Toymods » Tech & Conversions » Thermo fan
Big Rob
March 2005
Thermo fan Fri, 17 June 2005 08:22 Go to next message
Hey everyone. Not long ago I installed a davies craig thermo fan in my GZ20. I used a bosch relay and a davies craig mechanical thermo switch. But due to my lack of auto electrics we just wired both the poisitives straight onto the battery so the thing can turn on all the time. Now while this may be good to prevent heat soak and all, it pisses me off when i'm in a rush and my car alarm goes ue to the fan spinning over. I guess this problem may be solved by the time i finally get a turbo timer but i was thinking i should still try and wire the positive goint to the thermal switch onto the accessories of ignition power.
So i guess my question is where is the best place to find power to the thermal switch?
Thanks guys
Re: Thermo fan Fri, 17 June 2005 09:13 Go to previous messageGo to next message
Fuse box is a good place to start.
Big Rob
March 2005
Re: Thermo fan Wed, 22 June 2005 06:50 Go to previous messageGo to next message
ok thats fair enough to say the fuse box. But...... could you be a littl more descriptive. Where do i bodge power off in my soarers fuse box? I am relativly new to auto electics and just saying fuse box isnt exteemly helpful.
Re: Thermo fan Wed, 22 June 2005 06:56 Go to previous messageGo to next message
Something that has +12V with the key "ON" but not with the key in "ACC" or "OFF"
Big Rob
March 2005
Re: Thermo fan Wed, 22 June 2005 07:46 Go to previous messageGo to next message
so should i just poke around with my multi meter till i find 12 volts. Then bridge the wires?
Re: Thermo fan Wed, 22 June 2005 07:48 Go to previous messageGo to next message
Yeah, thats just for the trigger wire to the relay.
The Power wire just goes straight to the battery, through a fuse.
Big Rob
March 2005
Re: Thermo fan Wed, 22 June 2005 07:54 Go to previous messageGo to next message
thats correct. Just the trigger wire. Currently the trigger wire is right off the battery so it can go off when ever. Can anyone give me an exact location in the fuse box to poke around. If not i'll just have a go.
Thanks guys.
Skip
Re: Thermo fan Wed, 22 June 2005 08:52 Go to previous messageGo to next message
It's not that hard.
Test all the fuses with the ignition OFF, the ones with power scratch them out. Next turn the ign to ACC once again scratch the ones out that light up. Next turn the ign to ON and check the remainders, and find you output.
You can even use an automotive test light, shouldnt take more than 2 minutes.
Big Rob
March 2005
Re: Thermo fan Wed, 22 June 2005 13:35 Go to previous messageGo to next message
ohh, so i should be looking at the fuse box in the kick pannel in the car, or the fuse box in the engine bay. I'm guessing the engine bay.
Re: Thermo fan Wed, 22 June 2005 14:14 Go to previous message
Engine bay will be easier.
Previous Topic:honest opinion
Next Topic:70's Celica and brakeshoes?
Current Time: Sun Oct 18 17:55:19 UTC 2026
Total time taken to generate the page: 0.04914116859436 seconds
