Toymods » Tech & Conversions » 3tg/2tg dizzy/ignition on boost??
lilcrash
ipswich queensland
3tg/2tg dizzy/ignition on boost?? Thu, 23 June 2005 21:47 Go to next message
ok i am building a hybrid 3tg/2tg turbo engine and am just wondering wat ppl have done about the distributor. i have heard that i will need to retard the timing but am unsure of a solution.
what has everyone else done to fix this problem??
thanx
[Updated on: Thu, 23 June 2005 22:22]
Grega
melbourne.victoria.austra...
Re: 3tg/2tg dizzy/ignition on boost?? Fri, 24 June 2005 10:11 Go to previous messageGo to next message
crash from what i understand the dizzy retards/advances ignition by the diaphragms on the side of it.
are you going to run an aftermarket ecu or stock?
YelloRolla
On your mum!
Re: 3tg/2tg dizzy/ignition on boost?? Fri, 24 June 2005 10:18 Go to previous messageGo to next message
The 3T GTE uses a diaphragm that both advances with vacuum and retards with boost. Maybe you can adapt that vacuum canister into position on the 2T G distributor.
To completely solve the ignition problem, I changed my car to run coil per plug set up and igniton can be tailored however the engine best likes it.
lilcrash
ipswich queensland
Re: 3tg/2tg dizzy/ignition on boost?? Fri, 24 June 2005 22:25 Go to previous message
hey, i am going to be running a haltech fuel only ecu. and yes i have considered the 3tgte diaphragm into the 2tge dizzy but no one has one and u cant buy them new for sum stupid reason. if sumone has access to one i would be hapy to buy it.
other then that all i can think of is goin to a ignition control or sumthin but im not sure wat one to use.
laterdays
Previous Topic:Nova to Corolla conversion help?
Next Topic:how to take out AE86 lower arm? [need help]
Current Time: Thu Nov 19 06:20:18 UTC 2026
Total time taken to generate the page: 0.0048661231994629 seconds
