Toymods » General Car Talk » Delete if you wish moderators, problem solved
Choony_AE86
Melbourne, South East
Delete if you wish moderators, problem solved Thu, 23 June 2005 02:25 Go to next message
Done done done
http://img236.echo.cx/img236/4928/pict00386gv.jpg
http://img87.echo.cx/img87/2200/pict00393rz.jpg
http://img172.echo.cx/img172/7318/pict004058nl.gif
[Updated on: Thu, 23 June 2005 06:08]
ke382TG
Re: What are these parts called???? (PICS) Thu, 23 June 2005 02:41 Go to previous messageGo to next message
1st pic: one is a cold start enrichment (5th injector) temp sensor the other is a temp sensor for the factory ECU (also works with some aftermarket ECU's) can't remeber off the top of my head though which colour does which.
2nd pic: I assume again you are asking about the sensor. Another temp sensor, this one goes to the gauge in the dash.
3rd pic: shocking photo, all I can see is the hole for the dizzy or crank angle sensor (which ever your engine uses)
4agte
Toronto, Downtown
Re: What are these parts called???? (PICS) Thu, 23 June 2005 03:33 Go to previous messageGo to next message
the last picture looks to be the hole for the distributer...
the first one looks to be thermostat maybee could be wrong
Re: What are these parts called???? (PICS) Thu, 23 June 2005 04:26 Go to previous messageGo to next message
ke382TG wrote on Thu, 23 June 2005 10:41
I'm with ^^^^^
Green = ECU temp
Brown = CSI temp
Choony_AE86
Re: What are these parts called???? (PICS) Thu, 23 June 2005 05:31 Go to previous messageGo to next message
thanks guys all solved now
yeh the last one is the hole for the distributor, i was actually after the name for it coz i wanted to buy that gasket, same with the rest, just needed to know the name so wen i order the gaskets i dont sound like a fool Very Happy
But bought some damn expensive but well worth it gasket sealant instead of gaskets Wink
Thanks all
Choony
4agte
Toronto, Downtown
Re: What are these parts called???? (PICS) Thu, 23 June 2005 05:36 Go to previous messageGo to next message
Choony_AE86 wrote on Thu, 23 June 2005 15:31
Thanks all
Choony
what gasket sealant did you buy??
Re: What are these parts called???? (PICS) Thu, 23 June 2005 05:41 Go to previous messageGo to next message
Ummm, in my experience dizzy's dont use gaskets coz you rotate them.
They have an o-ring on the shaft instead.
Could be different for this motor, but its been like that for every motor I've ever worked on.
4agte
Toronto, Downtown
Re: What are these parts called???? (PICS) Thu, 23 June 2005 05:43 Go to previous messageGo to next message
thats correct for the 4age 86kw mr2 and afm gze
Choony_AE86
Re: What are these parts called???? (PICS) Thu, 23 June 2005 06:07 Go to previous messageGo to next message
yep sorry it uses an o ring, i forgot i had that conversation with the guy from Bursons auto parts.
Now i goto bring my dizzy bak so they can give me the correct size o ring Smile
Bought some gasket sealant called "Threebond 1207B" im only saying its good because of its price, $49! *yes im a titeass*
Hopefully my engine is in my engine bay this weekend, wish me luck guys
ke382TG
Re: Delete if you wish moderators, problem solved Thu, 23 June 2005 06:12 Go to previous messageGo to next message
For the housing in pic one that has the two sensors in it I would go to Toyota and get the proper gasket, it's the same gasket for all of the 16 valve 4AGE's. If it leaks it's a khunt to fix while the engine is in the car in RWD format, in my car I would have to lift the engine out to do it as the space is so confined. I would definitely not cut a corner on that one!
Gasket is under $10
ke382TG
Re: Delete if you wish moderators, problem solved Thu, 23 June 2005 06:13 Go to previous messageGo to next message
Oh and in pic 2 the thermostat housing uses a rubber o-ring as well (mine does anyway). The o-ring came with the thermostat.
Maybe you don't need your goo after all
Choony_AE86
Re: Delete if you wish moderators, problem solved Thu, 23 June 2005 06:17 Go to previous messageGo to next message
no! i need my goo!
dont tell me that, im known to waste my money on things i figure i dont need later on Embarassed
ke382TG
Re: Delete if you wish moderators, problem solved Thu, 23 June 2005 06:25 Go to previous message
You will always be able to use the goo later on on other things, trust me
Previous Topic:cheap towing in brisbane
Next Topic:ae92 sx wheels
Current Time: Sat Nov 21 04:38:24 UTC 2026
Total time taken to generate the page: 0.0056858062744141 seconds
