Toymods » Tech & Conversions » t series ratios
cooter
perth
t series ratios Wed, 22 June 2005 07:57 Go to next message
hey guys i was wondering if the t series diff came in any ratios higher than 4.11? if so what car are they available from? or do u need to mismatch rings and pinions to get any higher ratios. ive herd of 4.3 but am unsure if its actually posible.
craig
ae86trueno
Re: t series ratios Wed, 22 June 2005 10:35 Go to previous messageGo to next message
4.3 came from some JDM diffs,
thers also
4.7 and 5.1 available from NZ if your desperate
you cant mismatch rings and pinions they only really work as a pair
Ben.
cooter
perth
Re: t series ratios Thu, 23 June 2005 01:05 Go to previous messageGo to next message
ra23celica
Re: t series ratios Thu, 23 June 2005 06:06 Go to previous messageGo to next message
Unconfirmed and likely to be nearly impossible to get however on the YM30 manual 4WD Liteace grey import, the front diff in this is a 6.7 inch T series with a 4.300 ratio.
ae86drift
sydney.au
Re: t series ratios Thu, 23 June 2005 14:24 Go to previous messageGo to next message
3.7, 3.9, 4.1, 4.3, 4.5, 4.7, 4.9, 5.1
Very Happy
also trd makes some ones like 4.6 and 4.8
i think st205 ring gear is the same as t series
andrewvibert
Forum Sponsor
Shepparton (Vic)
Re: t series ratios Thu, 23 June 2005 21:03 Go to previous messageGo to next message
You can add to this 4.6 from a 4wd diesel tarago (front diff) and 5.325 (TRD)
kingmick
Banned by his request
moved to tamworth
Re: t series ratios Thu, 23 June 2005 21:25 Go to previous messageGo to next message
ben who sells the 4.7 and 5,1 in nz?
mick
cooter
perth
Re: t series ratios Thu, 23 June 2005 22:41 Go to previous messageGo to next message
cheers guys that helps heaps
ae86trueno
Re: t series ratios Thu, 23 June 2005 23:31 Go to previous messageGo to next message
kingmick try www.palmside.co.nz
for everyone else i have the AE86 FIA homologation papers at home and there are auctually about 12 different T ratios listed available in lots of small increments to suit any needs.
Ben.
ae86trueno
Re: t series ratios Fri, 24 June 2005 08:36 Go to previous message
For reference here is the list of pinion and ring combinations for T series in toyotas parts inventory
3.308 43/13
3.417 41/12
3.583 43/12
3.700 37/10
3.727 41/11
3.900 39/10
3.909 43/11
4.100 41/10
4.300 43/10
4.556 41/9
4.625 37/8
4.778 43/9
4.875 39/8
5.125 41/8
5.375 43/8
These gears probably arnt available anymore so happy hunting.
Ben.
Previous Topic:Caldina GT-T vs Celica GT4 gearbox/drivetrains???
Next Topic:Distributor & Timing...
Current Time: Thu Nov 19 08:41:34 UTC 2026
Total time taken to generate the page: 0.0047881603240967 seconds
