Classifieds » Engines, Accessories and other Mechanicals » Borgwarner Lsd diff suit Ae71/ke70
Kingswood
Hobart, tassie
Borgwarner Lsd diff suit Ae71/ke70 Sat, 18 June 2005 04:58 Go to next message
I have a pair of 45mm dcoe side draft webbers for sale. They are on an L18 datsun manifold but will separate that. Comes with linkages that suit a Datsun 180b but obviously can be modified to fit the application. Also has Trumpets for airfilters but no filters. $450 ono
Borgwarner LSD modified to fit ae71, ke70 and so on, Mitsubishi disc brakes and calipers, including handbrake cables, Back lash needs adjusting but nothing major. Good diff $900ono
Sr20 engine and gearbox mounts to fit an sr into ae71. $200,
got a hole ae71 I am pulling down so just ask if you need parts. Will ship everything i have but you'll have to pay for it.
jpriseman200b@yahoo.com
0418434036 and its Josh
[Updated on: Thu, 30 June 2005 05:35]
Kingswood
Hobart, tassie
Re: 45 mm webbers and assorted ae71 bits Sun, 19 June 2005 03:43 Go to previous messageGo to next message
bump
Mr DOHC
Re: 45 mm webbers and assorted ae71 bits Sun, 19 June 2005 07:36 Go to previous messageGo to next message
what cond are the webers in, need rebuild??
Kingswood
Hobart, tassie
Re: 45 mm webbers and assorted ae71 bits Sun, 19 June 2005 09:49 Go to previous messageGo to next message
No I don't reckon they'd need a rebuild, the seem fine to me. Maybe a bit of detailing on the outside. little bit of surface rust on the trumpets and a tiny bit on the carbies. The butterfly's open and close fine and no fuel leaks.
Kingswood
Hobart, tassie
Re: 45 mm webbers and assorted ae71 bits Mon, 20 June 2005 05:22 Go to previous messageGo to next message
Diff is now $600. No real reason just had a look around and realised they weren't worth as much as I thought.
I haven't received a deposit yet but a person I know said that they would take them, So be quick if you want them.Cause i can't hold them forever.
and no I am not a salesman.
notorius
Sydney, Hurstville, Pensh...
Re: 45 mm webbers and assorted ae71 bits Mon, 20 June 2005 08:25 Go to previous messageGo to next message
would u part with the mounts for sr20 for $120
rollin_stock
February 2005
Re: 45 mm webbers and assorted ae71 bits Mon, 20 June 2005 09:52 Go to previous messageGo to next message
Howdy, can i have a photo of the webers and the manifold pls, also would you send to adelaide, where abouts are you anyway? What are they jetted for?
Cheers Sean
pheonix83
Devonport Tasmania
Re: 45 mm webbers and assorted ae71 bits Mon, 20 June 2005 10:07 Go to previous messageGo to next message
what width is the DIff.
Kingswood
Hobart, tassie
Re: 45 mm webbers and assorted ae71 bits Tue, 21 June 2005 02:59 Go to previous messageGo to next message
Alright guys, both Webbers and engine mounts are sold pending payments. will know by friday. If they don't sell I will repost them up. Not sure on width of diff but i'll measure it, I figure its the same width as a standard ae71 diff.
Kingswood
Hobart, tassie
Re: 45 mm webbers and assorted ae71 bits Tue, 28 June 2005 03:57 Go to previous messageGo to next message
Ok webbers and engine mounts are now sold. I still have the diff for sale. But now it is making some strange noises. I will take $350. will need rebuild. very cheap for a disc to disc lsd that has been modified to Ke70/Ae71 and maybe even fit sprinter just not sure on the that
TA-022
Glenmore Park, NSW
Re: 45 mm webbers and assorted ae71 bits Tue, 28 June 2005 22:58 Go to previous messageGo to next message
width yet?
Kingswood
Hobart, tassie
Re: Borgwarner Lsd diff suit Ae71/ke70 Thu, 30 June 2005 05:39 Go to previous messageGo to next message
the width is 1135mm. no handbrake cables now as i didn't get a chance to pull them out. Comes with lowered spring and nolethane panhard rod bush.
Kingswood
Hobart, tassie
that measurment is disc to disc.
domasik
Re: Borgwarner Lsd diff suit Ae71/ke70 Thu, 30 June 2005 12:35 Go to previous message
r u sure your measuring from the hubb mounting face and not the insides of the discs, a ke55 diff is 1380mm and a ke70 diff is definatly wider than that
Previous Topic:AE86 LSD rear end
Next Topic:Cannon for sale
Current Time: Mon Oct 19 10:56:55 UTC 2026
Total time taken to generate the page: 0.052759885787964 seconds
