Toymods » Tech & Conversions » lights dim (ra23)
mkal6
melbourne
lights dim (ra23) Fri, 17 June 2005 13:43 Go to next message
hi guys (and gals)
my headlights (and inside dash lights)dim when i press the horn or the brakes. it is not a heavy drain but its noticeble. dont have any electrical components on it right now. not even a radio. so dont understand why this would happen.
is it something to do with the voltage regulators ?
if im planning to install speakers amps and stuff, would it be recommemded that i change over to falcon alternator (can someone give me the model number ).
by the way, its a ra23
appreciate the input
regards
mo
[Updated on: Fri, 17 June 2005 16:21]
mkal6
melbourne
Re: lights dim (ra23) Sat, 18 June 2005 14:20 Go to previous messageGo to next message
can somebody, anybody tell me y?-(bone thugs)
regards
mo
EldarO
Perth, WA
Re: lights dim (ra23) Sat, 18 June 2005 14:25 Go to previous messageGo to next message
turn the car on, and check the voltage over the terminals with a multimeter
sounds like you alternator is crook.
should be 14 ish volts.
Eldar.O.
ToyT18
Hobart
Re: lights dim (ra23) Sun, 19 June 2005 05:58 Go to previous messageGo to next message
try putting in a different voltage regulator from another toyota with the same plugs as the one already on there and check the voltage over the terminals
ToyT18
Hobart
Re: lights dim (ra23) Sun, 19 June 2005 06:07 Go to previous messageGo to next message
try getting a voltage regulator from another toyota with the same plugs for the wiring and then check the voltage across the terminals after that.
river
Land of Oz
Re: lights dim (ra23) Sun, 19 June 2005 06:09 Go to previous messageGo to next message
If your voltage is that low or the battery is dying then I'd expect your starter motor to be struggling to kick over the engine. Does it?
seeyuzz
river
mkal6
melbourne
Re: lights dim (ra23) Sun, 19 June 2005 06:23 Go to previous messageGo to next message
cant seem to find my voltmeter but should get it checked by tomorrow. the starter is fine. cant seem to see any obvious problem in turning the engine. let me find my voltmeter and lets see what it says
thanks for the response guys
regards
mo
Re: lights dim (ra23) Mon, 20 June 2005 00:12 Go to previous messageGo to next message
RA23's suffer from earthing problems, more so as they get older. Clean up the terminals on existing earth points, and add a few new ones for good measure. You'll be surprised what a difference this will make.
mkal6
melbourne
Re: lights dim (ra23) Wed, 22 June 2005 05:44 Go to previous message
checked with the meter and it read 14.4 volts. so that means the alternator is giving out the right output.
i'll try put norbie recommended and get some effective earthing goin
ne other suggestions guys while im at it
thanks for all the help
regards
mo
Previous Topic:C52 final into a e51
Next Topic:MX83 rear lowering springs
Current Time: Fri Oct 23 21:36:56 UTC 2026
Total time taken to generate the page: 0.0063819885253906 seconds
