Toymods » Tech & Conversions » 2tgeu/3tgte gasket kits, wats the diffrence
lilcrash
ipswich queensland
2tgeu/3tgte gasket kits, wats the diffrence Mon, 20 June 2005 09:20 Go to next message
wat gaskets come in a 3tgte gasket kit that dont come in the 2tgeu one??
edit : im building a hybrid so im not going to need the 3tgte tappet cover gasket or inlet gaskets neway.
would it be posible/cheaper to rebuild the 3tg bottom end with the 2tgeu gasket kit and just buy any other gaskets/orings that i need??
thanx and laterdays
[Updated on: Mon, 20 June 2005 09:25]
pheonix83
Devonport Tasmania
Re: 2tgeu/3tgte gasket kits, wats the diffrence Mon, 20 June 2005 10:01 Go to previous messageGo to next message
what exactly are you building.
are you building a 2tgte ?
EG a 3tgte with a 2tg crank and pistons.
or are u building a 2tg with 3tgte pistons and crank ?
lilcrash
ipswich queensland
Re: 2tgeu/3tgte gasket kits, wats the diffrence Mon, 20 June 2005 10:26 Go to previous messageGo to next message
i am just putting the 2tgeu head/intake onto the 3tgte block
pheonix83
Devonport Tasmania
Re: 2tgeu/3tgte gasket kits, wats the diffrence Mon, 20 June 2005 10:38 Go to previous messageGo to next message
just need a 2tg VRS Kit.
or if the head is A1 then a headgasket and 2 manifold gaskets.
u can make the thermo gasket from gasket paper.
lilcrash
ipswich queensland
Re: 2tgeu/3tgte gasket kits, wats the diffrence Mon, 20 June 2005 11:12 Go to previous messageGo to next message
will the 2tgeu bottom end gaskets fit, im rebuilding the bottom end while i got it apart
thanx and
laterdays
pheonix83
Devonport Tasmania
Re: 2tgeu/3tgte gasket kits, wats the diffrence Mon, 20 June 2005 11:20 Go to previous messageGo to next message
bottom ends are the same.
only difference is the big end bearings.
what condition are your bores in ?
are you replacing the rings.
as whats the point in stripping and rebuilding it only to have a worn out motor still.
lilcrash
ipswich queensland
Re: 2tgeu/3tgte gasket kits, wats the diffrence Mon, 20 June 2005 11:33 Go to previous messageGo to next message
i will be replacing the rings, bearings and getting a hone done.
wat do u mean by big end bearings?
laterdays
[Updated on: Mon, 20 June 2005 11:34]
pheonix83
Devonport Tasmania
Re: 2tgeu/3tgte gasket kits, wats the diffrence Mon, 20 June 2005 11:36 Go to previous messageGo to next message
big end of the conrods.
lilcrash
ipswich queensland
is there a diffrence in the 2tg head gasjet and the 3tg head gasket. like is the 3tgte gasket thicker of nethin to act as a decompression plate sorta thing??
Jonny2TG
Tasmania
Re: 2tgeu/3tgte gasket kits, wats the diffrence Mon, 20 June 2005 12:39 Go to previous messageGo to next message
From what I know, the compression differences are mostly in the piston tops. Most standard head gaskets are at about 1mm thick.
I think the 2T-GEU, 3T-GTEU head gaskets all work the same. There maybe some very small differences. I have used a 2T head gasket on my 2T-G before, (with other gasket bits and sealant around the timing cover). It worked well. There is a difference in the oil suply hole sometimes. Some gaskets have it as a round hole, some a oval, some a teardrop oval. Cheak the position of the oil suply hole in the block and the head.
Standard gaskets are good for a 86mm bore. If you go over this, you need a custom 89mm gasket.
SRacin
Christchurch, New Zealand
Re: 2tgeu/3tgte gasket kits, wats the diffrence Mon, 20 June 2005 21:19 Go to previous message
I ahve done visual inspection of the two had gaskets and apart from material (which i could not tell any difference with the naked eye) the only difference is the 3tgte head gasket has extra silicon around the oil gallery holes for extra sealing.
You will only need a 2tg gasket rebuild set
Previous Topic:flywheel machining
Next Topic:21/22-RE. EFI setup.
Current Time: Thu Oct 22 22:45:14 UTC 2026
Total time taken to generate the page: 0.0062999725341797 seconds
