Toymods » Tech & Conversions » 4inch MAGIC Cat ( Anyone used )
1200det
4inch MAGIC Cat ( Anyone used ) Thu, 23 June 2005 06:55 Go to next message
Just wondering if anyone has used or read much in regards to the MAGIC Cat converters ?
http://www.synthetic-engine-oils.com/toymods/7b_1_b.jpg
http://www.synthetic-engine-oils.com/toymods/37_1_b.jpg
http://www.synthetic-engine-oils.com/toymods/df_1_b.jpg
[Updated on: Thu, 23 June 2005 06:57]
4agte
Toronto, Downtown
Re: 4inch MAGIC Cat ( Anyone used ) Thu, 23 June 2005 07:28 Go to previous messageGo to next message
the editor of zoom used one in his 7mgte soarer.. was making i thinks 250rwkw with the standard cat. once fitted with the magic cat they were able to wind more timing into it and made about 280kw atw's from memory...
Re: 4inch MAGIC Cat ( Anyone used ) Thu, 23 June 2005 07:43 Go to previous messageGo to next message
what is the catalyst supported by? what catalyst are they using? what is the mesh like? (ie can you see directly thru, or is there a mangled air path (albeit small deviations)?
does it actually do the job of a catalytic converter? (ie light-off time, temp at cruise etc)
more timing? so less boost (ie chamber pressure)? cooler intake temps? cooler combustion temps?
[Updated on: Thu, 23 June 2005 07:45]
Re: 4inch MAGIC Cat ( Anyone used ) Thu, 23 June 2005 09:23 Go to previous messageGo to next message
The article in Zoom makes them SOUND like a good thing - but who knows what the reality is... Why not call them up, see if they'd be willing to offer some kind of money back gaurantee, and get someone to set it up on a flowbench, maybe in comparison to whatever cat you use now. That way, you'd be more likely to get your money back than if you actually put it on your car, and measured the pressure drop.
YelloRolla
On your mum!
Re: 4inch MAGIC Cat ( Anyone used ) Thu, 23 June 2005 09:31 Go to previous messageGo to next message
Call Magic and ask what the difference was on the flow bench (it will at least give some idea to the flow difference).
Matt (proprietor of Magic) is well versed in performance and measuring the gains (he does have a 10sec RA23 Celica) and I am sure that he will be able to disseminate any information that you may need in regards to any product that he sells.
1200det
Re: 4inch MAGIC Cat ( Anyone used ) Thu, 23 June 2005 11:12 Go to previous messageGo to next message
I ended up buying one and ill put it to the test and see how it goes Smile
Guess no-one here has one themselves ?
M.W.P.
Rocky Mountains, Canada
Re: 4inch MAGIC Cat ( Anyone used ) Thu, 23 June 2005 18:10 Go to previous messageGo to next message
I wonder if RTA inspection would recognise it as a cat... they might think its just a resonator or somthing.
4agte
Toronto, Downtown
Re: 4inch MAGIC Cat ( Anyone used ) Thu, 23 June 2005 21:46 Go to previous messageGo to next message
YelloRolla wrote on Thu, 23 June 2005 19:31
they quited the cfm for each different type of cat and a straight 3 inch pipe i thik from memory it was somewhere arround the 750cfm mark whereas a 3" was about 550cfm i thinks
in any case it flowed alot better than a 3" cat aparantly...
[Updated on: Thu, 23 June 2005 21:47]
1200det
Re: 4inch MAGIC Cat ( Anyone used ) Thu, 23 June 2005 22:15 Go to previous messageGo to next message
I ended up buying a couple and ive got one for sale at $280 + post
4"pipe straight through pipe - 1629cfm
4" MAGIC cat - 750cfm
3" pipe straight through pipe - 1152cfm
3" supercat - 469cfm
3" supercat - 524cfm (revised version)
As written in Zoom.
Chris Davey
sunny coast, qld
Re: 4inch MAGIC Cat ( Anyone used ) Fri, 24 June 2005 02:29 Go to previous messageGo to next message
how many people have 4" exhausts?
Are you going to use reducers to connect to the current exhaust?
1200det
Re: 4inch MAGIC Cat ( Anyone used ) Fri, 24 June 2005 02:44 Go to previous messageGo to next message
Well the older design were cut off at 4 inch pipe although this newer design is actually reduced down to a few mm off 3 inch to allow a direct welding of 3 inch pipe
4agte
Toronto, Downtown
Re: 4inch MAGIC Cat ( Anyone used ) Fri, 24 June 2005 03:36 Go to previous messageGo to next message
Chris Davey wrote on Fri, 24 June 2005 12:29
yeah you use a reducer
1JZ.747
Osama's hideout
Re: 4inch MAGIC Cat ( Anyone used ) Fri, 24 June 2005 05:59 Go to previous message
M.W.P. wrote on Fri, 24 June 2005 04:10
thats easy solved, the epa wave a heat wand undere your exhaust before and after the cat, they will see a vast drop in temp after the cat as the cat retains heat to burn the bad gases.
they dont need to look through it.
have seen the test done.
Previous Topic:4agze jdm spec wiring
Next Topic:1JZ Engine Mount Question
Current Time: Thu Nov 19 09:44:24 UTC 2026
Total time taken to generate the page: 0.015305042266846 seconds
