Toymods » Tech & Conversions » 4ac running rich
Simon-AE86
Banned user
ADELAIDE - The Drift City
4ac running rich Fri, 17 June 2005 15:07 Go to next message
Just got an AE82 with 4ac power... Prob is it runs rich as and uses a LOT of fuel, when you start it it idles rough before revving up, sounds like its on 3 cylns, but goes fine, it also hunts at idle.
oil and water are fine, doesnt over heat and drives very smoothly appart from the richness. Blows a LOT of black smoke and you can smell fumes...
shinybluesteel
melbourne
Re: 4ac running rich Fri, 17 June 2005 15:13 Go to previous messageGo to next message
sounds broken,
buy another 4AC for 5 bucks.
ViPeR_NiPPleX
VIC, Sth Frankston.
Re: 4ac running rich Sat, 18 June 2005 02:37 Go to previous messageGo to next message
is the choke stuck on? check your idle mixture needle (turn all the way in and back off two turns). Can't think of much else, unless there is a problem with EGR or something :S
Other wise replace carby/motor.
Re: 4ac running rich Sat, 18 June 2005 07:55 Go to previous message
This sort of running is perfectly normal for 4AC's. Spend some time/money on the boring crap like plugs etc., as well as a carb rebuild, and it might improve a bit, for a little while.
Previous Topic:Cold starting problems 100kw 4age
Next Topic:Interesting Master Cylinder - maybe a MA61 upgrade alternative?
Current Time: Mon Oct 19 17:46:32 UTC 2026
Total time taken to generate the page: 0.28166484832764 seconds
