Toymods » Tech & Conversions » Sprinter strut conversion
TOYBOYEE
Sydney, NSW
February 2005
Sprinter strut conversion Sun, 19 June 2005 06:01 Go to next message
can anyone recommend suspension specialists who can convert my sprinter struts to coilover if i supply all the parts???
i'm willing to freight my struts to wherever necessary aslong as its not overseas...
i tried calling up whiteline and noltec but they said they only manufacture the parts and don't do such conversions...
i'm thinking of buying coilover kit from noltec or fulcrum..
TOYBOYEE
Sydney, NSW
February 2005
Re: Sprinter strut conversion Sun, 19 June 2005 08:10 Go to previous messageGo to next message
bump
berad
Re: Sprinter strut conversion Sun, 19 June 2005 08:12 Go to previous messageGo to next message
fulcrum could probly help you out..
Sam_Q
S.E suberbs, Vic
Re: Sprinter strut conversion Sun, 19 June 2005 11:07 Go to previous messageGo to next message
you dont need a specialist for that job, just go to any fabrication shop, that way you get it done for a sensable price
Re: Sprinter strut conversion Sun, 19 June 2005 13:02 Go to previous messageGo to next message
Buy the kit, and go visit someone with a welder, lathe, etc.
xolent
Re: Sprinter strut conversion Sun, 19 June 2005 13:49 Go to previous messageGo to next message
steve-ae86 apparently does it
devolutio
Re: Sprinter strut conversion Sun, 19 June 2005 14:08 Go to previous messageGo to next message
isn't steve from adelaide or thereabouts? surely there is someone a little closer to sydney who can help this man out!
Sam_Q
S.E suberbs, Vic
Re: Sprinter strut conversion Mon, 20 June 2005 06:57 Go to previous messageGo to next message
what do you need a lathe for? I didnt use one for mine
Re: Sprinter strut conversion Mon, 20 June 2005 07:11 Go to previous messageGo to next message
Noltec in Syd do it and arn't too badly priced.
cri_ag
northern beaches
Re: Sprinter strut conversion Mon, 20 June 2005 09:24 Go to previous messageGo to next message
any one have a link to a bit of a write up on putting coilovers together?
[Updated on: Mon, 20 June 2005 09:30]
takai
Re: Sprinter strut conversion Mon, 20 June 2005 12:29 Go to previous messageGo to next message
http://www.club4ag.com/faq%20and%20tech_pages/Shor t%20Stroke%20Conversion.htm
That should give you a good enough idea. Has some theory in there too.
Re: Sprinter strut conversion Mon, 20 June 2005 14:48 Go to previous messageGo to next message
You don't need a lathe - it just makes life easier, that's all!
TOYBOYEE
Sydney, NSW
February 2005
Re: Sprinter strut conversion Tue, 21 June 2005 03:35 Go to previous messageGo to next message
Sam_Q wrote on Sun, 19 June 2005 21:07
i gave bilstein a call and he quoted me around $280 for shortening the struts, adding spacers etc.. is that a sensible price??
cannonball
Sydney NSW
Re: Sprinter strut conversion Tue, 21 June 2005 03:45 Go to previous messageGo to next message
Just a quick question on spacers, when i had mine made up, they seemed to be just a couple of lumps of stock round bar cut to length, which is OK, but the inserts dont locate as well in the bottom of the tube as the originals, and can move about a mil or two each way. This is with no load on the shock insert. When the top locking ring is tightened up, there is no movement, but the shock could actually be sitting anywhere in that area.
I was thinking of getting some new spacers machined up which snugly fit around the bottom of the insert, so it is located much more positively.
I may be being fussy, but a mil or two movement to one side at the bottom of the tube, means the actual assembled strut/shock has a slight kink between the shock shaft and the strut body, which can effect your wheel alighnment, especially if it shifts under extreme loading.
to those who have 'em, what are your insert spacers like?
Re: Sprinter strut conversion Tue, 21 June 2005 03:51 Go to previous messageGo to next message
Im also interested in this spacer question. I gotta get some made up. Was going to use alloy and get it turned down, but to buy a 60mm by 40mm block of alloy costs a bit.
Sam_Q
S.E suberbs, Vic
Re: Sprinter strut conversion Tue, 21 June 2005 06:57 Go to previous messageGo to next message
I think $280 is a joke, also spacers dont normally need to be run unless your cars unusually high or that your shocks are unusually short. I am using a 120mm shorter stroke and it still could be shorter.
cannonball
Sydney NSW
Re: Sprinter strut conversion Tue, 21 June 2005 07:37 Go to previous messageGo to next message
Im using Tokico short strokes, which are the same size as many other short strokes, and im using a sproonter strut cut down 40mm with a 22mm spacer. This is a pretty common setup, and im interested to se what others use, without getting into the debate of weather one is necessary or not. as that subject has been covered before in club 4AG.
TOYBOYEE..Sorry for Hijacking the thread, i will start another if your not interested in this.
[Updated on: Tue, 21 June 2005 07:38]
Sam_Q
S.E suberbs, Vic
Re: Sprinter strut conversion Tue, 21 June 2005 08:23 Go to previous messageGo to next message
as far as I can tell Tocico's do need a spacer because they are of a really short stroke, all other shocks dont that I know of, well unless your car is like high
Steve-AE86
Ademelaide, SA
Re: Sprinter strut conversion Tue, 21 June 2005 12:08 Go to previous messageGo to next message
i'll do it for $100 if you include postage.
i'll need all parts, including dampers to get the stroke positioning right, and can have them done within a week.
steve
Sam_Q
S.E suberbs, Vic
Re: Sprinter strut conversion Tue, 21 June 2005 20:50 Go to previous messageGo to next message
now thats more like it, go on you Steve
[Updated on: Tue, 21 June 2005 20:54]
TOYBOYEE
Sydney, NSW
February 2005
Re: Sprinter strut conversion Wed, 22 June 2005 07:53 Go to previous messageGo to next message
cannonball wrote on Tue, 21 June 2005 17:37
no not at all... i'm interested in everyone's suspension setup too regarding these shocks...
u may carry on Razz
hehehe
TOYBOYEE
Sydney, NSW
February 2005
Re: Sprinter strut conversion Wed, 22 June 2005 07:56 Go to previous messageGo to next message
Steve-AE86 wrote on Tue, 21 June 2005 22:08
steve
thanks steve... i think i might just take ur offer... if u could ge it done within a week then that'll be much appreciated coz it is my daily driver~!!!!
how many times have u performed this conversion just out of curiousity???
do u have tokico hts shocks on ur car???
i have the shocks and i'll take out the struts from my car... what else do u need to perform the conversion??
Sam_Q
S.E suberbs, Vic
Re: Sprinter strut conversion Wed, 22 June 2005 08:04 Go to previous message
if they are only 60mm shorter then why on earth would u run spacers? I wish mine were 80mm shorter, then they would be ideal.
Previous Topic:I've got some 3t engine questons...
Next Topic:AE93 SX - Lost Fuel Release Catch :(
Current Time: Sat Oct 17 10:53:28 UTC 2026
Total time taken to generate the page: 0.13049697875977 seconds
