Toymods » General Car Talk » some ppl just dont know their stuff
b1gb3n
south Melbourne/KL
some ppl just dont know their stuff Sun, 19 June 2005 20:50 Go to next message
here is a msn conversation i had with my fren. pardon the english, its malaysian english. i will have a little dictionary for all as we go along
WWXWW - The art of hand and leg - How I missed it says:
really?
i would have tot that with all the mods that u did u'd expect more increase
esp from xaust n cams
insomniac says:
thats about 12% increase
insomniac says:
increase with cams alone
i tot u did xaust aso? ***aso=also***
n pod filter?
well yeah i guess 10% is ok
10hp sounded a little small but 10% more like it
insomniac says:
as in i got the initial dyno reading after doin exhaust pod filter etc
insomniac says:
i compare the 2 readings
send ur dyno chart n see
insomniac says:
well actually the 10hp increase is the cam gears alone
u gain most where?
insomniac says:
coz initial run also had the cams in already
how much did the dyno cost u?
insomniac says:
dyno n tune $330
oh yeahhhhhhhhhhhhhh u tune asooooo
then u should have got more than 10% quarrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr **quarr=i guess?**
insomniac says:
my car not turbo lar **lar=dude/mate**
insomniac says:
but i got increase tru out the whole rev range
insomniac says:
10HP
insomniac says:
its a 1.6 NA dont forget
yeah but a tune in itself should give u somewhere around 12% increase
+ cams n xaust in tuning expect a little more?
oh well
insomniac says:
depends what u tune la
insomniac says:
if u get fully prog ecu ofcoz
insomniac says:
mine is just cam gears and safc
insomniac says:
i did the initial run after doin cam shafts n exhaust etcc
insomniac says:
he only tuned cam gears and safc
not for xaust?
y not?
insomniac says:
exhaust how to tune??
did u tell him how u wanted it tuned or he just did it for u?
tune ur settings for increased air flow mahhh **mah=dude/mate**
otherwise the settings all still running according to standard flow rates
insomniac says:
dude its modify for increase air flow
insomniac says:
note what TUNE means
hopefully u car won't run rich
insomniac says:
air flow depends on ur engine design dude
insomniac says:
increase air flow needs to change stuff
insomniac says:
this is purely tuning!!
insomniac says:
besides air flow is already good on my engine
yeah but u increased it whatt *this means "didnt u increase it?"*
guess should be ok
how bout torque figures for ur car?
improved a lot?
insomniac says:
how did they TUNE in increase air flow??
insomniac says:
im curious
beacuse engine combustion runs a certain amount
restricted according to how much airflow incoming and outgoing
if u have more air going means u can run more fuel in as well
so if u tune for the increase air flow u can improve performance by burning more fuel quarr
and even on outgoing if u can't output as much burnt products, ur engine won't overdo it quarrr
if got higher capacity for output u can increase if u want quarr
insomniac says:
so how did he TUNE it for that??
program ur ecu to change engine settings!!!
insomniac says:
how can ecu change air flow??
insomniac says:
HOW???
insomniac says:
go find out
insomniac says:
try getting a thermodynamics text book
insomniac says:
u will see that air flow is based on port and angle design
**this thermo and stoich part is just me trying to sound smart and say something he doesnt understand***
change ecu fuel mappppppppppppp
insomniac says:
so how can ecu change the design??
so u can run more fuel into engine
insomniac says:
a car runs on optimum at stoichometric air fuel ratio
insomniac says:
so changing ecu mapping is changing the amount of fuel goin in based one how much air
insomniac says:
the air volume remains constant
if u improve the air flow means u got more air going in rite??
insomniac says:
dont see how u can change air volume unless u change throttle body, piping, exhaust manifold, bigger valves etc...dont see how it can be done by tuning
if u have more air going in and the same amount of fuel u have going in as when u didn't improve air flow, that means the ratio changes
right?
more amount of air is going in during the same period of time now compared to when u didn't improve flow rite?
insomniac says:
so how do u get more air goin in frm tuning??
insomniac says:
ur not making any sense dude
i'm not saying change air flow by tuning
insomniac says:
yes u were
i'm saying change the fuel map by tuning to accomodate the increased aif flow
read what i typed again
insomniac says:
which part?
insomniac says:
u said increase flow frm the start
i said u have increased flow rite?
u told me u added pod filter to ur car and changed xaust rite?
brb tapau food **tapau=takeaway*
***conversation stoped for while and resumed later**
u geddit now?
insomniac says:
u didnt get it
insomniac says:
u said tune for airflow first
insomniac says:
then u change ur story say fuel mapping
yeah i said tune for increased airflow by changing fuel map!!!!!
insomniac says:
changing fuel map doesnt increase air flow
insomniac says:
actually it might
insomniac says:
tuning a car is all about increasing air flow!!
i said u modded ur car to increase air flow rite???
insomniac says:
its like saying the sky is blue
so i said BECAUSE u modded it, u should TUNE for it by CHANGING fuel map
haih...................*haih....=sigh...**
insomniac says:
actually its like the car already has increased air flow, ur tuning the fuel now
insomniac says:
so theoratically tuning refers to the fuel!!
finally u geddit...............................
***WTF!!**
now i can go eat my supper in peace.............
ttyl stomach calling
talk about talking sense into ppl Confused Confused
ae86slaver
Re: some ppl just dont know their stuff Sun, 19 June 2005 23:48 Go to previous messageGo to next message
umm i just read the whole thing - all along i thought u were 'insomniac'?? but it was only until the last 2 lines that i worked out you were 'WWXWW - The art of hand and leg - How I missed it'
hmmm thats my reading for today Confused
Hirogen
Melbourne, Australia
      WTF is a jabber?
Re: some ppl just dont know their stuff Mon, 20 June 2005 00:15 Go to previous messageGo to next message
I don't know who was who...........but my brain hurts, and its nothing to do with the content of that post, just the atrocious perversion of the english language.
acreese
Re: some ppl just dont know their stuff Mon, 20 June 2005 01:05 Go to previous messageGo to next message
Hirogen wrote on Mon, 20 June 2005 08:15
agreed.
b1gb3n
south Melbourne/KL
Re: some ppl just dont know their stuff Mon, 20 June 2005 10:50 Go to previous messageGo to next message
basically wwxxw is saying u can increase air-flow on a dyno tune Confused
insomniac is trying to find out how
MX73_drifter
Re: some ppl just dont know their stuff Mon, 20 June 2005 10:53 Go to previous messageGo to next message
could some1 read it 2 me i can read!!!
rthy
Melbourne - NthSubs
Re: some ppl just dont know their stuff Mon, 20 June 2005 10:58 Go to previous messageGo to next message
me2asonsit
4agte
Toronto, Downtown
Re: some ppl just dont know their stuff Mon, 20 June 2005 10:59 Go to previous messageGo to next message
i couldnt be bothered reading that much crap
Shraka
Re: some ppl just dont know their stuff Mon, 20 June 2005 11:57 Go to previous messageGo to next message
Actualy a car doesn't run at stoich the whole time. It runs lean at low RPM for economy and rich up high to protect the engine.
RA28
Re: some ppl just dont know their stuff Mon, 20 June 2005 12:24 Go to previous messageGo to next message
I think the convo was WX trying to tell insomniac to get a dyno tune after an exhaust upgrade due to the increased airflow from the mod.
I thought a car ran a little lean at the top for more power? like 12-13:1 at peak power? I guess it depends on the fuel and intake temps though.
Tim.
b1gb3n
south Melbourne/KL
Re: some ppl just dont know their stuff Mon, 20 June 2005 18:15 Go to previous messageGo to next message
WX knows jack all about cars. at first he was saying to increase air flow frm TUNING. not adjust fuel, but adjust air
Les
Re: some ppl just dont know their stuff Tue, 21 June 2005 02:03 Go to previous messageGo to next message
u fuggin malaysian, do a FIND AND REPLACE all the nick names on microsoft word so we just get the lines of the conversation..
regards,
fellow malausian
EVOSTi
cambo
      no
Re: some ppl just dont know their stuff Tue, 21 June 2005 02:42 Go to previous messageGo to next message
to those who were talking about a/f ratios:
a car doesnt necesarily run lean on low rpm, its all about load. the car will run lean when on decceleration and rich on acceleration.
ra28, 12-13:1 isnt lean, its rich.
cars will generally run at:
warm engine idle 13-14:1
acceleration 11-12:1
cruise 14-16:1
full power 10-12:1
RA28
Re: some ppl just dont know their stuff Tue, 21 June 2005 04:49 Go to previous messageGo to next message
EVOSTi wrote on Tue, 21 June 2005 12:42
heh... Embarassed I'm going over there now ...bye...
Tim
RobertoX
Re: some ppl just dont know their stuff Wed, 22 June 2005 02:44 Go to previous messageGo to next message
ai yo... Confused
fOOZ86
Re: some ppl just dont know their stuff Wed, 22 June 2005 07:28 Go to previous messageGo to next message
the www guy seemed to be saying in a roundabout way "when you put on an exhaust, cams etc (anything that flows more) you have to program it to inject more fuel and use a bigger spark to get most power possible. I think what he means is that if you don't do this, there's not much point in running more air (better thorttlebody, pipes, exhaust, pod filter etc)
So you're a whiney semantic little bitch who needs to play better with his friends.
Laughing
He never meant "you tune the engine to adjust how much air comes in" even though he may of said it like that, he goes on for the rest of that draining conversation to explain that he means you tune the ecu to optimize this new found airflow (from extractors, and pod filter.) ^_^
b1gb3n
south Melbourne/KL
Re: some ppl just dont know their stuff Wed, 22 June 2005 10:00 Go to previous messageGo to next message
knowing this ww guy, he probably meant tuning for increased air and found out along the way that he was wrong and changed his story Rolling Eyes
fOOZ86
Re: some ppl just dont know their stuff Wed, 22 June 2005 12:56 Go to previous messageGo to next message
Well actually early on in the convo you said you got it tuned for "cams and safc" and not exhaust, and he said why not.
like you got the fuel mapped differently to handle the cams, but not the exhaust, so.. he's more right in this case IMO.
Choony_AE86
Melbourne, South East
Re: some ppl just dont know their stuff Wed, 22 June 2005 16:03 Go to previous messageGo to next message
omg u malaysians are so hard to understand
reading that hurt my head, after all that and reading all the replies i still dont know who is who, ben were u WWXX guy or the insomniac guy?
Choony
another fellow malaysian
b1gb3n
south Melbourne/KL
Re: some ppl just dont know their stuff Wed, 22 June 2005 19:31 Go to previous messageGo to next message
fOOZ86 wrote on Wed, 22 June 2005 22:56
well if exhaust refers to the exhaust system (not cams), how is it possible to tune for the cams and not the exhaust??
fOOZ86
Re: some ppl just dont know their stuff Thu, 23 June 2005 05:41 Go to previous messageGo to next message
No competant tuner would tune for the gains of cams but not exhaust, but, it could be done, you could up the fuel mapping a bit, but not all the way Smile
b1gb3n
south Melbourne/KL
Re: some ppl just dont know their stuff Fri, 24 June 2005 03:01 Go to previous messageGo to next message
isnt fuel mapping tuned based on o2 reading?? so what do u mean by up abit?? as i understand, sometimes its up and sometimes its down unless u have a perfect A/F ratio line, which is quite impossible for us mere mortals
riceburna73
Re: some ppl just dont know their stuff Fri, 24 June 2005 12:43 Go to previous messageGo to next message
Sorry dude but...worst thread ever!
EldarO
Perth, WA
Re: some ppl just dont know their stuff Sat, 25 June 2005 10:27 Go to previous messageGo to next message
riceburna73 wrote on Fri, 24 June 2005 20:43
i concur.
Eldar.O.
bigg willie style
melbourne
Re: some ppl just dont know their stuff Sat, 25 June 2005 11:38 Go to previous messageGo to next message
OMFG @ your conversation!
im no idiot, but that was too fuckin hard to read/understand. i read the first few lines, then gave up. do what les said, and find/replace the names so we only get the convo, its too hard to read with a long bastard msn name like that (you long msn name people get me cut on msn Razz)
ae80
Castle Hill
Re: some ppl just dont know their stuff Sat, 25 June 2005 16:39 Go to previous message
EldarO wrote on Sat, 25 June 2005 20:27
i concur.
Eldar.O.
And ill second that concur!!
Previous Topic:who smashed a celica at willowbank today
Next Topic:New Celica SX-R
Current Time: Mon Oct 26 00:52:17 UTC 2026
Total time taken to generate the page: 0.0059328079223633 seconds
