Toymods » Tech & Conversions » AFR Help
monkeymajik
AFR Help Fri, 24 June 2005 06:45 Go to next message
I'll try to keep this short.
I have a 4agte running the AFM gze management. <6months ago when the conversion was just completed, we used a wideband o2 sensor to setup the boost on road. We had it set at 1.1-1.2bar with safe to rich afr's (around 11:1 on full boost)
Yesterday the car was put on a dyno dynamics dyno to setup the hiperboost boost controller, the only things that have changed since the last time was shorter intake piping, a different BOV and the hiperboost.
Initially we were getting crazy lean (25:1 on boost!) readings, this was due to the pipe that the o2 sensor sits in being too small for the exhaust. We then changed to a bigger pipe and things were more normal.
But this time the most i could dial in was about 10.X psi at about 130rwkw without it spiking when the boost builds? (12:1 AFRs on full boost)
Is this a descrepency between o2 sensors? Are my injectors dirty/shagged? What could be causeing this?
any help appreciated.
[Updated on: Fri, 24 June 2005 06:47]
Chris Davey
sunny coast, qld
Re: AFR Help Fri, 24 June 2005 07:36 Go to previous messageGo to next message
Could it be due to a dyno not having the "real" load on the engine as if it is actually pulling its own weight at speed?
I know in the US they tune their cars slightly richer to compensate for the extra load but their dynos are slightly different to ours.
monkeymajik
Re: AFR Help Fri, 24 June 2005 13:59 Go to previous messageGo to next message
Wouldnt it be leaner on the road then? This was richer on the road :S
Chris Davey
sunny coast, qld
Re: AFR Help Fri, 24 June 2005 22:47 Go to previous message
whoops Embarassed Got nothing then. Razz
Previous Topic:Hilux hub on RA60 strut
Next Topic:Nova to Corolla conversion help?
Current Time: Thu Nov 19 04:13:40 UTC 2026
Total time taken to generate the page: 0.063657999038696 seconds
