Toymods » Tech & Conversions » Wheel Stud Thread
DigitalAE86
Wheel Stud Thread Fri, 17 June 2005 11:05 Go to next message
Are all wheel studs the same size? Will the lock nuts that fit my MX83 fit most anything else?
ke35 - 4AGZE
Re: Wheel Stud Thread Fri, 17 June 2005 11:16 Go to previous messageGo to next message
i dont think so,
i think manufacturers use different TPI studs.
ae95
Re: Wheel Stud Thread Fri, 17 June 2005 11:29 Go to previous messageGo to next message
wheel stud thread, length and pitch ussually varies from manufacturer and car to car
i know toyo nuts dont fit nissans due to different pitch.
also the angle on the ehad of the nuts needs to suit the rim
ke35 - 4AGZE
Re: Wheel Stud Thread Fri, 17 June 2005 11:35 Go to previous messageGo to next message
yep this i can confirm.
Re: Wheel Stud Thread Fri, 17 June 2005 11:57 Go to previous messageGo to next message
Of course different manufacturers change these things! However, your MX83 locknuts might well be useful on many other TOYOTAs (and the odd mitsubishi Razz )
fester
Gympie Qld
Re: Wheel Stud Thread Fri, 17 June 2005 12:02 Go to previous messageGo to next message
Most jap cars including Toyota are 12 x 1.5mm.
Nissan are 12 x 1.25mm.
Fiat/Lancia and Alfa I think from memoery are also 12 x 1.25mm.
Most big Fords are 1/2"
Most big Holdens are 7/16th.
Normal taper is 60 degrees and "most" mags use this but not all tapers are 60 and some mags use shanks with no taper and some Nissans and Mitsubishis used a combination of shank and taper.
Most standard steel wheels are 60 degree taper as well.
The bottom line is thatyou do have a fair chance of reusing them and it is fairly easy to see if they are correct or not.
Re: Wheel Stud Thread Fri, 17 June 2005 12:09 Go to previous messageGo to next message
Actually, I'm pretty sure that Holden changed to metric when they introduced the Commodore. Oh, the progress!
Re: Wheel Stud Thread Mon, 20 June 2005 00:48 Go to previous messageGo to next message
mrshin wrote on Fri, 17 June 2005 20:09
The amount of times an imperial socket has fit a commodore bolt better than a metric one....
bbaacchhyy
Re: Wheel Stud Thread Mon, 20 June 2005 03:00 Go to previous message
CrUZsida wrote on Mon, 20 June 2005 10:18
Yep, the wheel muts on Crumpledores are 12 x 1.5mm. I know, they fit my Supra !!!
Previous Topic:4AGE Hunting at idle and really high idle.
Next Topic:HEADERS, What order are primary's
Current Time: Sat Oct 24 05:43:58 UTC 2026
Total time taken to generate the page: 0.0094780921936035 seconds
