Toymods » Tech & Conversions » oil cooler on 20v 4age
adamaw11
February 2005
oil cooler on 20v 4age Thu, 23 June 2005 02:43 Go to next message
I'm thinking of setting up an oil cooler on my 20v (i've already got the sump with the outlet to put on, and the mount under the filter for this)
I've heard rumors that using an oil cooler can effect the oil pressure, which could make the VVT system function improperly, since it works on oil pressure.
If anyone has put an oil cooler onto a 20v, has there been any oil pressure issues? has the vvt still worked ok?
cheers,
Adam.
-gt-
Nthn Beaches, Sydney
Re: oil cooler on 20v 4age Thu, 23 June 2005 03:11 Go to previous messageGo to next message
I'm running one, it's lifted the oil pressure a little, maybe just from cooler temps hence higher density? My pressure was fairly low at idle without it though.
It won't cause any problems at all. I'd only worry about the vvt if your pressure got really low, but you've probably got bigger problems by then anyway and shouldn't be running it, let alone revving it.
adamaw11
February 2005
Re: oil cooler on 20v 4age Thu, 23 June 2005 03:53 Go to previous message
Ok, cool, that sounds good if it can actually raise the oil pressure a little.
Your reply has put me at ease, thanks Smile
Previous Topic:3TGTE Vacuume Diagram
Next Topic:HELP! Opinions needed...
Current Time: Sat Oct 17 16:06:35 UTC 2026
Total time taken to generate the page: 0.0090618133544922 seconds
