Toymods » Tech & Conversions » diameter of audio cables
diameter of audio cables Mon, 20 June 2005 23:35 Go to next message
For all the audio nuts out there...
I'm wondering what diameter I should be running to my various speaker. Josh reckons skinny to the sub (maintain strength, lose quality) and thick wires to the fronts (lose strength, maintain quality). The guy who I stole all my wires off obviously did it the other way around.
Does anyone know the answer?
Chris Davey
sunny coast, qld
Re: diameter of audio cables Mon, 20 June 2005 23:58 Go to previous messageGo to next message
I don't think it matters between strength and quality, mainly the current that is being sent along the wire. That is why people usually use larger wires for a sub because they usually receive more power.
In actual fact, unless you are some sort of audiophile, I don't think you could tell the difference. Just make sure they are big enough so that they don't melt!
Re: diameter of audio cables Tue, 21 June 2005 00:02 Go to previous messageGo to next message
I am a bit of an audiophile Embarassed
You're probably right tho, I won't be able to tell the difference with my exhaust and fuel pump to add to the noise.
Re: diameter of audio cables Tue, 21 June 2005 00:34 Go to previous messageGo to next message
12 guage from the amp to the sub.
16 guage from the amp to the front crossovers.
<16 guage from the deck to the rear speakers.
Get a decent pair of RCA's and use a separate trigger wire down the opposite side to the RCA's.
Re: diameter of audio cables Tue, 21 June 2005 01:06 Go to previous messageGo to next message
If you're really concerned about quality, focus on the really important stuff. That said, I'd probably follow Peewees rough size recommendations.
Don't by shit speaker cabling to begin with Razz Make sure your RCA's are good quality and separated from power sources and things which could cause interferece. Ultimately, it will come out very good by proper application of the simple things, but leave the audiophile stuff for home, the environment of a car is about the worst place for music Smile
Re: diameter of audio cables Tue, 21 June 2005 01:08 Go to previous messageGo to next message
yeah, I've already got good quality cabling. the RCAs that came with the cable look very cheap unfortunately, so will have a hunt for some decent ones.
and yeah, ultimately a car's sound system is not going to be ideal, but I still want to do it right, get what I can out of the setup
My advice is, makes sure you have no bad earths!
Re: diameter of audio cables Tue, 21 June 2005 01:09 Go to previous messageGo to next message
Cool1 wrote on Tue, 21 June 2005 09:08
Haha, that too Laughing
Re: diameter of audio cables Tue, 21 June 2005 01:10 Go to previous messageGo to next message
draven wrote on Tue, 21 June 2005 09:08
That's the important bit. Make sure they're up to scratch, and with some thoughtful planning, all should be well. Where are you mounting your amp?
Re: diameter of audio cables Tue, 21 June 2005 01:15 Go to previous messageGo to next message
amp is undecided at the moment. either under my seat, or in the boot near the sub. one of my rear speaker wires is going to have to run next to my battery cable unfortunately, so I'm expecting a bit of degredation back there.
Re: diameter of audio cables Tue, 21 June 2005 01:17 Go to previous messageGo to next message
The Witzl's tips for car audio installations (amplifiers)
  • ALWAYS ALWAYS ALWAYS put a fuse no more than 30cm from the battery on your power cable(s). These fuses are a FIRE protection.
  • use 8 guage power cable for up to 600W, 4 guage for up to 1500W, and 2guage for stupidity, and 1/0 guage for insanity
  • Subs should have SHORT speaker cable runs, with minimum 12guage cable
  • Amplified full range speakers should be wired with 16 guage cable at minimum.
  • RCA cables should be run AS FAR away as possible from any major current carrying cable (ie amp power cable), and high frequency signal carrying wires (ecu). That means RCA cable down one side, and power cable down the other. If the RCA cables HAVE to go near the ECU, wrap that section in alfoil........ doing all this avoids engine noise.
  • amplifier earths have to be the same size as the power cable!!
  • Cable ties and electrical tape are your friends. Learn to use them wisely.
Stay tuned for more imparting of the Witzl's bountiful knowledge and advice. WST's may be involved.
Ultimately you're not going to notice dude, the rears are...in the rear Razz
I've only got rear fill coming from my subwoofer atm, and people always bag it until they get in it Razz
Re: diameter of audio cables Tue, 21 June 2005 01:35 Go to previous messageGo to next message
I listened to just a sub with some fronts. the difference the rear speakers make was HUGE.
Karl - many thanks for that, exactly the sort of info I was after. The amp will have it's own fuse. unfortunately my battery cable from boot to engine bay runs down one side of my car, so 1 speaker cable is going to have to go fairly close to it (5cm away), no way to avoid it.
Re: diameter of audio cables Tue, 21 June 2005 01:37 Go to previous messageGo to next message
draven wrote on Tue, 21 June 2005 09:35
In what car, and how was the sub positioned?
Re: diameter of audio cables Tue, 21 June 2005 01:38 Go to previous messageGo to next message
in a shop, not a car. but the mids bought out parts of the sound taht were totally missed with just front splits and a sub
Re: diameter of audio cables Tue, 21 June 2005 01:40 Go to previous messageGo to next message
I've found that speaker cable can run next to power cable no worries.
RCA cable however needs a good distance.
Re: diameter of audio cables Tue, 21 June 2005 01:43 Go to previous messageGo to next message
cool RCA will not be going near any other cables, except for switches on the centre console.
Re: diameter of audio cables Tue, 21 June 2005 01:50 Go to previous messageGo to next message
jaycar is the place to shop for all the speaker cable, RCA cable and fuses and shit. get some good RCAs.....
Re: diameter of audio cables Tue, 21 June 2005 01:52 Go to previous messageGo to next message
not biased or anything there? Smile
when are you next working? I might try and pop by (do you still work there?)
Re: diameter of audio cables Tue, 21 June 2005 02:18 Go to previous messageGo to next message
i work in head office. I buy the stuff that we sell and you buy.
im not biased, i just dont think you should pay twice the price for 20% more product..... sure Jaycar stuff aint the best, but its a damn sight cheaper than the alternatives - so value for money is uber high.
P.S. i have that new Re'Sponse Precision Class D sub amp.... damn good piece of equipment!! The whole new range of audio gear is actually pretty top shelf in my opinion!
Chris Davey
sunny coast, qld
Re: diameter of audio cables Tue, 21 June 2005 02:43 Go to previous messageGo to next message
Also if you are technically insane by The Witzl's standards you can use welding cable from BOC for amp power and ground. It is a shitload cheaper than stereo places.
Also on that topic, this guy who was putting my windscreen in reckons there is no point having power wire that is thick because the alternator is only about 45amps anyway. What are your thoughts? I was only using 8 guage on the rolla whereas I had welding cable in my Soarer. Personally, I would rather be safe than sorry and end up with melted wire everywhere.
Re: diameter of audio cables Tue, 21 June 2005 03:00 Go to previous messageGo to next message
Most alternators these days are 70A+
And regardless of that, 8guage can handle about 60A constant.
4guage can handle about 110A constant.
If the fuses on your amp are > 50A you SHOULD be running 4guage.
If its only 30A or 40A 8guage is enough.
Also, check the specs on welding wire. I doubt its of the quality of OFC power wire.
Bananaman
Strathfield / Sydney
Re: diameter of audio cables Wed, 22 June 2005 00:07 Go to previous messageGo to next message
Jaycar sell some decent RCA's that actually have a remote wire built in. I found this very convenient Razz
Sadly midway through my wiring i decided to put the amp on a different side of the car from what i originally budgeted cable for, so i had to run my power cabling across the floor to keep it from my RCA's. Its now all complete and done, and no engine hiss, so i'm happy Smile
Re: diameter of audio cables Wed, 22 June 2005 01:08 Go to previous messageGo to next message
Bananaman wrote on Wed, 22 June 2005 08:07
Umm, thats actually a grounding wire, not a trigger wire.
While using this for trigger you *can* introduce a *popping* sound upon startup and turnoff.
I've done it on mine, and have no pop, but I've heard it on others, and moving the trigger wire has solved it.
Chris Davey
sunny coast, qld
Re: diameter of audio cables Wed, 22 June 2005 01:53 Go to previous messageGo to next message
I realised my RCA's had this extra wire after I had already ran a regular signal wire anyway Smile
Mr DOHC
Re: diameter of audio cables Wed, 22 June 2005 11:10 Go to previous messageGo to next message
i have a pair of 6" 2-ways in the corona Confused
Re: diameter of audio cables Wed, 22 June 2005 15:10 Go to previous messageGo to next message
next question: does anyone have a wiring list for the shitpile of wires that come out for the head unit on an ma61? Smile
I guess the only 2 I actually need to know are constant and acc power, and a continuity tester will list those
styler
Re: diameter of audio cables Wed, 22 June 2005 23:03 Go to previous messageGo to next message
the size of wires, ie thickness relates to how many amps they will carry, amplifiers draw low volts and a lot of amps, speakers draw high volts and low amps. speaker wire doesnt need to be super thick but amplifier wire usually does.
8 gauge = about 60a
4 gauge = about 120a
i have a built 2 jaycar setups, all matched components and wires and they went hard. jaycar stuff is so much better than the bling bling crap they sell everywhere else, and cheaper too.
Bananaman
Re: diameter of audio cables Wed, 22 June 2005 23:12 Go to previous messageGo to next message
CrUZsida wrote on Wed, 22 June 2005 11:08
Seem to recall it bing marked as remote wire on the box, not sure. In any case, its working brilliantly for me as a remote wire Very Happy Haven't heard this popping sound you speak of.
Speaking of jaycar gear, i'm using one of the new range of the 4x50wrms amps. Quite happy with it, it is quite good build quality, no complaints about how it sounds, plenty of customisation available, etc. My only comment is that the manual for it had pretty dodgy english. I'm also using the old range of 6x9s, with the adjustable tweeters. I used them before and was very happy, so i went and bought the display ones from my local shop Very Happy
Having said that, i got the amp wholesale via electus (jaycar's wholesale arm) - the retail side may supply a different manual, although i doubt it.
Back to the topic at hand (Wink) If you're using an amp, just grab your multimeter - its quite easy to work out which are your voltages and earth (if you use it and don't make your own). Even if you're not using an amp, its probably wise to run fresh speaker cabling anyway.
Re: diameter of audio cables Thu, 23 June 2005 00:45 Go to previous messageGo to next message
draven wrote on Wed, 22 June 2005 23:10
Yeah, thats it.
Accessories power, and maybe lights input is all you'll really need.
Electric aerial output if you still have one.
For new deck I'd be running another constant power wire and earth, as the current stuff was built to handle about 40watts, where as you will be using over 100.
Re: diameter of audio cables Fri, 24 June 2005 03:27 Go to previous messageGo to next message
josh you ugly homo (or anyone else with a good memory) - what is the colour code of the ACC power for the stereo? I have 2 constant power wires (same colour) but no ACC power as far as I can tell. also anyone know what the "lights" one is? (or do I have to run it myself?)
Re: diameter of audio cables Fri, 24 June 2005 04:35 Go to previous messageGo to next message
# ACC is usually L-R (blue-red)
# ILL is usually G-R or green of some variety
# to the donghead "windscreen installer" who said "big cables are stupid".... why do cars have batteries? When your amp gets a large bass kick or similar, it does not draw power from the alternator.... it draws from the BATTERY!!! The alternator simply charges the battery back up in between these very short bursts of current draw. (do not argue with the Witzl on this one - you will lose).
# Welding cable is teh ghey. Yes it's fat, but not a low voltage drop cable like multistrand OFC copper - hence not ideal.
# The engrish instructions in the new amps are thanks to directly importing these amps ourselves. There isnt much realy needed with an amps instructions other than a diagram of what is what, and a table of specifications. Anything else is "padding"
Chris Davey
sunny coast, qld
Re: diameter of audio cables Fri, 24 June 2005 05:49 Go to previous messageGo to next message
THE WITZL wrote on Fri, 24 June 2005 14:35
Figured as much but couldn't remember the details from my old days as an SPL head Razz
Yeah I figured it isn't the best but it certainly did the job for me. I was running a 4X150rms amp and a 1200rmsX1 amp @ 1ohm so she pulled a bit of current!
Re: diameter of audio cables Fri, 24 June 2005 07:24 Go to previous messageGo to next message
at that current level, welding cable becomes relatively resistive because of its LARGE diam conductors and low strand count..... this means lower voltage at the amplifier, and lower voltage at amplifier = MUCH LOWER POWER!!!!
If you had 2 guage cable, splitting into 4g for each amp ver near by - you would have had a SHITLOAD more power output.....
remember...
Quote:
POWER = VOLTS x CURRENT
So when you are drawing 100A thru cable with no votlage drop, you should have 1380watts.... but if you have a small voltage drop (up to 2.0V is not unheard of) - then you have just 1180watts!!!
Comprehende? Razz
not taking the piss, just trying to impart my bountiful wealth of knowledge again Laughing
Chris Davey
sunny coast, qld
Re: diameter of audio cables Fri, 24 June 2005 07:34 Go to previous messageGo to next message
That's all good mate.
slightly off topic: I am now using this welding cable for my cabling to my battery in the boot. If you had a look at my thread about 1jz with wolf 3d stalling, do you think this could be a factor at all? It was only dropping from 14.6 to 14.2V though.
[/hijack]
Re: diameter of audio cables Fri, 24 June 2005 09:07 Go to previous messageGo to next message
that's not very much drop - but then again, no NORMAL engine has a massive (50A plus) instantaneous/repeatetive current draw!!
The biggest load a normal engine's electrical system will ever see is the starter motor, at around 200-400A.
Re: diameter of audio cables Sun, 26 June 2005 15:23 Go to previous message
A slight aside. While wiring up my speakers, Joorsh happened to hear me mention that I'd thrown out a bunch of useless ma61 black interior parts.
Faster than you can say "desperate scavenger", he dives in headfirst to my bin to recover the treasure.
Here he is, happier than a pig in shit:
http://www.users.bigpond.net.au/draven/car/trash.jpg
Eureka! He found the treasure! (albeit slightly stinky)
http://www.users.bigpond.net.au/draven/car/trash1.jpg
We are a depraved bunch, us ma61 owners.
Edit: sorry for the blurry first pic. I was trying not to piss myself while taking it Smile
[Updated on: Sun, 26 June 2005 15:24]
Previous Topic:1UZFE into AW11?
Next Topic:how to tell what different diff centres look like
Current Time: Thu Oct 15 10:44:59 UTC 2026
Total time taken to generate the page: 0.015037059783936 seconds
