Toymods » Tech & Conversions » ma61 wiring Q
ma61 wiring Q Thu, 23 June 2005 23:45 Go to next message
can anyone tell me what this is I'm holding? for some reason it has +ve power in, a stupid mixture of wires underneath, and eventually just has 2 +ve lines out - what was wring with something a lot more simplified?
]http://www.users.bigpond.net.au/draven/car/pic.jpg
Re: ma61 wiring Q Thu, 23 June 2005 23:55 Go to previous messageGo to next message
Fusible link.
Re: ma61 wiring Q Fri, 24 June 2005 00:15 Go to previous messageGo to next message
thought so. any idea on the rating of that fuse?
HyDrA
Adelaide, SA
Re: ma61 wiring Q Fri, 24 June 2005 00:27 Go to previous messageGo to next message
Not off hand - but I do know that wire caused me a bit of pain when the power to the car kept dropping out.
(the wire was all crusty and broken inside.)
[Updated on: Fri, 24 June 2005 00:27]
Re: ma61 wiring Q Fri, 24 June 2005 00:47 Go to previous messageGo to next message
100A I think ???
Check the TSRM
Re: ma61 wiring Q Fri, 24 June 2005 01:01 Go to previous messageGo to next message
ah crap. I was hoping to remove the need for that whole ugly black thing, but not if I'm going to need a 100A fuse
Re: ma61 wiring Q Fri, 24 June 2005 01:10 Go to previous messageGo to next message
http://www.cygnusx1.net/supra/library/TSRM_MKII/e/ E_003.html
Re: ma61 wiring Q Fri, 24 June 2005 01:54 Go to previous messageGo to next message
replace them with fuses. I loathe fusible links.....
bbaacchhyy
Re: ma61 wiring Q Fri, 24 June 2005 03:21 Go to previous messageGo to next message
CrUZsida wrote on Fri, 24 June 2005 10:40
But that doesn't tell you what the rating of the fusible link is though ?
Last time I was at the wreckers, I grabbed a handful from a variety of donor RA65's. Very Happy
BTW, the black fuse cover on JB1 has the same decal as that used on the RA65. So now my car also has one of these Very Happy
Re: ma61 wiring Q Fri, 24 June 2005 03:30 Go to previous messageGo to next message
bbaacchhyy wrote on Fri, 24 June 2005 11:21
It probably does mean something, you just have to decipher it.
82MKII
Re: ma61 wiring Q Fri, 24 June 2005 04:45 Go to previous messageGo to next message
Talk to your friendly auto electrician.
Mine made up a new lead from the alternator (for when I finally install the 1J) with a smaller and hardly noticeable fusible link in it. It is rated at 100A and barely larger than the diameter of the cable it is soldered to.
Peter
Re: ma61 wiring Q Fri, 24 June 2005 06:55 Go to previous messageGo to next message
THE WITZL wrote on Fri, 24 June 2005 11:54
replace them with nails.
Fixed.
Re: ma61 wiring Q Fri, 24 June 2005 07:10 Go to previous messageGo to next message
GT, i could slap you.....
Witzl's Fuse Replacement Guide
http://www.twincam.org/forums/uploads/post-20-1119597104.jpg
Re: ma61 wiring Q Fri, 24 June 2005 07:11 Go to previous messageGo to next message
gianttomato wrote on Fri, 24 June 2005 16:55
Fixed.
But don't forget to add one of these:
http://www.koogansafety.co.uk/images/foam_fire_extinguisher.gif
[Updated on: Fri, 24 June 2005 07:12]
Re: ma61 wiring Q Fri, 24 June 2005 09:53 Go to previous messageGo to next message
what could possibly be drawing that much power? starter motor, amp and head unit are all powered directly from the battery, which leaves coil packs and headlights as aboiut the only other majhor things the battery is powering. 100A seems total overkill.
and since the coil packs are running through my (fused) ECU, if anything goes wrong there that fuse will blow.
Re: ma61 wiring Q Fri, 24 June 2005 10:57 Go to previous messageGo to next message
Don't forget it protects the factory alternator which is 65A + spiking.
bbaacchhyy
Re: ma61 wiring Q Fri, 24 June 2005 11:20 Go to previous message
THE WITZL wrote on Fri, 24 June 2005 16:40
Um, can I order one of the 243Amp units. How much incl postage ?
I am not sure that the slow blow is correctly rated. Isn't the M10 1,482 Amps, not the long M12 ? Wink
Previous Topic:how to take out AE86 lower arm? [need help]
Next Topic:ST185 Stereo wire diagram (need to do an install)
Current Time: Thu Nov 19 06:38:29 UTC 2026
Total time taken to generate the page: 0.011979818344116 seconds
