Toymods » Tech & Conversions » Blocking plate for electric fuel pump on a 2TB Celica TA23 engine ??
stevenvandecauter
Belgium
Blocking plate for electric fuel pump on a 2TB Celica TA23 engine ?? Thu, 23 June 2005 07:25 Go to next message
Hi all,
I would like to put an electric fuel pump in place of the old mechanical one, reason is the crankcase gets contaminated with fuel (I mean heaps, liters !!), and I guess this is due to the fuel pump.
I found a new 30 GPH @ 2-4 PSI fuel pump, would this do the trick, please ?
Also, I wonder if I would nead a blockoff-plate or just leave the old fuel pump in place and mount the thing directly on the old mechanical one, just as a pass-through ??
Thanks in advance for your answers !
Re: Blocking plate for electric fuel pump on a 2TB Celica TA23 engine ?? Thu, 23 June 2005 07:36 Go to previous messageGo to next message
definitely take old pump out and fit a cover plate.. otherwise it'll be hammering away and will eventually make noise and be nasty.. passing fuel thru it will also be not so good.. depending on pump design.
ideally, you will get a pump that is self regulating (or can't make any more pressure) to 2-3psi.. the volume doesn't matter so much... as long as it can pump maybe 50-60 litres/hr it will be heaps.
rip off the mech one, cover it up, place new pump near the fuel tank, and you are set Smile.. remember to wire up pump so it turns off Wink
Grega
melbourne.victoria.austra...
Re: Blocking plate for electric fuel pump on a 2TB Celica TA23 engine ?? Thu, 23 June 2005 11:07 Go to previous message
i used a cover on my 2T years ago from an 18RGEU motor.
i'm pretty sure they're all the same anyway
Previous Topic:3tgte oil hole??
Next Topic:Powder Coating Rims
Current Time: Thu Oct 22 19:46:05 UTC 2026
Total time taken to generate the page: 0.0046322345733643 seconds
