Toymods » Tech & Conversions » 3tgte oil hole??
lilcrash
ipswich queensland
3tgte oil hole?? Thu, 23 June 2005 08:35 Go to next message
ok i have a 3rd hole for oil on my thermostat housing, what is it sposed to be used for?? i have got a pic of a 3tgte with an oil cooler connected to the hole but i cant see where the other side goes in to the enigne so im guessing it isnt stock.
ne ideas??
laterdays
YelloRolla
On your mum!
Re: 3tgte oil hole?? Thu, 23 June 2005 09:19 Go to previous messageGo to next message
Some of them came with an additonal outlet from the oil filter cast aluminium thingy (banjo fitting on the under side of where the filter lives) That line can be plumbed to an oil cooler and then back into the banjo fitting at the thermo housing.
I currently have that line blocked off on my car and I have a larger sump capacity (that facilitates oil cooling by design).
lilcrash
ipswich queensland
Re: 3tgte oil hole?? Thu, 23 June 2005 09:25 Go to previous messageGo to next message
so is the hole on the thermo housing a in or a out hole??
CLG
Perth, Western Australia
Re: 3tgte oil hole?? Thu, 23 June 2005 10:13 Go to previous messageGo to next message
On the thermostat housing there is facility for both "in" and "out" holes! We all know 3TGTE's came equipped with either an oil cooled turbo (mainly found in the 1982 models), or a water cooled turbo (mainly the 1983 models). The oil cooled turbo units were also given an oil cooler to assist with this job.
The oil cooler is controlled by a thermostat - it only flows oil when the oil is hot enough to open the thermostat. This thermostat is located in line by the sandwich plate at the oil filter. While bypassed, the oil supply for the turbocharcger bearings is fed through the steel pipe, around the front of the engine, and into the oil feed line, byt the thermostat. When the oil heats up, that steel pipe is blocked off, and the oil is routed through the oil cooler line to the oil cooler.
From the cooler it is then fed back to the turbo oil feed line through the thermostat. Also present at these junctions is an oil temp sensor too.
lilcrash
ipswich queensland
Re: 3tgte oil hole?? Thu, 23 June 2005 10:19 Go to previous messageGo to next message
hmmm im still confused
does neone have a pic of the oil filter thing where the oil goes through a thermostat??
Grega
melbourne.victoria.austra...
Re: 3tgte oil hole?? Thu, 23 June 2005 11:04 Go to previous messageGo to next message
crash - from another thread a few posts down :
http://img99.echo.cx/img99/4643/thing4xn.jpg
lilcrash
ipswich queensland
Re: 3tgte oil hole?? Thu, 23 June 2005 11:06 Go to previous messageGo to next message
awesome thank you
laterdays
Grega
Re: 3tgte oil hole?? Thu, 23 June 2005 11:09 Go to previous messageGo to next message
thank jackel dude
http://forums.toymods.org.au/index.php?t=msg&t h=71944&start=0&rid=664&S=8ddcc8341c7a f35ae26a6d6add8ade22
jackel
Re: 3tgte oil hole?? Thu, 23 June 2005 11:11 Go to previous message
no problemo Very Happy
Previous Topic:T-18 brake upgrade
Next Topic:Blocking plate for electric fuel pump on a 2TB Celica TA23 engine ??
Current Time: Tue Oct 20 01:07:04 UTC 2026
Total time taken to generate the page: 0.004979133605957 seconds
