Classifieds » Engines, Accessories and other Mechanicals » RA23/28 1ggte engine package $1600
Pube
Camden
RA23/28 1ggte engine package $1600 Wed, 22 June 2005 12:14 Go to next message
Some may have seen this advertised before. However no one wanted to buy it. So i have decided to split some of it up and just sell as a basic package which may be more affordable for some now.
Originally from a GX81 Front cut. Package includes:
- Gen 3 1GGTE from GX81
- Front sump
- Stock twin turbos
- New timing belt fitted
- Modified (shortened) intercooler pipe for clearance - throttle body side.
- Manual computer
- Standard wiring harness from GX81 front cut including leads, coil, air flow meter, etc.
- New exedy clutch and heavy duty pressure plate
- Machined flywheel
- W58 gearbox
- TA23 crossmember with 2T mounts repositioned
- Modified 2T mounts on engine
- Stock GX81 Radiator - fits perfectly between RA23/28 chassis rails
- Stock GX81 Front mount intercooler
- Modified GX81 gearbox crossmember
This is basiclly all that is needed to bolt in a 1ggte into an RA23/28. A custom dump pipe needs to be fabricated as the stock cast one dumps straight onto the engine mount. Also included is the tailshaft yoke for a custom tailshaft or maybe there is something out there that is the correct length.
This is the engine. However it will be converted back to standard twin turbos.
http://img.photobucket.com/albums/v307/pube83/102_0576.jpg
http://img.photobucket.com/albums/v307/pube83/102_0578.jpg
http://img.photobucket.com/albums/v307/pube83/102_0580.jpg
Crossmembers:
http://img.photobucket.com/albums/v307/pube83/102_0582.jpg
I can put on a pallet and send Australia wide at buyers expense or can arrange pick up for Sydney residents.
stradlater
Arthurs Creek, Victoria
Re: RA23/28 1ggte engine package $1600 Fri, 24 June 2005 02:53 Go to previous messageGo to next message
I know you have the whole package listed there, but I'll offer you money for the 1g only.. IE no turbos, manifolds, all the bits you can keep, just need the engine. Let me know if your interested. If not, that's cool.
Pube
Camden
Re: RA23/28 1ggte engine package $1600 Sat, 25 June 2005 07:38 Go to previous messageGo to next message
sorry i want to sell the lot. I dont want to be left with bits and pieces that i cant use/sell. Thanks for the interest anyway.
toyrona
April 2005
Re: RA23/28 1ggte engine package $1600 Sun, 17 July 2005 03:37 Go to previous messageGo to next message
if u still have this i want it i sent u a pm
toyrona
April 2005
Re: RA23/28 1ggte engine package $1600 Wed, 20 July 2005 09:13 Go to previous message
sent you another pm
Previous Topic:1JZ/2JZ stuff
Next Topic:Supra 5spd to Holden V8 fitting kit SA
Current Time: Thu Oct 22 13:38:19 UTC 2026
Total time taken to generate the page: 0.015451192855835 seconds
