Classifieds » Engines, Accessories and other Mechanicals » quad throttle ram tubes suit weber/solex/dellorto
Mr DOHC
quad throttle ram tubes suit weber/solex/dellorto Thu, 23 June 2005 12:11 Go to next message
i have a set of ram tubes to suit a quad throttle engine, they fit weber, solex, dellorto, efi throttles, probably 4AGE ITB's too.
fit upto 48mm
tubes in perfect condition, socks need a clean
send me offers
http://img266.echo.cx/img266/6634/p10100029sw.jpg
tubes can be bead blasted at buyers request
Mr DOHC
Re: quad throttle ram tubes suit weber/solex/dellorto Thu, 23 June 2005 12:12 Go to previous messageGo to next message
the reason i am getting rid of them is they are the wrong lenght to suit my cam/manifold setup
Mr DOHC
Re: quad throttle ram tubes suit weber/solex/dellorto Sat, 25 June 2005 08:33 Go to previous messageGo to next message
ok, more details
they are 60mm high,
OD of sock is 95mm, sock is 105mm long
once assembled can be as shor as 110mm, or 140mm, all socks have springs inside so they dont get sucked inwards,
offers
Mr DOHC
Re: quad throttle ram tubes suit weber/solex/dellorto Sun, 26 June 2005 06:54 Go to previous messageGo to next message
pics
http://img205.echo.cx/img205/9357/img77779vs.jpg
http://img205.echo.cx/img205/3994/img77767cy.jpg
the below pic shows the minimum height they can be,
http://img205.echo.cx/img205/5751/img77754sr.jpg
below pic show the max height they can be
http://img205.echo.cx/img205/7510/img77749hf.jpg
psychofox
Wollongong, NSW
Re: quad throttle ram tubes suit weber/solex/dellorto Sun, 26 June 2005 11:04 Go to previous messageGo to next message
What's the distance between the bolt holes? I just want to check if they will fit on my 4AGE 20V Quads...
fester
Gympie Qld
Re: quad throttle ram tubes suit weber/solex/dellorto Sun, 26 June 2005 12:04 Go to previous messageGo to next message
Psychofox, the bolt spacing of weber style ram tubes does not match the 20 valve mounting. The 20 valve is further apart so you have to elongate the holes or cut the ends off through the holes so you can use the nut and a washer to just clamp them on.
Mr DOHC, what is the diameter of the base of the ram tube. ie at the flange end where it bolts to the carby not the sock end.
Mr DOHC
Re: quad throttle ram tubes suit weber/solex/dellorto Sun, 26 June 2005 12:28 Go to previous messageGo to next message
the bolt hole spacing is exactly 65mm
the outer dia is 65mm as well, inner is 46mm, not 48 as previously stated
Mr DOHC
Re: quad throttle ram tubes suit weber/solex/dellorto Mon, 27 June 2005 06:16 Go to previous messageGo to next message
brand new they retail for $350
looking for $150
ae86 Drifter
newcastle
Re: quad throttle ram tubes suit weber/solex/dellorto Mon, 27 June 2005 07:08 Go to previous messageGo to next message
so these dont suit 20v
Mr DOHC
Re: quad throttle ram tubes suit weber/solex/dellorto Mon, 27 June 2005 07:13 Go to previous messageGo to next message
i dont know, ask the ppl above, they may know, might be able to fit them
psychofox
Wollongong, NSW
Re: quad throttle ram tubes suit weber/solex/dellorto Mon, 27 June 2005 22:20 Go to previous message
20v is 75mm between the bolt holes. So unless you slot the holes, it doesn't suit 20V quads.
Previous Topic:Is this a decent price for sidedrafts?
Next Topic:FS:Stock Supra TT Fuel Pump
Current Time: Thu Nov 19 08:41:28 UTC 2026
Total time taken to generate the page: 0.0054140090942383 seconds
