Toymods » Tech & Conversions » 3TGTE thermostat housing neck
ToyT18
Hobart
3TGTE thermostat housing neck Fri, 24 June 2005 10:00 Go to next message
3TGTE thermostat housing neck.
i took my thermostat housing to a guy so he could point it towards the front of the car so it would be easy to put on a radiator hose being a qualified engineer i thought he would do a good job but i went back and he said he tried to do it but the metal was too thin and burnt holes when i welded? so hes completely fucked it. can i use a 3TC one of these they look similar? has anyone else had this done?
YelloRolla
On your mum!
Re: 3TGTE thermostat housing neck Fri, 24 June 2005 10:20 Go to previous messageGo to next message
Use one of an 18RC. They look a whole lot better.
Grega
melbourne.victoria.austra...
Re: 3TGTE thermostat housing neck Sat, 25 June 2005 00:15 Go to previous messageGo to next message
too much voltage. did he TIG or MIG? not sure whether you could use a 2T one...
slonlo
auckland new zeland
Re: 3TGTE thermostat housing neck Sat, 25 June 2005 11:18 Go to previous messageGo to next message
you can use a 2tg one
fits fine and faces almost dead forward
YelloRolla
On your mum!
Re: 3TGTE thermostat housing neck Sun, 26 June 2005 08:17 Go to previous messageGo to next message
Grega wrote on Sat, 25 June 2005 10:15
Apology for being pedantic - but amps not volts..
ToyT18
Hobart
Re: 3TGTE thermostat housing neck Sun, 26 June 2005 09:28 Go to previous messageGo to next message
thanks for the help. i dunno what he used to weld it with, so an 18rc one will point the way i want?
[Updated on: Sun, 26 June 2005 09:33]
Grega
Re: 3TGTE thermostat housing neck Sun, 26 June 2005 21:58 Go to previous messageGo to next message
jason - well picked. amps. Embarassed
sounds like 18RC or 2T one should be fine.
a mob called kilkenny castings seem to cast HEAPS of these things - go to local supercheap and have a looksee...
ToyT18
Hobart
Re: 3TGTE thermostat housing neck Mon, 27 June 2005 07:16 Go to previous message
okes
Previous Topic:ae86 4age sump removal
Next Topic:compression testing
Current Time: Mon Oct 12 13:44:47 UTC 2026
Total time taken to generate the page: 0.086059093475342 seconds
