Classifieds » Car/Engine Electronics & Audio » AE86/KE70/AE71 parts extravaganza!
IRA11Y
Club Member
AE86/KE70/AE71 parts extravaganza! Fri, 17 June 2005 09:34 Go to next message
guys im selling up.. everything has to go, lots more to add to this list, first with cash takes the goods rule. LOTS OF BARGAINS HERE! heres the list....
Extractors with 2" straight thru exhaust sytem and hi flow turbo muffler ( full car exhaust system) SOLD
front Koni race shocks two way adjustable, recently rebuilt SOLD
rear Koni shocks adjustable SOLD
4.11:1 T series diff centre SOLD
4.3:1 series diff centre SOLD
Jap spec T series Diff housing SOLD
Diff housing with axles and 260mm disc brakes incl new hand brake cables SOLD
front sway heavy duty ( will measure dia. Soon) with new Nolathane bushes SOLD
rear adjustable sway bar 12 - 19mm? As new includes bushes SOLD
2 core radiator full width SOLD
2 x 15" thermo fans SOLD
oil air seperator SOLD
dual coils on single mount 6 months old SOLD
2 x bosch 008 ignitors SOLD
custom quad throttle bodies with adapter plate for bigport and equalization/pulsation dampner SOLD
2 x 272deg x 8mm lift billet cams with heavy duty valve spring set SOLD
4AGE adjustable cam gears SOLD
bigport head, blueprinted,polished and port matched(no cams) SOLD
20V bottom end with 1mm OS high comp pistons, fully rebuilt and fully balanced, hi flow oil pump, blueprinted SOLD
remote oil filter adpater and mount SOLD
Cusco oil cooler SOLD
front lower arms for bigger camber, gives 1-2 deg. extra neg camber, new nolathane bushes $100
GX60 front strutts with 280mm x 22mm disc brakes including coil overs with Eibach ( 300lb) springs, new brake lines etc SOLD
rear coilover kit never fitted or used, comes with new Eibach (180lb) springs SOLD
Cusco camber tops with custom spacer for coilovers SOLD
front strutt brace SOLD
rear strutt brace SOLD
AE86 fuel tank with hi flow in tank fuel pump setup SOLD
KE70 6 point roll cage SOLD
350Z Tokico brake master with custom booster SOLD
Willwood Brake Bias adjuster SOLD
AE71 Spirit rear spoiler in silver metalic $100
Cobra race seat with rails $250
2 x sprinter front seats, fair condition $200
Schroth race harness ( out of date, non cams compliant) $60
H4 headlight kit for KE70 $60
Brand new custom flares to suit KE70/AE71 will also fit AE86 $350
T50 gearbox (TE72) $80
Custom driveshaft to suit T series conversion ( gearbox specific!) AE86 and K/AE7X $100
Short shifter kit for T series box SOLD
Wolf3D V4 ECU with V3 handset come with all the tuning manuals and software SOLD
4AGE 3.2kg lightweight alloy flywheel SOLD
Reduction drive starter motor ( 250rpm) $150
Custom rearview door mirrors SOLD
TRD Brass button clutch and TRD HD pressure plate SOLD
4AGE Factory RWD intake manifold SOLD
Adj. Pan Hard rod SOLD
MORE ITEMS FOR SALE
14 x 7 Supra rims with good tread tyres (yokohamas) x4 $400
15 x 6 Supra rims with worn Azenis semi slicks x4 SOLD
Brand new pistons for 4age, been balanced $200
small intercooler $100
basic alloy plenium for carbys $50
bare small port head $30
semi bare bigport head SOLD
AE86 Steering coloumn $50
AE86 Steering rack SOLD
TE72 (T18) Diff housing, bare with one axle SOLD
will consider selling the engine components as a complete package to anyone interested. Ill accept SOLDfor the engine package complete with the 272 cams, adj. cam gears reduction drive starter and 100amp alternator. Obviously this is the bigport head with the fully balanced high compression 20V bottom end as listed above in unbroken form, its still sitting in the car.
pics of some of the items can be found here....
http://ira11y.qnix.com.au/4sale/]http://ira11y.qnix.com.au/4sale/[/URL
[Updated on: Sat, 02 July 2005 20:06]
Callifo
Gawler, SA
Re: AE86/KE70/AE71 parts extravaganza! Fri, 17 June 2005 11:58 Go to previous messageGo to next message
Custom rearview door mirrors $80 <-- which car and any pics?
IRA11Y
Club Member
Re: AE86/KE70/AE71 parts extravaganza! Fri, 17 June 2005 21:55 Go to previous messageGo to next message
they are not off a car, theyre actually off a bike, if you goto the members rides section and look at ira11y then you will see them in about page 4 on the car, you cant miss them, theyre bright red Smile
IRA11Y
Club Member
Re: AE86/KE70/AE71 parts extravaganza! Sat, 18 June 2005 06:40 Go to previous messageGo to next message
link to more parts and pics added
IRA11Y
Club Member
Re: AE86/KE70/AE71 parts extravaganza! Tue, 28 June 2005 08:09 Go to previous message
updated
Previous Topic:soarer v8 fuel pump
Next Topic:TWO 12"subs in box/ 660watt amp/ wiring kit CHEAP!
Current Time: Wed Oct 14 12:07:05 UTC 2026
Total time taken to generate the page: 0.072706937789917 seconds
