Classifieds » Wheels, Tyres, Suspension and Brakes » AE86/KE70/AE71 parts extravaganza!
IRA11Y
Club Member
AE86/KE70/AE71 parts extravaganza! Fri, 17 June 2005 09:33 Go to next message
guys im selling up.. everything has to go, lots more to add to this list, first with cash takes the goods rule. LOTS OF BARGAINS HERE! heres the list....
Extractors with 2" straight thru exhaust sytem and hi flow turbo muffler ( full car exhaust system) SOLD
front Koni race shocks two way adjustable, recently rebuilt SOLD
rear Koni shocks adjustable SOLD
4.11:1 T series diff centre SOLD
4.3:1 series diff centre SOLD
Jap spec T series Diff housing SOLD
Diff housing with axles and 260mm disc brakes incl new hand brake cables SOLD
front sway heavy duty ( will measure dia. Soon) with new Nolathane bushes SOLD
rear adjustable sway bar 12 - 19mm? As new includes bushes SOLD
2 core radiator full width SOLD
2 x 15" thermo fans SOLD
oil air seperator SOLD
dual coils on single mount 6 months old SOLD
2 x bosch 008 ignitors SOLD
custom quad throttle bodies with adapter plate for bigport and equalization/pulsation dampner SOLD
2 x 272deg x 8mm lift billet cams with heavy duty valve spring set SOLD
4AGE adjustable cam gears SOLD
bigport head, blueprinted,polished and port matched(no cams) SOLD
20V bottom end with 1mm OS high comp pistons, fully rebuilt and fully balanced, hi flow oil pump, blueprinted SOLD
remote oil filter adpater and mount SOLD
Cusco oil cooler SOLD
front lower arms for bigger camber, gives 1-2 deg. extra neg camber, new nolathane bushes SOLD
GX60 front strutts with 280mm x 22mm disc brakes including coil overs with Eibach ( 300lb) springs, new brake lines etc SOLD
rear coilover kit never fitted or used, comes with new Eibach (180lb) springs SOLD
Cusco camber tops with custom spacer for coilovers SOLD
front strutt brace SOLD
rear strutt brace SOLD
AE86 fuel tank with hi flow in tank fuel pump setup SOLD
KE70 6 point roll cage SOLD
350Z Tokico brake master with custom booster SOLD
Willwood Brake Bias adjuster SOLD
AE71 Spirit rear spoiler in silver metalic SOLD
Cobra race seat with rails SOLD
2 x sprinter front seats, fair condition $200
Schroth race harness ( out of date, non cams compliant) SOLD
H4 headlight kit for KE70 $60
Brand new custom flares to suit KE70/AE71 will also fit AE86 SOLD
T50 gearbox (TE72) SOLD
Custom driveshaft to suit T series conversion ( gearbox specific!) AE86 and K/AE7X $100
Short shifter kit for T series box SOLD
Wolf3D V4 ECU with V3 handset come with all the tuning manuals and software SOLD
4AGE 3.2kg lightweight alloy flywheel SOLD
Reduction drive starter motor ( 250rpm) SOLD
Custom rearview door mirrors SOLD
TRD Brass button clutch and TRD HD pressure plate SOLD
4AGE Factory RWD intake manifold SOLD
Adj. Pan Hard rod SOLD
MORE ITEMS FOR SALE
14 x 7 Supra rims with good tread tyres (yokohamas) x4 SOLD
15 x 6 Supra rims with worn Azenis semi slicks x4 SOLD
Brand new pistons for 4age, been balanced $200
small intercooler $100
basic alloy plenium for carbys $50
bare small port head SOLD
semi bare bigport head SOLD
AE86 Steering coloumn $50
AE86 Steering rack SOLD
TE72 (T18) Diff housing, bare with one axle SOLD
will consider selling the engine components as a complete package to anyone interested. Ill accept SOLDfor the engine package complete with the 272 cams, adj. cam gears reduction drive starter and 100amp alternator. Obviously this is the bigport head with the fully balanced high compression 20V bottom end as listed above in unbroken form, its still sitting in the car.
pics of some of the items can be found
http://ira11y.qnix.com.au/4sale/
[Updated on: Fri, 08 July 2005 20:15]
Big T
Re: AE86/KE70/AE71 parts extravaganza! Fri, 17 June 2005 10:25 Go to previous messageGo to next message
pm sent.
Bustin
Tasmania
April 2005
Re: AE86/KE70/AE71 parts extravaganza! Fri, 17 June 2005 12:06 Go to previous messageGo to next message
PM sent...
justin
September_Squall
Melbourne, Australia
March 2005
Re: AE86/KE70/AE71 parts extravaganza! Fri, 17 June 2005 14:23 Go to previous messageGo to next message
PM sent.
marc00013390
vic
Re: AE86/KE70/AE71 parts extravaganza! Fri, 17 June 2005 17:39 Go to previous messageGo to next message
pm sent!
IRA11Y
Club Member
Re: AE86/KE70/AE71 parts extravaganza! Fri, 17 June 2005 21:57 Go to previous messageGo to next message
PM's sent
Rallystanza
Re: AE86/KE70/AE71 parts extravaganza! Fri, 17 June 2005 23:24 Go to previous messageGo to next message
PM sent,
Also will the 2 core radiator fit in a sprinter.
Can i get some pics of it to see where the ins and outs are on it.
Can I have some dimensions of it also.
Condition?
Thanks,
Jezza
no_tofu_speed
Jab what?!!?!
Re: AE86/KE70/AE71 parts extravaganza! Fri, 17 June 2005 23:57 Go to previous messageGo to next message
...I still don't believe I missed out on the camberplates *sob sob sob; wailz*!!!!!!!!!!!
EVOSTi
cambo
      no
Re: AE86/KE70/AE71 parts extravaganza! Sat, 18 June 2005 01:34 Go to previous messageGo to next message
geez some people are gonna make a killing here!
IRA11Y
Club Member
Re: AE86/KE70/AE71 parts extravaganza! Sat, 18 June 2005 02:35 Go to previous messageGo to next message
ok for those that asked for dimensions of the radiator and the cooler here you go...
radiator is W62cm x H47cm x 5.5cm
cooler is W26cm x H15cm x 1"
im trying to get pics up but its hard when im spending the whole day replying to everyones PM's adn getting the parts off the car
IRA11Y
Club Member
Re: AE86/KE70/AE71 parts extravaganza! Sat, 18 June 2005 06:06 Go to previous messageGo to next message
ok heres a link to some pics of some parts that people have requested...
ShiRi
Re: AE86/KE70/AE71 parts extravaganza! Sat, 18 June 2005 10:45 Go to previous messageGo to next message
is the trd clutch and pressure plate been used at all? suit a t50 obviusly
how used are the shocks?
Rallystanza
Re: AE86/KE70/AE71 parts extravaganza! Sat, 18 June 2005 11:04 Go to previous messageGo to next message
Quote:
350Z Tokico brake master with custom booster $300
Was this going into your Ke70?
Can I get some pics of this please.
What is the bore of the master?
More details pls. I need something to suit my sprinter brake upgrade.
Jezza
rick86
Re: AE86/KE70/AE71 parts extravaganza! Sat, 18 June 2005 11:35 Go to previous messageGo to next message
What size are the tyres on the 14 x 7 Supra rims?
Rick.
Re: AE86/KE70/AE71 parts extravaganza! Sat, 18 June 2005 12:00 Go to previous messageGo to next message
you know i'm interested in that flywheel Wink
3.2kg... vs my 9 or 10kg 4K flywheel Very Happy
-Talasas-
Re: AE86/KE70/AE71 parts extravaganza! Sat, 18 June 2005 12:33 Go to previous messageGo to next message
What Compression are the 4AGE pistons?
ShAkEn
adelaide
Re: AE86/KE70/AE71 parts extravaganza! Sun, 19 June 2005 02:03 Go to previous messageGo to next message
pm sent
IRA11Y
Club Member
Re: AE86/KE70/AE71 parts extravaganza! Sun, 19 June 2005 03:12 Go to previous messageGo to next message
replied to you all via PM or check the top for whats still available
mc68
Perth.
April 2005
Re: AE86/KE70/AE71 parts extravaganza! Sun, 19 June 2005 03:35 Go to previous messageGo to next message
havent replied to me Sad
IRA11Y
Club Member
Re: AE86/KE70/AE71 parts extravaganza! Sun, 19 June 2005 03:50 Go to previous messageGo to next message
sorry must have missed you amongst all the PM's, ive sent one now Smile
4ageeza
Adelaide, drift capital
Re: AE86/KE70/AE71 parts extravaganza! Sun, 19 June 2005 04:32 Go to previous messageGo to next message
Could you please pm some pics of the KE70 flares?
Joel
IRA11Y
Club Member
Re: AE86/KE70/AE71 parts extravaganza! Sun, 19 June 2005 06:34 Go to previous messageGo to next message
PM sent
Rallystanza
Re: AE86/KE70/AE71 parts extravaganza! Sun, 19 June 2005 06:35 Go to previous messageGo to next message
Rallystanza wrote on Sat, 18 June 2005 21:04
Jezza
PM me about this pls,
Jezza
IRA11Y
Club Member
Re: AE86/KE70/AE71 parts extravaganza! Sun, 19 June 2005 06:39 Go to previous messageGo to next message
sorry missed that one.. PM sent
Patr1c
Re: AE86/KE70/AE71 parts extravaganza! Mon, 20 June 2005 01:30 Go to previous messageGo to next message
Ira11y
Who built the engine?
IRA11Y
Club Member
Re: AE86/KE70/AE71 parts extravaganza! Mon, 20 June 2005 08:56 Go to previous messageGo to next message
I did patric
IRA11Y
Club Member
Re: AE86/KE70/AE71 parts extravaganza! Fri, 08 July 2005 20:16 Go to previous message
updated
Previous Topic:fs: 2x 17" roh adrenalines
Next Topic:sold.
Current Time: Thu Oct 22 06:54:05 UTC 2026
Total time taken to generate the page: 0.012412071228027 seconds
