Toymods » Tech & Conversions » ST185 Stereo wire diagram (need to do an install)
amosite
ST185 Stereo wire diagram (need to do an install) Fri, 24 June 2005 06:08 Go to next message
I did a quick search but couldnt find much except
for people paying other people to do it.
If you have done it yourself and know of a wire diagram,
please let me know as I would like to have a fricken radio/cd player ASAP.
Its pretty boring driving without one.
Toobs
Re: ST185 Stereo wire diagram (need to do an install) Fri, 24 June 2005 06:11 Go to previous messageGo to next message
If you still have the factory loom with the plug attached go and grab yourself a loom adaptor to suit "Fujitsu Ten" stereo's installed in Toyota vehicles.
Using these saves you from having to chop your factory loom and also come with clearly labelled wires in standardised colours.
Trust me... its worth hunting around for one.
-==L=a=N=c=E==-
Brisbane, Queensland
Re: ST185 Stereo wire diagram (need to do an install) Fri, 24 June 2005 06:38 Go to previous messageGo to next message
Have you got the 'System 10' or just eh standard tape player?
I've got wiring diagrams here if you need them.
FWDCelica
sydney,nsw.oz.
Re: ST185 Stereo wire diagram (need to do an install) Fri, 24 June 2005 06:56 Go to previous messageGo to next message
Toobs wrote on Fri, 24 June 2005 16:11
Yep !
Super Cheap Auto sell em. About $20. Saves cutting/splicing into the original loom.
Or check out http://www.installdr.com/Harnesses/Toyota-Wiring.p df
Re: ST185 Stereo wire diagram (need to do an install) Fri, 24 June 2005 07:15 Go to previous messageGo to next message
or for those who arent daunted by the task of testing the wires.... all you need is a multimeter and a 9V battery.
amosite
Re: ST185 Stereo wire diagram (need to do an install) Fri, 24 June 2005 07:18 Go to previous messageGo to next message
Its a Jap import. I think they have a duel CD/cassett looking at the double Din gap (any suggestion on how to block it?)
Im not sure if this is a "System 10"
Which wire diagram/Fijitsu 10 do I need?
I might lean towards the adaptor if it has 15cm or so of length
amosite
Re: ST185 Stereo wire diagram (need to do an install) Fri, 24 June 2005 07:20 Go to previous messageGo to next message
THE WITZL wrote on Fri, 24 June 2005 17:15
haha.
Not daunted. Just wont have the time on the weekend for it. Looking for the quickest install as possible.. Wink
I think the car has tweeters near the mirrors, but they are not shown on this link?
[Updated on: Fri, 24 June 2005 07:25]
Toobs
Re: ST185 Stereo wire diagram (need to do an install) Fri, 24 June 2005 08:46 Go to previous messageGo to next message
If it has tweeters they will just be split by a little crossover cap from the midbass driver.
There will not be a seperate set of wires going to the stereo just for the tweeter.
Just get the "Fujitsu Ten" type loom adaptor from Repco, Supercheap or whoever sells them near you and you're ready to rock n roll!
I got mine from Repco and it was actually a Fujitsu ten to ISO adaptor... I just cut the ISO connectors off and wired my Pioneer loom up to it.
ZZT231
melbourne.vic.au
Re: ST185 Stereo wire diagram (need to do an install) Fri, 24 June 2005 09:06 Go to previous messageGo to next message
To block the hole (Din) get a Toyota Din Pocket from any wrecker. I got mine from the Camry but also a few other Toyotas have them... Don't pay any more then AUD$10 for it. In AutoBahn they are around AUD$40 *I think*
Cheers.
BlackGT4
February 2005
Re: ST185 Stereo wire diagram (need to do an install) Fri, 24 June 2005 09:16 Go to previous message
hi, i wired mine following all this info i found on a google search back when i did mine. i used a multimeter to make sure i got the power wires right tho.
TOYOTA Top of page
P o w e r
Memory (+12v Constant) Blue/Yellow
Ignition (+12v Switched) Gray
Ground (-) Brown
Illumination Green
Dimmer White/Green
Power Antenna Black/Red
S p e a k e r s
Right Front (+) ------Light Green
Right Front (-) ------Blue
Left Front (+) -------Pink
Left Front (-) -------Violet
Right Rear (+) -------Red
Right Rear (-) -------White
Left Rear (+) --------Black
Left Rear (-) --------Yellow
[Updated on: Fri, 24 June 2005 09:19]
Previous Topic:ma61 wiring Q
Next Topic:Caldina GT-T vs Celica GT4 gearbox/drivetrains???
Current Time: Thu Nov 19 07:00:43 UTC 2026
Total time taken to generate the page: 0.0069680213928223 seconds
