Toymods » Tech & Conversions » Battery Cutoff Switch
Razor
Battery Cutoff Switch Mon, 20 June 2005 00:01 Go to next message
Hey everyone
How do you install a battery cutoff switch, like a kill switch
but I just want the battery not the fuel pump or ignitor JUST the actual battery.
what do I need? and where can I buy them?
I want a switch that I can mount inside the car.
Re: Battery Cutoff Switch Mon, 20 June 2005 00:17 Go to previous messageGo to next message
So you want to be able to isolate the battery from the system?
Re: Battery Cutoff Switch Mon, 20 June 2005 00:44 Go to previous messageGo to next message
specialist battery shops stock them. I was going to get mine from a place called "all about 12 volts" here in syd, no idea if they're national. in the end, I couldn't be arsed with the cutoff switch.
Razor
Re: Battery Cutoff Switch Mon, 20 June 2005 01:27 Go to previous messageGo to next message
Yes I want to isolate the battery
so I can have a switch to turn it off inside the car if I want to.
I've read that you also connect the alternator so when you turn it off you dont wreck the alternator so the switch has a connection for the alternator.
Dale_ta22
Forster NSW
Re: Battery Cutoff Switch Mon, 20 June 2005 02:33 Go to previous messageGo to next message
The alternator thing sounds like someone who had no idea about auto electronics...
Why would you want to isolate the battery from in the cabin? And why do you need to isolate the battery to begin with?
You can get isolation switches that go ON the battery, it's basically another battery clamp for the +12v.
[Updated on: Mon, 20 June 2005 02:34]
badboybubby
On Probation
Re: Battery Cutoff Switch Mon, 20 June 2005 03:18 Go to previous messageGo to next message
If you wanna drag your gunna need a battery cut off switch It needs to be got at from the outside add a tail shaft loop while your at it Very Happy
sideshow
Re: Battery Cutoff Switch Mon, 20 June 2005 06:40 Go to previous messageGo to next message
the reason for turnin of the alternator is because on new cars these days theres so many relays and crap
and the alternator and some thermo fans when spinin cause a tiny voltage to still run thru the system and its enough to keep relays on even when batt key is off
so by disconnecting alternator at same time as battery the engine will not keep running
this is a common prob on new cars
some battery switches these days have 2 big terminals for bat cable
then 2 or 4 small terminals for coil power so it cuts power to coils and the engine stops
Scootaphill
Geelong, Vic
Re: Battery Cutoff Switch Mon, 20 June 2005 08:09 Go to previous message
Have a look here...
http://www.racerimports.com.au/electrical.htm
It may be what your looking for
phill
Previous Topic:4age crank pulley worries
Next Topic:Busted my motor... 4agte or 3sgte
Current Time: Sun Oct 18 20:00:44 UTC 2026
Total time taken to generate the page: 0.0051031112670898 seconds
