Toymods » Tech & Conversions » Fuel Line Blockage ?
ra23celica
Fuel Line Blockage ? Fri, 24 June 2005 10:47 Go to next message
I have an RA23 with a 1G-GZE and external electric fuel pump supplying a 8mm line to the motor while the original 6mm line carries it back to the tank. The fuel system is stock and the injectors where cleaned and tested not long ago.
How can I tell if any of the fuel lines are blocked ?
The engine is running rich and has no power. The fuel pump used to make a continous buzz when it was on, now it changes pitch and tone and sounds like it is struggling.
Would this cause a lack of power ?
All help appreciated. Thanks,
Mitch.
Re: Fuel Line Blockage ? Fri, 24 June 2005 12:25 Go to previous messageGo to next message
remove return line at tank and run to bucket (away from exhaust)
maybe the return line is blocked, or maybe the pressure reg is not functioning properly, giving high rail pressure and over-rich conditions?
ra23celica
Re: Fuel Line Blockage ? Sat, 25 June 2005 00:23 Go to previous message
Thanks Stew, good ideas and I will check this out over the weekend.
Mitch.
(Suffering Caldina envy!)
Previous Topic:to someone who has anthony kellam extractors
Next Topic:Hilux hub on RA60 strut
Current Time: Thu Nov 19 03:31:44 UTC 2026
Total time taken to generate the page: 0.012248992919922 seconds
