Toymods » Tech & Conversions » Balancing Flywheels (warning: massive pics)
Big T
Balancing Flywheels (warning: massive pics) Fri, 24 June 2005 08:27 Go to next message
Hey all. Just curious as to how many times you can balance a single flywheel?
I just recently discovered i had a 215mm 4age flywheel lying around and want to use it for the new engine but noticed it already has some parts drilled out of it.
Anyone know if this could be a problem?
The pics show 2 smaller holes drilled all the way through and one large hole on the inside face.
Here are the pics.
http://img297.echo.cx/img297/5928/fly0019cn.jpg
http://img297.echo.cx/img297/5698/fly0029nb.jpg
http://img297.echo.cx/img297/5120/fly0053ic.jpg
http://img297.echo.cx/img297/1852/fly0081wd.jpg
allencr
tallahassee FL usOFa
Re: Balancing Flywheels (warning: massive pics) Fri, 24 June 2005 12:48 Go to previous messageGo to next message
no reason to balance it, unless you just want to for the hell of it. any special reason why you wanna???
it absolutely needs to be resurfaced if you want to do a decent job!
it almost absolutely needs to be cleaned up or resurfaced on its mating surface to the crank!
those 2 holes on the inside aren't for balancing, but that large one near 11 o'clock in the first pic is.
Re: Balancing Flywheels (warning: massive pics) Fri, 24 June 2005 12:52 Go to previous messageGo to next message
factory balancing? looks similar to that done to K motor flywheels
Re: Balancing Flywheels (warning: massive pics) Fri, 24 June 2005 13:04 Go to previous messageGo to next message
It looks like factory balancing and it won't be an issue. The flywheel can be rebalanced multiple times. For the best job, take your pressure plate as well.
Toobs
Re: Balancing Flywheels (warning: massive pics) Fri, 24 June 2005 13:13 Go to previous messageGo to next message
Thats nothing... the factory flywheel off my frontcut had about 5 drill holes from factory balancing!
Big T
Re: Balancing Flywheels (warning: massive pics) Fri, 24 June 2005 22:46 Go to previous messageGo to next message
Great thanks guys!
I'm getting the entire engine balanced up so flywheel, pressure plate, crank, rods, pistons and harmonic balaner. It's a given that i'll machine and clean up the flywheel as well.
Eddie.
Mr DOHC
Re: Balancing Flywheels (warning: massive pics) Sun, 26 June 2005 04:15 Go to previous messageGo to next message
how much u paying for the balance anyway
Big T
Re: Balancing Flywheels (warning: massive pics) Sun, 26 June 2005 08:49 Go to previous message
Well the engine balance itself is about $160 if i remember correctly. But i don't think this will include cleaning up/machining the flywheel but i can't imagine it being that much more expensive ontop of this price.
Eddie.
Previous Topic:clunk in diff
Next Topic:Quick Plumback BOV question
Current Time: Fri Oct 23 02:59:02 UTC 2026
Total time taken to generate the page: 0.0042529106140137 seconds
