Toymods » Tech & Conversions » Busted my motor... 4agte or 3sgte
mr2sc
January 2005
icon3.gif  Busted my motor... 4agte or 3sgte Sat, 18 June 2005 07:39 Go to next message
Hi all,
I have a JDM 4agze aw11. I had the nevo pulley installed and was happish with the power it was making. I have been planning on converting to turbo, now seems like the perfect time to go nuts on it as the motor just shat itself.
The car is in with quickfit motorsport in sydney at the moment.
I am tossing up between rebuilding the 4agze as a 4agte or replacing it with a 3sgte.
Somehow I doubt the 4agte will have the power I am chasing without a motza of money and even then might be a bit laggy.
I want around 200rwk but I want I dont want much lag.
I already have an autronic smc ready to go with whatever combination I end up with.
What are your thoughts?
V8_MA61
Re: Busted my motor... 4agte or 3sgte Sat, 18 June 2005 07:41 Go to previous messageGo to next message
3sgte. No 2 ways about it. Need to make the fucker fit tho! Ask around, maybe theres a kit available?
Re: Busted my motor... 4agte or 3sgte Sat, 18 June 2005 07:53 Go to previous messageGo to next message
If you're able to do it yourself, maybe look at the 3S, but I wouldn't want to have to pay someone to do the 3S job myself. Good condition 4AG with sensible turbo/manifold, and your autronic should do what you want no worries.
mr2sc
January 2005
Re: Busted my motor... 4agte or 3sgte Sat, 18 June 2005 08:33 Go to previous messageGo to next message
I would imagine that rebuilding the 4agze with suitable turbo would be around the same cost as installing a 3sgte. I guess it would depend how much custom work would be required for the 3sgte.
I wasn't really satisfied with the torque of the 4agze even with the pulley upgrade. I cant imagine that you could get more low down torque from the 4a than with that combination.
It could go either way based on your recommendations... Please help!!!
Jorrs
Coffs Harbour
Re: Busted my motor... 4agte or 3sgte Sat, 18 June 2005 15:30 Go to previous messageGo to next message
3SGTE
enough said Wink
peeack
Re: Busted my motor... 4agte or 3sgte Sat, 18 June 2005 15:34 Go to previous messageGo to next message
When you say it shat it's self, what did it do exactly? To give an idea of rebuild cost vs conversion. Anything salvageable from the old GZE?
4agte
Toronto, Downtown
Re: Busted my motor... 4agte or 3sgte Sat, 18 June 2005 17:09 Go to previous messageGo to next message
It depends what you are after....
If you want a quick car at the drags then go 3sgte as it has the best bang for buck you can make close to if not more than 200kw atw with a gen 3 3sgte turbo transplant.
If you want a car that will have a bit more lagg but less wight in the rear then go the 4agte there are people here making 200kw or close too atw and are making acceptable boost by 3k.
I have driven an n/a aw11 and then converted my n/a to a 4agze. The difference in the weight between the 4agze and the 4age may only be about 50kg but boy does it make a huge difference to the handling the rear end becomes nocticbly heavier.
From what i can gather the 3sgte will add another 50kg give or take a few kg (the 3sgte guys might have a different view) to the car it might not sound like much but it makes a huge difference and for me that was enuf to stick with the 4agte.
in my view the 3sgtw will upset the handling too much than a 4agte but it would be uber fast in a straight line being so torquey so i guess its a case of what your after....
Joshstix
Toymods Vice President
Re: Busted my motor... 4agte or 3sgte Sun, 19 June 2005 01:41 Go to previous messageGo to next message
My car handles far better with the 3S in it than it did with the 4A. You can actually use torque to influence the balance of the car and make it do what you want, it's actually more manageable with the 3S.
As to the 3S good for straight line but not for handling I'd advise you to take a look at the results of the MR2 Owners club NA2005 event. This was a US national MR2 event that also invited GT4's and Lotus Elises. The fastest two cars in the auto cross were 3S powered AW11's they were actually ~5 seconds faster on a sub 1 minute course than the fastest SW20 turbo. The fastest car on the road course was also a 3S powered AW11.
As to which is the better conversion, that's really a personal choice. I wanted a 3S because I knew I wouldn't be happy with a 4AGZE, I'd end up turboing a 4AGZE and this would have cost as much as a 3S swap. I really wanted a nice smooth standard Toyota engine that would make 150rwKw on stock management etc. Admittedly that's not what I'm going to end up with now but that's a different story.
mr2sc
January 2005
Re: Busted my motor... 4agte or 3sgte Sun, 19 June 2005 01:56 Go to previous messageGo to next message
Thankx for the replies.
Well there are a few things that would need fixing on the 4a
first up it appears that I have blown the rings. It needs a new starter motor and the clutch is toasted.
I am leaning toward the 3sgte. I have read various articales from other people who have done the swap and it doesn't appear to be overly difficult.
Has anyone had any luck squeazing a slightly bigger turbo in there with the 3s? I don't imagine there would be much room for much.
mr2sc
January 2005
Re: Busted my motor... 4agte or 3sgte Sun, 19 June 2005 02:29 Go to previous messageGo to next message
I think I could sell all the parts of the gze and recoup the cost of buying the 3sgte. This would mean I would only pay for the labour of putting it in. Quick fit seem to have done quite alot of swaps like this so I trust their work wich is important.
Another reason for going 3sgte is that there appears to be many more bolt on parts for them. little things like equal length manifolds and intake gear etc. Nothing is available for the 4agze in the aw11. custom is expensive.
I don't want to upset the handling to much. I will ajust the suspension with the engine swap. I think that if the suspension was setup correctly 50 extra kilos would not upset the car to much. I tend to agree with joshstix that the car would be more controlable with more torque. The battery will be relocated to the front aswell.
Is it worthy to have the autronic installed on the 3sgte to obtain 200rwk? I mean if it wasn't really nessecary then I could sell it and put the money towards the swap.
Thanks for your help!
berad
Re: Busted my motor... 4agte or 3sgte Sun, 19 June 2005 07:14 Go to previous messageGo to next message
id buy a gen 2 3sgte.. use ur autronic ecu... and the other usual mild mods and 200rwkw is achievable... gen 3 will get there easier but will cost a bit more... its all about ur hip pocket
4agte
Toronto, Downtown
Re: Busted my motor... 4agte or 3sgte Sun, 19 June 2005 07:54 Go to previous messageGo to next message
Joshstix wrote on Sun, 19 June 2005 11:41
thats interesting josh.
there was a very noticble difference between the 4age and the gze in regards to the balance of the car..
How much heavier is the 3sgte than the 4age????
4agte
Toronto, Downtown
Re: Busted my motor... 4agte or 3sgte Sun, 19 June 2005 07:59 Go to previous messageGo to next message
mr2sc wrote on Sun, 19 June 2005 12:29
50 kg's more in the rear of the car makes a huge difference to the handling in the aw11 ive found
Joshstix
Re: Busted my motor... 4agte or 3sgte Sun, 19 June 2005 08:51 Go to previous messageGo to next message
To tell you the truth I haven't weighed either the 4A setup or the 3S setup. I have had a variety of different suspension setups in my car including a set of coilovers with pillow ball mounts, the stock setup and also a set of HKS rear struts and strut tops. It handles better with the coil overs and also with the HKS rear struts and stock fronts than it ever did as a 4A.
I did also move the battery to the front and have an additional radiator at the front for the water to air IC so the increase in weight at the back would be reduced considerably.
As for engine options, this si what I really wanted to do to an AW11.
http://img.photobucket.com/albums/v210/vvega/aw11progress002.jpg
mr2sc
January 2005
Re: Busted my motor... 4agte or 3sgte Sun, 19 June 2005 09:17 Go to previous messageGo to next message
I think that v8 idea is one that every aw11 owner would do, money permitting.
Does anyone know if the 3sgte bolts to the supercharged gearbox. I know that people who have done the conversion with the n/a model have used the turbo gearbox with supercharged axles. I thought I read somewhere that the 3s and sc gearboxs are the same??? Obviously using the 3s bellhousing.
Confused
feral4mr2
Bundaberg, Qld.
Re: Busted my motor... 4agte or 3sgte Sun, 19 June 2005 10:13 Go to previous messageGo to next message
4agte wrote on Sun, 19 June 2005 03:09
the 4agze/e51 conversion adds ~100kg over the 4age. cant say i noticed the weight difference when i did mine, all i noticed was the POWA... Wink
mr2sc, here is only one link of many that have done the 3sgte converion in the aw11.
http://www.mr2mk1club.com/turbo.html
and scour this forum
http://www.mr2oc.com/forumdisplay.php?f=58
read, learn and take note from people that have actually done the conversion.
mr2sc
January 2005
Re: Busted my motor... 4agte or 3sgte Mon, 20 June 2005 02:02 Go to previous messageGo to next message
Well it looks like I will be converting to 3s power. The boys in the shop are keen to do it.
I am having difficulty finding a mr2 turbo half cut though. I have tried all the usual places. Anyone know of someone who has got one?
Thankx for your help
Joshstix
Re: Busted my motor... 4agte or 3sgte Mon, 20 June 2005 02:10 Go to previous messageGo to next message
These guys http://www.japimports.com.au/halfcuts2.htm have got a Gen3 half cut listed for $3k. That's a bargain if it's in decent condition.
mr2sc
January 2005
Re: Busted my motor... 4agte or 3sgte Mon, 20 June 2005 02:22 Go to previous messageGo to next message
done and done. Thanks for that. I just rang them then.
mr2sc
January 2005
Re: Busted my motor... 4agte or 3sgte Mon, 20 June 2005 02:23 Go to previous messageGo to next message
One problem. The car has an open diff. I have an LSD in my sc box now.
Any idea what I can do to keep my LSD?
feral4mr2
Bundaberg, Qld.
Re: Busted my motor... 4agte or 3sgte Mon, 20 June 2005 04:01 Go to previous messageGo to next message
the gze e51 is spose to have the same internals as the 3sgte gearbox, if your lucky the lsd you have now will be a straight swap into the 3sgte's gearbox.
Joshstix
Re: Busted my motor... 4agte or 3sgte Mon, 20 June 2005 04:04 Go to previous messageGo to next message
The E153 and E58 are pretty much identical internally.
Ask around on MR2OC if it is possible to swap the diffs. I will warn you though that you have to pull the entire gearbox apart to change the diff, and if you're thinking you may as well give the box a freshen while you're in there I'm pretty sure you can't buy the Gen3 synchro's any more.
mr2sc
January 2005
Re: Busted my motor... 4agte or 3sgte Mon, 20 June 2005 04:53 Go to previous messageGo to next message
josh do you have a lsd fitted to your car?
I wonder if it might be worth it live without it for a little while.
I spose I could always go aftermarket but I have a feeling there pretty expensive.
Joshstix
Re: Busted my motor... 4agte or 3sgte Mon, 20 June 2005 05:51 Go to previous messageGo to next message
Yeah mine is a stock LSD it's really tame until you light the tyres, then it's well sideways.
mr2sc
January 2005
Re: Busted my motor... 4agte or 3sgte Mon, 20 June 2005 06:16 Go to previous messageGo to next message
Not sure how to handle this one. I like a tight lsd. The one in my car now was great.
I might keep looking around for the perfect halfcut I think as I dont want to have to do things twice. That link above was actually for a series 2 motor that had been coverted into an n/a series 1.
I really want the series 3 motor with LSD and I wouldn't mind paying a bit extra for that, so if anyone sees one please let me know.
mr2sc
January 2005
Re: Busted my motor... 4agte or 3sgte Mon, 20 June 2005 06:19 Go to previous messageGo to next message
By the way for anyone who is interested in the parts off my 4agze, they are listed in the for sale section. Very Happy
arasta
brisvegas
Re: Busted my motor... 4agte or 3sgte Mon, 20 June 2005 06:54 Go to previous messageGo to next message
if you did NOT want to do this swap yourself after reading ferals link... well at least you will have an idea of how involved the conversion is. (first link i thought of too)
been around for donkeys but i still feel one of the better resources for a 3sgte into AW11 setup (commonly called a mk1.5 - at least i think thats sensible). personally id like to toy with a beams powered Aw11 so i can keep it NA but that swap is definitely tempting. i guess a Beams 3sge swap is very similar to it tho so i keep the info handy. hope it helps!
[Updated on: Mon, 20 June 2005 06:58]
mr2sc
January 2005
Re: Busted my motor... 4agte or 3sgte Mon, 20 June 2005 07:01 Go to previous messageGo to next message
oooook
4agte
Toronto, Downtown
Re: Busted my motor... 4agte or 3sgte Mon, 20 June 2005 07:42 Go to previous message
feral4mr2 wrote on Sun, 19 June 2005 20:13
thats cause you drive like a girl Razz Laughing Laughing Laughing
Previous Topic:Battery Cutoff Switch
Next Topic:Brisbane
Current Time: Sun Oct 18 22:58:35 UTC 2026
Total time taken to generate the page: 0.0075130462646484 seconds
