Classifieds » Engines, Accessories and other Mechanicals » t-18 diff R31 disc brakes
jesseT18
Castle Hill, Sydney
t-18 diff R31 disc brakes Mon, 20 June 2005 12:08 Go to next message
well my diff is out and i really need some cash
it has
-R31 calipers with brand new brake pads
-R31 rotors
-sway bar mounts
-sway bar
-t-18 axles
pretty much everything you need is there except for the centre
$400 ono
edit- you need 14" wheels or bigger to fit over these brakes
[Updated on: Mon, 20 June 2005 23:28]
Ko Ko
Re: t-18 diff R31 disc brakes Mon, 20 June 2005 22:15 Go to previous messageGo to next message
No Message Body
[Updated on: Mon, 20 June 2005 22:15]
Big T
Re: t-18 diff R31 disc brakes Mon, 20 June 2005 23:15 Go to previous messageGo to next message
These are solid, 260 dia, 10mm thick?
Eddie.
jesseT18
Castle Hill, Sydney
Re: t-18 diff R31 disc brakes Mon, 20 June 2005 23:23 Go to previous messageGo to next message
solid 280mm rotors, not sure how thick off the top of my head
jesseT18
Castle Hill, Sydney
Re: t-18 diff R31 disc brakes Mon, 20 June 2005 23:26 Go to previous messageGo to next message
No Message Body
Attachment: rotos.jpg
(Size: 56.14KB, Downloaded 112 time(s))
Big T
Re: t-18 diff R31 disc brakes Mon, 20 June 2005 23:35 Go to previous messageGo to next message
Just want to confirm that they're 280mm. The dba catalogue lists them as 260mm. Thanks.
Eddie.
jesseT18
Castle Hill, Sydney
Re: t-18 diff R31 disc brakes Thu, 23 June 2005 05:42 Go to previous messageGo to next message
according to my tape measure they are 280mm, i just double checked
Bobski
Re: t-18 diff R31 disc brakes Fri, 24 June 2005 08:29 Go to previous messageGo to next message
any chance u could take a picture of how u mounted the caliper?
thanx
Adam
jesseT18
Castle Hill, Sydney
Re: t-18 diff R31 disc brakes Sat, 25 June 2005 09:05 Go to previous messageGo to next message
now $350 ono
ozboy
Re: t-18 diff R31 disc brakes Sun, 26 June 2005 08:17 Go to previous messageGo to next message
this will bolt int my 22 wont it? also what centre will i need can i get a lsd for it easy?
FKN16V
NSW, East Coast
Re: t-18 diff R31 disc brakes Sun, 26 June 2005 10:42 Go to previous messageGo to next message
ozboy wrote on Sun, 26 June 2005 18:17
It has T-18 axles so lsd very easy to get hold of, there is another group buy gather momentem here http://forums.toymods.org.au/index.php?t=msg&t h=71512&start=0&rid=3118&S=0ad7455a2ee 92fa0626f5573a2e1cf50
Steve
jesseT18
Castle Hill, Sydney
Re: t-18 diff R31 disc brakes Sun, 26 June 2005 12:03 Go to previous messageGo to next message
AFAIK its the same housing as ta22 but heard its 20mm or so wider?
yeah lsd is very easy to find for this diff
the only problem you will have with putting this in a ta22 from my expereice is you will have to drill out the trailing arm holes a little wider on the housing
inark
Re: t-18 diff R31 disc brakes Sun, 26 June 2005 21:55 Go to previous messageGo to next message
i assume this will bolt straight up to a sprinter?
if so can u work out shipping to melbourne? i'll take em off ya hands this week.
Big T
Re: t-18 diff R31 disc brakes Sun, 26 June 2005 23:17 Go to previous messageGo to next message
What's the diff ratio?
EVOSTi
cambo
      no
Re: t-18 diff R31 disc brakes Mon, 27 June 2005 01:44 Go to previous messageGo to next message
Big T wrote on Mon, 27 June 2005 09:17
whatever you want, it has no centre.
inark
Re: t-18 diff R31 disc brakes Mon, 27 June 2005 02:11 Go to previous messageGo to next message
can someone clear this up for me... the center... is what i put into it (as in the kaaz 2way) theres nothing else needed? so the ratio would be set by the LSD? or is that nothing to do with it...
EVOSTi
cambo
      no
Re: t-18 diff R31 disc brakes Mon, 27 June 2005 02:17 Go to previous messageGo to next message
the ratio is determined by the crown wheel and pinion.
jesseT18
Castle Hill, Sydney
Re: t-18 diff R31 disc brakes Mon, 27 June 2005 05:00 Go to previous messageGo to next message
you can put in either a RA40 centre, these come in 3.9 and 3.7 i think, t18 which come in 3.7 and 3.9, or ta22 which are 4.1
or the mechanical lsd to suit the jdm sprinters
i guess i can ship if nobodyu local wants it,
it does bolt up to a sprinter but you also need the rear half of a t-18 tailshaft
SprinterBoy
Re: t-18 diff R31 disc brakes Mon, 27 June 2005 07:12 Go to previous messageGo to next message
PM sent
jesseT18
Castle Hill, Sydney
Re: t-18 diff R31 disc brakes Mon, 27 June 2005 07:17 Go to previous messageGo to next message
and Replied!
Big T
Re: t-18 diff R31 disc brakes Mon, 27 June 2005 09:07 Go to previous messageGo to next message
Sorry if this is a stupid question but do you just use your existing handbrake cables to connect up to the calipers? Or are you supplying handbrake cables as well?
Eddie.
jesseT18
Castle Hill, Sydney
Re: t-18 diff R31 disc brakes Mon, 27 June 2005 12:15 Go to previous messageGo to next message
yeah it comes with handbrake cables. they are custom t18 cables with the R31 fittings at the other end
Big T
Re: t-18 diff R31 disc brakes Mon, 27 June 2005 13:00 Go to previous messageGo to next message
Pm sent
ae86slaver
Re: t-18 diff R31 disc brakes Mon, 27 June 2005 13:04 Go to previous messageGo to next message
Eddie if you are using the T series on the AE86, u can use the stock handbrake cables
September_Squall
Melbourne, Australia
March 2005
Re: t-18 diff R31 disc brakes Tue, 28 June 2005 01:45 Go to previous messageGo to next message
PM sent.
jesseT18
Castle Hill, Sydney
Re: t-18 diff R31 disc brakes Tue, 28 June 2005 10:50 Go to previous message
sold to sprinter boy, pending payment
Previous Topic:Twin JUNK turbo manifold for 1GGTE
Next Topic: MR2/3sgte turbo and 180sx/sr20det and misc parts for sale
Current Time: Thu Nov 19 20:52:35 UTC 2026
Total time taken to generate the page: 0.0083580017089844 seconds
