Toymods » Tech & Conversions » Oil on rocker (?) cover?
Hardcore Celica
May 2005
Oil on rocker (?) cover? Sun, 19 June 2005 07:52 Go to next message
There's fresh oil appearing on the rocker cover seal, nothing huge just a fresh layer everytime i push the engine a little bit. It needs new seals or is it a more complicated affair? (1975 ta22)
river
Land of Oz
Re: Oil on rocker (?) cover? Sun, 19 June 2005 07:57 Go to previous messageGo to next message
Sounds like the gasket may need replacing. Check the bolts are tight that secure the cover. Worse case is the cover is warped, but I don't think it gets that hot to do this.
seeyuzz
river
Hardcore Celica
May 2005
Re: Oil on rocker (?) cover? Sun, 19 June 2005 07:59 Go to previous messageGo to next message
Thanks for the quick reply, will go and check right now.
Hardcore Celica
May 2005
Re: Oil on rocker (?) cover? Sun, 19 June 2005 09:21 Go to previous messageGo to next message
Should the bolts be done up reasonably tight or should i use a torque wrench?
Re: Oil on rocker (?) cover? Sun, 19 June 2005 13:52 Go to previous messageGo to next message
Shouldn't need to be too tight, just firmish. Leave the rattle gun on the shelf...
xolent
Re: Oil on rocker (?) cover? Sun, 19 June 2005 14:01 Go to previous messageGo to next message
instead of wasting another post, i'm also having the same problem. When i go to toyota and buy new seals (for my smallport 4age), do i need to apply the high temp silicone too? Some mechanics even told me that the high temp silicone's are even better than the seal itself... anyone got oppinions/help?
Re: Oil on rocker (?) cover? Sun, 19 June 2005 15:56 Go to previous message
Sticking it on is a good way to stop things leaking, but a whole lot messier when you come to pull it off. It's usually only needed on engines that have crappy pressed tin rattle covers the go all out of shape. Use a new gasket, make sure everythings clean, flat, etc. and you shouldn't have too many issues. If somethings damaged and it won't stop, then break out the goo.
Previous Topic:Diesel conversion ideas - TA22
Next Topic:Shocks from AE82????
Current Time: Fri Oct 23 20:03:53 UTC 2026
Total time taken to generate the page: 0.0042550563812256 seconds
