Toymods » Tech & Conversions » 20V question - what is this?
Simon-AE86
Banned user
ADELAIDE - The Drift City
20V question - what is this? Sun, 19 June 2005 07:26 Go to next message
http://img236.echo.cx/img236/2927/p10100221wo.th.jpg
What is this and what is it suppose to be hooked up to? sorry about the blurry pic, but im not sure what its suppose to be hooked up to. Defo not coolant, but what?
Takai suggested Idle control valve, but the micortech isnt wired up to is so shall i just block it off?
170bhp
Re: 20V question - what is this? Mon, 20 June 2005 08:25 Go to previous messageGo to next message
Yes, it's the IAC valve, generally most don't use it when using aftermarket computer, easiest way to alter idle spped is to plum in a small adj solenoid into one of the connections on the 'common rail' that feeds all the throttles, the the use the adjustable solenoid to bleed air around the throttles, works fine and gives good idle control, of course make sure your fuel map is ok.
Re: 20V question - what is this? Mon, 20 June 2005 08:30 Go to previous messageGo to next message
FYI the Microtech can be programmed to control it.
I am using one on my 1UZ.
Jonny2TG
Tasmania
Re: 20V question - what is this? Mon, 20 June 2005 13:02 Go to previous message
I have just recieve my 20 valve and am working this out too.
I think the big thing in the middle of your pic is Idle control, as already said. There are 3 wires to the plug. With no power to it, it is just open so needs to be blocked or removed if your not using it. The valve controls extra air from the airbox strait to the ballance tube (bypasses the throttles).
The other electric plug in the right top corner of the picture is (I think, still working out) the charcol canister control valve. There are 4 vacuum lines from the bottom of each throttle all linked. They are all connected to the chracole canister, via some small valves so as not to effect idle too much. When the engine speed is higher (I think..) the electric valve is opened, and the fumes from the charcole canister can flow dirrectly into the ballance tube.
What I call the ballance tube is just the alloy cover the PCV valve goes to. Not really a tube like on my 2T-G, but probably does the same thing.
So I guess for a track car, you just remove everything you see below the throttles there and plug up the holes. But will we have trouble getting the right idle speed? Maybe I can remove the electric idle speed controler, and have a manual screw type one sort of like a crude boost controler, just to control idle.
I wonder how many people have used their Microtech to switch the charcol canister line open? I may give it a go.
Previous Topic:3S dipstick hole/holder?? help please
Next Topic:BLITZ BAG turbos?
Current Time: Fri Nov 20 19:23:52 UTC 2026
Total time taken to generate the page: 0.0061540603637695 seconds
