Toymods » Tech & Conversions » Oil Pressure
Pumpkin
Toymods Board Member
icon8.gif  Oil Pressure Wed, 04 December 2002 21:11 Go to next message
I have a 2TGEU that has low oil pressure. Apart from that the engine runs fine.. Would it matter if I put a oil pump from a 3TGTE in it to raise the pressure, or would this damage the engine more?
inferno
Re: Oil Pressure Thu, 05 December 2002 01:12 Go to previous messageGo to next message
I can't see why not... The 3TGTE is basically the same as the 2TGEU, but with a turbo, and since you can run the 3TGTE without a turbo, you should be able to run the 3TG oil pump in the 2TGEU. I would imagine the 3TGTE oil pressure is higher, but that shouldn't hurt the engine.
Goodluck.
Re: Oil Pressure Thu, 05 December 2002 01:55 Go to previous messageGo to next message
If your engine has low oil pressure, it obviously has problems. A larger oil pump is only going to hide the problem, not fix it. Exactly how low are we talking here?
Pumpkin
Re: Oil Pressure Thu, 05 December 2002 03:00 Go to previous message
Thanks for your reply's.
Norbie: The engine is pretty tired, compression is 120psi even on all cylinders. Sad Saying that, it has never let me down and still pulls quite well. Oil pressure is around 25-50kpa on idle and around 250-300 at 3800 rpm. Cold, it will idle at 400kpa. It doesn't blow smoke at all and uses no oil between services (every 5000km's) I know it wont repair the problem, but being Christmas, everybody is miserable and broke, including me! Confused
Previous Topic:RA 40 Bonnets?
Next Topic:4AGE Gaskets
Current Time: Tue Oct 27 00:40:52 UTC 2026
Total time taken to generate the page: 0.0046610832214355 seconds
