as I did the spark plug swap & regap during my lunchbreak.
[Updated on: Wed, 22 June 2005 06:21]
Merudo
Central Coast, NSW
February 2005
Re: Carbon clean??? Wed, 22 June 2005 06:23 Go to previous messageGo to next message
urban_myth wrote on Wed, 22 June 2005 16:19
yeah but carbon buildup from 20,000km ago probably isnt going to come off with just using premium.
perhaps the carby cleaner into the cylinder and leaving it overnight is the better idea.
I might try this tomorrow night!
jeffro RA28
Tamworth
Re: Carbon clean??? Wed, 22 June 2005 08:01 Go to previous messageGo to next message
For me Brake Cleaner works great. I clean heads with this everyday. Just spray it on and add a bit of compressed air and its gone.
Mind you they are race engines that have been running 15.1 comp and alcy, so being run on alcy there isnt much carbon, but wats there is gone after some brake cleaner.
I have also used it on my 18r, worked ok i guess but some scrubbing was needed.
Big T
Re: Carbon clean??? Wed, 22 June 2005 09:36 Go to previous messageGo to next message
Aust162 wrote on Mon, 20 June 2005 18:27
It's called "Subaru Upper Engine Cleaner". My cousin's a subie mechanic and he "lent" me a couple cans to use. It's specifically made for removing carbon deposits and stuff.
Eddie.
Aust162
Melb, Victoria
Re: Carbon clean??? Wed, 22 June 2005 11:02 Go to previous messageGo to next message
Big T wrote on Wed, 22 June 2005 19:36
Eddie.
Fair enough. i was just repeating was someone else wrote. Smile
i've never heard of the stuff until this week.
do you know if the product is for sale "direct to the public," say from subaru spare parts dealership?
Big T
Re: Carbon clean??? Wed, 22 June 2005 11:08 Go to previous messageGo to next message
Not sure if it's available to the public but i see no reason it wouldn't be. Just try calling up and asking for it at the parts department. The worst they can do is simply say no.
Eddie.
4agte
Toronto, Downtown
Re: Carbon clean??? Wed, 22 June 2005 14:34 Go to previous messageGo to next message
probably uber costly if its anything like buying things from toyota
Jezza
Re: Carbon clean??? Wed, 22 June 2005 23:22 Go to previous messageGo to next message
some people with rotaries also use ATF (automatic transmission fluid) or brake fluid to clean carbon from their engines.
they squirt some in the spark plug holes, turn it over (not starting it) and sit for an hr or so, then repeat, until u r happy, and then start it up. lots of billowing white smoke for a while, and then supposedly the carbon is gone. havent tried it myself though, might give it a go on the celica Very Happy
jzx83
Gympie
June 2005
Re: Carbon clean??? Thu, 23 June 2005 04:48 Go to previous messageGo to next message
Regarding Brake cleaner.
Be very very careful not to inhale this stuff as I have been told of an experienced mechanic who combined his work on a car's braking system with his love of a cigarette, with fatal results.
If you think about the difficulty of removing the type of stuff that brake cleaner products are used on, it seems likely that there may be some heavy duty nasties involved. Having said that, my mate said that he thinks they may have changed the formulation to prevent this happening. My tendency with anything that I don't know the ingredients of is to assume the worst... and then be half arsed about reducing the danger. I would also love to know what is in the soobie head cleaner product too. Am seeing little bro tonight so I'll ask him. He is a gun Subaru mechanic.
In my previous post I mentioned my mate telling me about Bon Ami. I spoke to him again and it is basically a powder version of Jif, and the people using it were mechanics on the Bathurst racers. The purpose of putting it down the carbys was to free up freshly built engines, and bed them in. Since bedding in involves a certain amount of wear, I think it is probably NOT what you would want to do to an old(er) engine.
When I mentioned the other possible methods to my mate, he was:
a/ Horrified by the vacuum pipe into the bucket of water.
b/ Agreeable to the idea of misting water into intake (He was the one who showed me how to do it after all)
c/ Agreeable that brake clean, brake fluid, auto fluid and naturally the soobie product should all work.
If you were doing plugs out, put agent down the cylinders and leave in for a time. the thing to be careful of might be to make sure that none of the metal objects that it comes in contact with are going to be munched by the agent. It is probably for this reason that this job is usually done with motor running as the stuff is only in there until it gets burned/belched out.
Cheers Richard
jzx83
Gympie
June 2005
Re: Carbon clean??? Thu, 23 June 2005 04:59 Go to previous messageGo to next message
Hey I forgot to mention.
d/ Possum piss (RP7, WD40 etc etc) Yeah Maybe. Not sure if they are aggressive enough to do very much with carbon.
Also, on the subject of water/steam. In the '60s my mate had made up a steam injectio system on his workshop runabout Holden. It consisted of fine copper pipe wrapped around the exhaust manifold to heat up the water. Then the steam was directed into the intake somewhere. The result was that the vehicle ran better all the time, and when the head was removed years later it was 'as clean as a whistle'. Which probably proves the case for water injection ie continuous or at least regular doses of h2o. It may be more tenuous for spending 15 to 30 minutes misting water into the intake of a running motor. The process is unlikely to do any harm but its also possible that it won't do the full job either. Only way to know is to speak to someone with lots of experience in doing it.
Confused Yet?
Cheers Richard
jeffro RA28
Tamworth
Re: Carbon clean??? Thu, 23 June 2005 10:28 Go to previous messageGo to next message
jzx83 wrote on Thu, 23 June 2005 14:48
Whoops, i have been using this to clean my hands.
illuminatus
eastern suburbs, melbourne
March 2005
Re: Carbon clean??? Fri, 24 June 2005 00:49 Go to previous messageGo to next message
i got some fuel system cleaner put in yesturday.
WOW. what a difference.
they unplugged a vacuum hose and succed some of it up to clean out the head/upper cylinder and put the rest into my fuel tank.
straight away the revs have increased by 500rpm(need to get that fixed now)
but its so responsive and drives like new now. i recomend getting the treatment done on any car.
my car in a twin cam ae82 (4age) with 250000kms. the car revs out so nicely now.
[Updated on: Fri, 24 June 2005 00:51]
Rainey
Hobart, Tasmania
January 2005
Re: Carbon clean??? Fri, 24 June 2005 01:02 Go to previous messageGo to next message
Okay guys I was actually able to observe the carbon cleaning machine at my workshop on Wednesday. Basically they connect a trolley machine to your fuel line and run the car on an alternate fluid rather than it's independent tank. They take the car through some variable rpm and the machine monitors the fluid level so that they know when to stop it.
I'll let you know if I notice an increase in performance or a smoother sounding engine when I get my baby back on Monday or Tuesday. Wink
jeffro RA28
Tamworth
Re: Carbon clean??? Fri, 24 June 2005 07:47 Go to previous messageGo to next message
I remember seeing some stuff in repco. Cant remember the name but i think it was a NULON product. Suppost to clean out your combustion chambers
Aust162
Melb, Victoria
Re: Carbon clean??? Fri, 24 June 2005 08:28 Go to previous messageGo to next message
Repco have a product called "rocket boost" i think, dont quote me. might be the nulon product your thinking of. its in a tall, skinny aerosol can.
187_20v
Re: Carbon clean??? Sun, 24 July 2005 05:26 Go to previous messageGo to next message
very interesting tread
my car has been pinging sometimes also and not smoooth at times
and now i think after reading this
mayb i got alot of carbon built up in my engine coz mt afm was screwed 4 awhile and i was driving 4 a while with it coz my car was always running very rich and use 2 change the spark plugs and boy did it have heaps of carbon builtup on it HEAPS
gotta try this next weekend
richov8
Hobart, Tasmania
July 2005
Re: Carbon clean??? Sun, 24 July 2005 06:08 Go to previous messageGo to next message
I have been using cabon cleaning for years as a mechanic and the way it operates is it uses a seperate fuel pump in the carbon clean machine which uses a detergent mixed with fuel to clean fuel rails,injectors,valves,pressure regulators,combustion chambers etc. This detergent removes gums and varnishes in injectors, softens carbon within the combustion chambers and when on the machine the operator gives the engine a few revs to blow out the carbon.
Yes it does improve fuel consumption, engine power and overfall driveability but only on a engine with excessive cabon build up.
New engines with low km's will not benefit from the clean due to being internally clean.
The detergent which is mixed with the fuel is fairly expensive $300-350 for 5 litres, the machine is hooked up to the supply line and return line on the fuel rail and the lines which are left hanging are simply plumbed into each other while the clean is being carried out, best to perform with engine at operating temp.
I have personally witnessed a engine which was missing severly and when driven felt like the engine was down on a couple of cylinders, ignition system tested fine and when the clean was carried out the vehicle performed excellent.
blofly
Bunbury
July 2005
Re: Carbon clean??? Mon, 25 July 2005 13:16 Go to previous message
awesome I will be having a fuel system clean done to my 1988 camry ultima with the 3S-FE engine currently getting 330km to a tank of standard unleaded!, at the moment I have just fitted a new cat back system, it is a standard replacement system and already it is all carbed up at the tail pipe! I did a diagnostic check and it tells me it is a code 51 fault which is a problem in the throttle position sensor circuit, but should I try the water mist in the intake of a running engine or throttle body cleaner in the spark plug holes over night before I have the fuel system cleaned?
Previous Topic:1JZ-GTE TT Soarer Exhaust HELP
Next Topic:"bolt on" brake conversion options for FWD/4WD 5 x 100 stud pattern
Current Time: Fri Nov 20 20:35:04 UTC 2026
Total time taken to generate the page: 0.011567831039429 seconds
