Toymods » Tech & Conversions » Whats different between a twin cam AE82 and the CS, CSX ??
rollaboy
Coffs
Whats different between a twin cam AE82 and the CS, CSX ?? Tue, 03 December 2002 13:30 Go to next message
Here are some things i know of.
Hatch lip/wing.
Rear disc brakes.
Macphe. strut is different i think.
Engine
G/box
Interior
What else is there?
juzzo84
Hornsby, N.S.W
icon10.gif  Re: Whats different between a twin cam AE82 and the CS, CSX ?? Tue, 03 December 2002 19:58 Go to previous messageGo to next message
the cs did not have a TACHO, and did not have air con
JUZZO
SW20R
Re: Whats different between a twin cam AE82 and the CS, CSX ?? Wed, 04 December 2002 06:29 Go to previous messageGo to next message
I got aircon factory stock on my CS 1987.
Probably the older plastic gril ones didn't.
CS
Rear are Drums, Front are struts, Bumpers aren't colour coded.
Aircon is optional? Gearbox would probably be the same. No tacho you stuck with a clock Razz A weird green colour dash backlight and a bodgey metal toyota stereo (those old ones where you really have to push in the button for the preset stations and big nobs)
haggis
Re: Whats different between a twin cam AE82 and the CS, CSX ?? Fri, 06 December 2002 05:31 Go to previous messageGo to next message
You may also find that the front disk are diffrent between twin cam and the others. The CS-X has the tacho like the twin cam, the others did not.
Most of the rest is the plastic bits like bumpers, grille etc. The only parts which are not intechangeable are the front parker lamps as late 1985 they changed to a longer version (ie, bigger gap in the wing panel) and the plastic around the rear number plate on the sedans.
Oh yea, and you cant bolt a twincam front sway bar to a sedan, but the holes are there on the CS and CS-X hatches. (i know this cause i want to and found the problem first hand...)
Craig.
flungie
Re: Whats different between a twin cam AE82 and the CS, CSX ?? Tue, 17 December 2002 21:42 Go to previous message
Mechanical difference between T/Cam and CS/X:
- Engine/Gearbox/DriveShafts/Engine Wiring etc.
- Front ventilated & Rear Disc Brakes
- Struts/springs/sway bars
- Front strut top & lower rear braces
- Rear hub assembly
- Fuel pump/Fuel tank baffles/fuel lines
Misc
- Instrument cluster
- Steering wheel
- Rear roof spoiler
- trimmings
Previous Topic:Remote Oil Filter Kit?
Next Topic:ABS switch
Current Time: Sat Nov 21 00:12:40 UTC 2026
Total time taken to generate the page: 0.0063118934631348 seconds
