Toymods » Tech & Conversions » SC vs Turbo -- Emissions
acreese
SC vs Turbo -- Emissions Fri, 24 June 2005 06:50 Go to next message
I have been searching the internet / forums (working hard today!)
Trying to find out,
Given An identical engine and all other params (boost, fuelling, temps etc..) being equal
Would a Supercharged or Turbo Charged version produce the lowest emissions?
Adam
Henn
Rosanna, Melb
Re: SC vs Turbo -- Emissions Fri, 24 June 2005 06:57 Go to previous messageGo to next message
In my opinion (and I am happy to be proved wrong by someone more learned) the emissions should be identical. If everything really is identical then you get the same air going into cylinder, same AFR, same combustion and so same emissions.
However the turbo car would be quieter so less noise emission if you count that.
Hen
rob_RA40
c'town, NSW
Re: SC vs Turbo -- Emissions Fri, 24 June 2005 07:00 Go to previous messageGo to next message
SC and TC are both compressors they do the same thing just in a different manner.
acreese
Re: SC vs Turbo -- Emissions Fri, 24 June 2005 07:24 Go to previous messageGo to next message
Right,
now the reason that i asked.
I applied to add F/I to my engine.
With turbo option, all I need is brakes and my car can be registered legally (no eng cert required - as stated in response to mod request from D.P.I)
However with SC (all other things being equal) they require me to get an Emissions test.
I submitted two individual requests (I was baffled)
-Adam
Re: SC vs Turbo -- Emissions Sat, 25 June 2005 06:06 Go to previous messageGo to next message
Reason being past habbits. Traditionally, and to the rego people, a supercharger means 6/71 and a couple of 4 barrels hanging through the bonnet, whereas turbo is one of those litle noisy things from those little gutless jap motors that can't possibly make any smog. Quite up with the times, aren't they!
However, there IS a little bit of truth in what they say - positive displacement blowers DO tend to blow unburnt charge straight through the motor during overlap at low revs, increasing HC emissions. Unfortunately, while doing this, they tend to give a big serve of bottom end torque... Therefore, you need to do a certain amount of fiddling with valve and fuel timing to clean this up, and they probably want to make sure you get this right. What do they say about centrifugal blowers?
shinybluesteel
melbourne
Re: SC vs Turbo -- Emissions Sat, 25 June 2005 06:11 Go to previous messageGo to next message
well a supercharged engine would tend to use more fuel (when you are caning it) as the turbo utilises the exhaust energy to drive the compressor, wheras the supercharger uses crankshaft power.
not that you get power for free with a turbo, it still takes engine power to drive, but not as much as a supercharger.
4agte
Toronto, Downtown
Re: SC vs Turbo -- Emissions Sat, 25 June 2005 07:02 Go to previous messageGo to next message
shinybluesteel wrote on Sat, 25 June 2005 16:11
a supercharger will tend to use more fuel when your not canning it unless youve set it to come on at a certain throttle position or load ect ect and thats assuming your using an electronic clutch....
you are constantly boosting a s/c car when driving arround town to get away from traffic lights etc etc
bored
Re: SC vs Turbo -- Emissions Sun, 26 June 2005 05:50 Go to previous messageGo to next message
4agte wrote on Sat, 25 June 2005 17:02
Unless you have a bypass valve, like most modern positive displacement superchargers do (look at eaton for example). Such superchargers do not require much power to run when the engine is not under load.
inertia
Re: SC vs Turbo -- Emissions Sun, 26 June 2005 06:20 Go to previous messageGo to next message
I am in a similar shitty situation with my 4AGZE AE92... having to get engineering and probably an emissions test... we'll see... might need to move states lol Shocked
4agte
Toronto, Downtown
Re: SC vs Turbo -- Emissions Sun, 26 June 2005 07:16 Go to previous messageGo to next message
bored wrote on Sun, 26 June 2005 15:50
i still think you will find that it soaks up the petrol
acreese
Re: SC vs Turbo -- Emissions Mon, 27 June 2005 01:26 Go to previous messageGo to next message
mrshin wrote on Sat, 25 June 2005 14:06
I am not sure, I did not ask about this, as I don't know where to get one cheap enough Razz
-Adam
Allan
Re: SC vs Turbo -- Emissions Mon, 27 June 2005 02:05 Go to previous messageGo to next message
typicaly a hoter exhaust with a turbo thus the cat gets its job done better
Joshstix
Toymods Vice President
Re: SC vs Turbo -- Emissions Mon, 27 June 2005 02:23 Go to previous messageGo to next message
Allan wrote on Mon, 27 June 2005 12:05
The opposite of this is generally the case. The fact that you have a big hunk of cast steal in the exhaust path up near the head that soaks up a huge amount of heat means that the gas after the turbo is cooler and it take longer for the cats to light off.
On the other hand any supercharged engine where there is valve overlap will end up with unburnt fuel air mix going through to the exhaust, whereas if it is turbo this does not happen because the pressure in the exhaust ports is higher than the pressure in the intake ports.
Allan
Re: SC vs Turbo -- Emissions Mon, 27 June 2005 02:30 Go to previous messageGo to next message
hmmmm debateable, the higher pressures seen outside of the combustion chamber on the exhaust side tend to also see higher temps pre cat (also more fuel tends to get burnt before reaching the cat
Joshstix
Re: SC vs Turbo -- Emissions Mon, 27 June 2005 02:50 Go to previous messageGo to next message
Debate it with Garrett then since that's where the info comes from.
This is one of the biggest things that Garrett have been working on, along with VATN and 48V turbo's, in order to keep the turbo relevant to future OEM emissions standards. There is a lot of research into lighter materials and also in methods to increase the temperature of the gas after the turbo.
The fact is that the hardest part of an emissions test for a turbo engine to pass is the initial startup. The turbo takes a long time to heat up and this reduces the temperature of the exhaust gasses. If you think that the pressure in the exhaust manifold at startup due to a turbo exhaust housing and turbine wheel will increase the temperature of the exhaust gas then I guess you subscribe to a different form of physics to most people.
Allan
Re: SC vs Turbo -- Emissions Mon, 27 June 2005 02:52 Go to previous messageGo to next message
hmmm defeintly at startup your right im thinking more along the lines of cruise
Joshstix
Re: SC vs Turbo -- Emissions Mon, 27 June 2005 03:15 Go to previous messageGo to next message
Fair enough. Yeah the emissions tests are all realtively easy for a turbo engine to pass except for the initial startup tests.
inertia
Re: SC vs Turbo -- Emissions Mon, 27 June 2005 08:31 Go to previous message
On a side note, anyone know if a MAP 4AGZE passes ADR37/00 ? Confused
Previous Topic:MZ20 running too rich?
Next Topic:TROOPY TO DYNA - 4WD RUNNING GEAR same year? is it possible?????
Current Time: Fri Nov 20 21:10:34 UTC 2026
Total time taken to generate the page: 0.0071480274200439 seconds
