Toymods » Tech & Conversions » My 4AGZE with electric water pump
nick.parker
January 2005
icon5.gif  My 4AGZE with electric water pump Fri, 24 June 2005 14:43 Go to next message
I have a 4AGZE'd AW11 MR2. I have ditched my mechanical water pump for an electric (Davies Craig) pump, due to SC14 conversion and the mechanical water pump doesn't fit anymore. I have removed the thermostat too, and have a custom hardware to run the water pump. It runs slow when water temp is cold basically.
My setup is this:
Thermostat is GONE, all standard metal water metal pipes are GONE. This is ALL I have :-
1. the pump sources cold water from radiator and pumps it into the block where the old water pump use to pump into, BUT T'd into this pump outlet is the smaller line that goes to the heater.
And yes, I know, its cool water going to the heater..please read on..
2. the water exits the engine through the standard rectangle hole on side of head and goes back to the radiatior
3. heater outlet on back of head goes to heater, but flow is reversed (read point 1. again for why)
Is there a problem with pumping cool water into the 'old heater outlet' instead of hot heater water coming out. This setup would mean the only place hot water leaves the engine is the rectangular hole on the side of the head in (2).
I actually screwed up, but I want to hear if anyone thinks there will be a problem with this unorthodox approach, before I spend an hour fixing it.
Regards, Nick
nick.parker
January 2005
Re: My 4AGZE with electric water pump Sat, 25 June 2005 02:37 Go to previous message
Please, can anyone comment?
Regards, Nick
Previous Topic:2tgeu coolant lines in T/B
Next Topic:engine damper
Current Time: Thu Nov 19 03:03:49 UTC 2026
Total time taken to generate the page: 0.0077779293060303 seconds
