Toymods » Tech & Conversions » JZA70 vs MA70 r154 gearboxes
CrispyFries
JZA70 vs MA70 r154 gearboxes Wed, 22 June 2005 02:51 Go to next message
Do the JZA70 r154 gearboxes have a different shifter position to the MA70?
Based on my reading of poombah's site (http://www.supratt.tk) the JZA has a shorter bellhousing than the MA, and a straight gb crossmember, where as the MA has a gb crossmember that angles forward to the bolt holes on the chassis. This combination I think would put the JZAs gearbox about an inch closer to the front of the car than the MA? So if they have the same shifter position, one of them wouldn't come up through the centre of the hole.
I'm currently in the middle of an r154 conversion and I'm noticing that it's coming up right at the back edge of the hole in the tunnel.
Justin
Re: JZA70 vs MA70 r154 gearboxes Wed, 22 June 2005 03:04 Go to previous messageGo to next message
I've never heard of such things.
And if the bellhousing was shorter then the input shaft would vary.
And what about the people that use 5MGE gearboxes on both 7MGTE's and 1JZGTE's, that would suggest that the input shafts are identical.
I'd suggest your problem is due to the xZ20 having a different hole in the floor to the xA70.
Just like the xZ10 has a different hole to the xA61
[Updated on: Wed, 22 June 2005 03:05]
CrispyFries
Re: JZA70 vs MA70 r154 gearboxes Wed, 22 June 2005 03:20 Go to previous messageGo to next message
That's seems reasonable, I'm just going on my observations and what Poombah has on his site.
This image
http://www.supratt.tk/manual_conversion/r154_gearb ox/bellhousings_7mvs1jz_4.jpg
shows what is meant to be a jz bellhousing next to the 7m.
Does the end of the crank shaft of the 7m sit further out relative to the mounting plane of the bellhousing than a jz? That could explain the input shaft issue.
I've never seen a M to W series bellhousing side by side with a JZ to W bellhousing. Are they the same length?
Justin
Re: JZA70 vs MA70 r154 gearboxes Wed, 22 June 2005 03:23 Go to previous messageGo to next message
CrUZsida wrote on Wed, 22 June 2005 13:04
...Just like the xZ10 has a different hole to the xA61
yup - wilbo & I found that 7MGE + W58 with MA61 shifter position requires approx 25mm of metal at front of gearstick hole in an MZ10.
Re: JZA70 vs MA70 r154 gearboxes Wed, 22 June 2005 03:30 Go to previous messageGo to next message
I see your point Crispy.
And no, I haven't seen the W series bellhousings side-by-side.
It is possible that the crank sits further out, but an inch is a lot.
There have been lots of people on here swapping JZ for M bellhousings on the R154, so I highly doubt the input shaft varies.
You have raised an interesting point...
Skip
Re: JZA70 vs MA70 r154 gearboxes Wed, 22 June 2005 03:44 Go to previous messageGo to next message
Maybe that picture shows the 160mm Input Shaft dellow housing like I have on my R151f?
Skip
Re: JZA70 vs MA70 r154 gearboxes Wed, 22 June 2005 03:45 Go to previous messageGo to next message
Then again I can't remember the dellowing housings having as much external webbing Confused
MR 1JZ
Re: JZA70 vs MA70 r154 gearboxes Wed, 22 June 2005 03:59 Go to previous messageGo to next message
I have an MA70 R154 with a JZ bellhousing on my soarer, not a problem lining up, infact i used the stock GB xmember and the shifter lined up perfectly...i cant see why you are having an issue
CrispyFries
Re: JZA70 vs MA70 r154 gearboxes Wed, 22 June 2005 04:08 Go to previous messageGo to next message
Ok, did a little more looking around
Here's a 1jz with auto ring gear The ring gear sits the engine side of the bellhousing mounting face inside a mini housing thing.
Here and here shows the ring gear from my 7m. The ring gear sits inside the auto bellhousing, rather than in a housing on the engine, which the 7m doesn't have.
That by it self doesn't suggest that the gear box would be closer to the front of the car, but combined with the different gearbox crossmembers, the jz shape ___ and the 7m \__/ (though not so exaggerated Very Happy) would put the gearbox closer meaning a possibly different shifter position
Justin
Re: JZA70 vs MA70 r154 gearboxes Wed, 22 June 2005 04:13 Go to previous messageGo to next message
Thet would also explain why the JZ autobox's have smaller bellhousings.
1200det
Re: JZA70 vs MA70 r154 gearboxes Wed, 22 June 2005 05:50 Go to previous messageGo to next message
On my Auto to 5 speed converted MZ21 the Supra MA70 R154 gearbox comes up through the standard floor hole
Re: JZA70 vs MA70 r154 gearboxes Wed, 22 June 2005 06:07 Go to previous messageGo to next message
thechuckster wrote on Wed, 22 June 2005 13:23
As a point of interest, I had to do the same with my MA61 when installing the W58 with MA61 shifter position. I suspect the shifter hole is different between auto and manual cars, but that's just a guess because all three of my MA61's were originally auto.
Re: JZA70 vs MA70 r154 gearboxes Wed, 22 June 2005 06:09 Go to previous messageGo to next message
you're right norbie - on auto MA61s you have to chop an inch or 2 of metal off the front of the position. I've had to do this on mine, and have seen it done on many others. (but not on my original, as it was factory manual)
Norbie wrote on Wed, 22 June 2005 14:07
You sure this isnt something to do with the position of the 2JZ?
Re: JZA70 vs MA70 r154 gearboxes Wed, 22 June 2005 06:10 Go to previous messageGo to next message
Ok, cancel that.
Thats just wierd.
wilbo666
Re: JZA70 vs MA70 r154 gearboxes Wed, 22 June 2005 06:49 Go to previous message
draven wrote on Wed, 22 June 2005 16:09
That is macho interesting!!!! I was just under the impression that the MA61 shifter position was different to the MZ10 one, hmm would appear not! Appears that MA61 may indeed be the correct position and its the fact that all MZ10's were auto (to my knowledge) that made things interesting the other night during the 7mge -> MZ10 transplant...
http://everest.fit.qut.edu.au/~n4150414/MZ10%20%2014-4-2005/MZ10%207mge/tn_DSC01448.JPG
http://everest.fit.qut.edu.au/~n4150414/MZ10%20%2014-4-2005/MZ10%207mge/tn_DSC01450.JPG
Back to the topic of R154 gearboxes, I was under the impression that the shifter position between the JZA70 and MA70 were the same (I don't have first hand experience on this tho however!), however I thought that the JZZ30 was different (further back)...if yours is coming up right at the back is it possible that you have a JZZ30 R154 with the further back shifter position?
Justin
I can check this and get back to everyone.
Previous Topic:3TGTEU - spark timing.
Next Topic:C52 final into a e51
Current Time: Tue Oct 20 06:36:37 UTC 2026
Total time taken to generate the page: 0.0050570964813232 seconds
