Toymods » Tech & Conversions » Distributor & Timing...
BootySlap
Distributor & Timing... Fri, 24 June 2005 05:59 Go to next message
Took the distributor out of my 4AGE today to replace a seal and can only remember roughly the position of where the rotor was facing.
When I put the distributor back in, if the gears are off by a few teeth of where they should be, is this still ok ? Can I just adjust the timing by adjusting the dizzy bolts or do I have to turn the crankshaft pulley etc like in the manual ?
[Updated on: Fri, 24 June 2005 06:00]
Re: Distributor & Timing... Fri, 24 June 2005 06:17 Go to previous messageGo to next message
Gear HAS to be on the right tooth.
BootySlap
Re: Distributor & Timing... Fri, 24 June 2005 07:25 Go to previous messageGo to next message
Crap... ive put it back on and everything seems fine and I cant seem to hear any pinging... will this be ok until I get timing checked ?
Re: Distributor & Timing... Fri, 24 June 2005 07:32 Go to previous messageGo to next message
It won't run if its one tooth out.
BootySlap
Re: Distributor & Timing... Fri, 24 June 2005 08:08 Go to previous messageGo to next message
Wow I must be damn lucky then to get it back on the right tooth. I dont have a timing light to check the timing and im worried about damage to the engine if my timing is too advanced. Im not too sure what 'pinging' sounds like but everything 'seems' to sound normal. I dont know if at idle the sound of my engine is its normal tapping noise or if it sounds bad because im listening too hard.
Re: Distributor & Timing... Fri, 24 June 2005 08:12 Go to previous messageGo to next message
She should be right.
Just set it where you think it was before hand.
A couple of degrees in either direction wont matter.
Check it when you can though.
Celica_John
Re: Distributor & Timing... Fri, 24 June 2005 08:15 Go to previous messageGo to next message
I think if you've changed your timing your idle will also change. Is it idling any higher than before?
Also if its too advanced it will ping under load so that means pedal to the metal and tick tick tick.
BootySlap
Re: Distributor & Timing... Fri, 24 June 2005 08:31 Go to previous message
Thanks guys, idle seems as per usual and I'll test it out on the freeway tomorrow... I should invest in a timing light I think !
Previous Topic:t series ratios
Next Topic:4agze jdm spec wiring
Current Time: Thu Nov 19 09:37:12 UTC 2026
Total time taken to generate the page: 0.0060830116271973 seconds
