Classifieds » Parts Wanted » 3 things to make 18rg complete
mkal6
melbourne
3 things to make 18rg complete Sat, 18 June 2005 13:20 Go to next message
guys i need this parts soon. just wondering if anyones got it lying around their garage
- A manifold
- exhaust manifold/exctractors,
- and an electronic coil
regards
mo
mkal6
melbourne
Re: 3 things to make 18rg complete Sun, 19 June 2005 08:25 Go to previous messageGo to next message
cough:
Steve M
Re: 3 things to make 18rg complete Sun, 19 June 2005 12:32 Go to previous messageGo to next message
When you say manifold, I assume you mean for carbies, right?
If so, I may be able to help of no one else will.
What type do you want, long runner that used rubber tube mounted balance tube or short runner that uses a cast alloy balance tube?
Pacemaker make extractors for 18RG into RA23/RA28.
There are a couple of other companies that do too, but we've had trouble with them cracking a lot.
Pace makers may be to goer there.
As for the electronic coil, get one from a 21RC or a 22RE, I reckon those will do the trick as they are used to convert 18R dizzies to electronic all the time.
I think that a newer (than the celicas) model mitsubishi magna uses a similar coil that can be sourced from repco.
o_man_ra23
Townsville North Qld
icon10.gif  Re: 3 things to make 18rg complete Sun, 19 June 2005 12:55 Go to previous messageGo to next message
I also have both types of intake manifolds available. Electronic coil i can also get, i just use the ones off falcons (i work at a ford wrecker and can get them for free). So, if you want the both of them, i can organise that.
email me O_man_ra23@yahoo.com.au
mkal6
melbourne
Re: 3 things to make 18rg complete Tue, 21 June 2005 01:23 Go to previous messageGo to next message
aight, found a manifold so got 2 more to go
still after extractors, if anyones got them and
electronic coil- was told a mitsubishi ones does the same job- could any one tell me what model/year mistubishi is it off
appreciate the help
regards
mo
o_man_ra23
icon10.gif  Re: 3 things to make 18rg complete Tue, 21 June 2005 11:54 Go to previous message
all depends what type of setup you are running. most electronic setups are resistorless, so in that case, anything the shape that you want (usually a cylinder or the later style resin moulded design) will do. so just about any model ford, holden, mitsubishi, 81-on celica, etc will do the trick. a brand newy can be purchased from your local autobarn or supercheap auto store for around $70.
Hope this helps. your looking... inadvertantly... for one of the most common items in automotive history.
Previous Topic:tt142 engine mounts
Next Topic:4.1 T-Series WANTED
Current Time: Fri Nov 20 22:47:11 UTC 2026
Total time taken to generate the page: 0.0038058757781982 seconds
